Old Jan 29, 2013, 11:47 AM
JRuggiero is online now
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
My RedWhiteBlue
After years of delay, I built a new fuselage around (or under ) an old wing I had built for a model using GWS IPS power (remember IPS?). Because I'm too lazy to build a tail from balsa sticks and covering, I opted for 3MM Depron construction.
I call it RedWhiteBlue. It's a variation on the style of sport free flight models from the 1940s and 1950s. Span is 36 inches, weight is about 7 ounces with 2S 460 mAh Rhino pack. Motor is a BP Hobbies A2204/14 brushless, ESC is a Castle 6 Amp. Thunderbird, and prop is an 8 X 3.8 slow flyer. Receiver is an OrangeRX 6 channel and servos are HXT600s.
What's special about it is that it is nearly a perfect primary trainer. It's very stable, thanks to the polyhedral wing. Put it into a tight turn and release the sticks, it will come out of the turn in a blink and return to level flight. Note that the control surfaces are small. They are adequate for take-off, cruising around, and landing. But I have to work hard to do a loop.
As a primary trainer, loops and rolls are not part of the syllabus . It's so easy to fly that any basic 3-channel radio will work fine, and there is no need for dual rates or exponential.
There are times and places when I need relaxing, reliable flying, and RedWhiteBlue fills the bill.
Jim R.
JRuggiero is online now Find More Posts by JRuggiero
Help! how do I know my multi4 is not cooking my packs? ronj10 FMA Direct 2 Jan 05, 2013 05:13 PM
Help! My First Build - Can Someone Check My Parts List? jelled123 Multirotor Electronics 2 Jan 05, 2013 11:35 AM
Help! My push rods arent working in my champ can someone help me. joeIII Electric Plane Talk 5 Jan 04, 2013 07:12 PM
