Old Jan 29, 2013, 11:37 AM
rhokita is offline
Find More Posts by rhokita
gardena, ca
Joined Feb 2003
Optima 6 stopped working after 2 weeks powered storage
I recently installed and checked out an Optima 6 into one of my airplanes. I forgot to remove the motor battery and had shelved the airplane. When I decided to fly the airplane a couple weeks later, I discovered that the motor battery was still plugged in and now discharged. So I plugged in a new motor battery, turned on, receiver LED is illuminated and no servo movement. I tried rebinding and still no servo movement. I also tried using the SPC plug using another external 12V battery and still no servo movement. The Transmitter works fine with another receiver. Removed the case and did not observe any stressed components. Don't know what happened to the receiver when it was mistakenly left on for a couple weeks.
Any ideas what caused the receiver to die after powered on storage? Would reflashing the receiver do any good?
rhokita is offline Find More Posts by rhokita
Old Jan 29, 2013, 11:45 AM
rhokita is offline
gardena, ca
Joined Feb 2003
Oh yeah, I also tried a complete bench top setup with a 5V receiver battery instead of the ESC's BEC and new servos. Same symptoms, LED on and no servo movement. I know the servos are getting power since they move a little when i toggle the power switch.
Old Jan 29, 2013, 10:28 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Check firmware in Spectra Module (& Tx if Hitec & updates are available) is current and retry :
Hitec AFHSS ID-Setup (Bind) with your 5V? Rx battery (4 cell or 6v 5 cell rechargeable fully charged) via the SPC port. (Disconnect ESC)
If after two attempts, reset is not established, refer direct to:
Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
service@hitecrcd.com any time you have a question"
If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Question LIPO cycling after storage?? no power now, bad batt? finguz Batteries and Chargers 9 Jan 19, 2013 10:47 PM
Sold Hitec Optic 6 Sport 2.4 transmitter+ Optima 6 receiver mnahmia Aircraft - General - Radio Equipment (FS/W) 2 Jan 17, 2013 12:03 PM
For Sale 2 HIB Hitec Optima 6 receivers GeetarJoe Aircraft - General - Radio Equipment (FS/W) 5 Jan 06, 2013 02:02 PM
Discussion Picco Z (Havoc Heli) stopped working after 6 flights? bfaulguy Micro Helis 1 Feb 28, 2007 07:50 PM
My EPU-6 (DX-A) Motor Died After 2 Weeks? Manchild Parkflyers 6 Oct 07, 2002 11:47 PM
