Espritmodel.com Heli Air
Old Jan 29, 2013, 10:18 AM
Return of the Warlord
vernon7026's Avatar
United Kingdom, England, Wallington
Joined Aug 2009
Lipos in Parallel
Hi can someone tell me, if i place 2 x 3s battery ( 2200mah 25c )
What will the overall amperage be in Parallel ?
Would it be 110a ??
Thanx
vernon7026 is offline Find More Posts by vernon7026
Old Jan 29, 2013, 01:59 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
Yes, it would be 3s voltage but 4400mah at 25c.
wparsons is offline Find More Posts by wparsons
Old Jan 29, 2013, 07:01 PM
United States, AZ, Seligman
Joined Nov 2011
Yes, your mah will double and voltage will remain the same if wired in parallel. Your mah will remain the same and your voltage will double if wired in series.
Dave8888 is offline Find More Posts by Dave8888
Old Feb 08, 2013, 05:32 PM
cyberhoops's Avatar
Seattle
Joined Feb 2006
The max amp draw for a 2200mah pack at 25c would be 55 amps, so yes, if you hook two of them in parallel you could draw 110 amps. They would last about 2.4 minutes at that amp draw, but the batteries would suffer.
cyberhoops is offline Find More Posts by cyberhoops
Old Feb 09, 2013, 07:29 PM
United States, NJ, Frenchtown
Joined Mar 2003
And you can buy new batteries every 20 flights. Good luck on overdischarging at that rate. Strap a fire extinguisher to your hip..
cyclops2 is offline Find More Posts by cyclops2
Old Feb 10, 2013, 04:49 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
If you know you need 110a constant, opt for at least 4400mah 40c total, ideally 5000mah 40c.
Old Feb 11, 2013, 01:34 PM
United States, CO, Aurora
Joined May 2009
My 2200s barely hold 40A each at around 10.1V and the voltage starts dropping from there. I'd say you would want at least 3 or 4 in parallel if the batteries are that small to hold 110A.
hemiblas is offline Find More Posts by hemiblas
Old Feb 11, 2013, 02:05 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
^^ Depends on the C rating of the packs too... a 2200mah 20c pack is only "capable" of 44a, so that wouldn't surprise me if your packs are 20c.
Discussion using 2 lipos in parallel GaryX1001 Batteries and Chargers 5 Jan 28, 2013 03:07 PM
Question Parallel Charging E-Flite 1C Lipo's thannamhbfp Batteries and Chargers 9 Jan 26, 2013 08:26 AM
Discussion running parallel LiPos - what about balance plugs hamburger Batteries and Chargers 10 Jan 16, 2013 07:25 AM
Question Connecting Cells in Parallel: Can This Be Done? AEMontoya DIY Electronics 3 Jan 09, 2013 10:39 PM
Discussion wiring a bec and esc in parallel nicosoh Power Systems 3 Jan 06, 2013 02:15 PM
