Old Jan 29, 2013, 08:33 AM
m.kennedy is offline
Find More Posts by m.kennedy
Learning More Every Day...
Cincinnati, Ohio
Joined Aug 2007
Question
How to Start a Moki 210
Hi Everyone!!
Last weekend I went to a swap meet and found a gently used Miko 210 (nitro) engine. [I don't even have an airplane for it ...yet!!] But I've never owned a Moki engine and at the price I bought it.
Yesterday I tried to start it and was unsuccessful. Not because something the engine did, but because my starter didn't appear "strong enough".
I don't blame the engine. In fact, I know the engine has good compression. But, I've heard of being able to hook up a starter to a 24 volt (set of) batteries. This may be the answer for me...
How do I go about hooking up a 24 volt system? Is that two batteries in series? ...in parallel?
Thanks in advamce!! Mike
m.kennedy is offline Find More Posts by m.kennedy
Old Jan 29, 2013, 08:44 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Hook the battery's in series. Positive to negative. Some of the guys are using 18 volt drill battery's or Lipo's for power.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old Jan 29, 2013, 10:02 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Back-flip - the safe way to hand-start.
Mike,
Your Moki will respond to back-flip and start like a champ!
Prime it, turn it over several times by hand, then power the glow-plug and flip it backward against compression (not all the way over).
It will kick-back and start running in the normal direction.
Do it with 'soft fingers', so once the blade is kicked back and clears your fingers, your entire hand will be out of the way.
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 29, 2013, 10:45 AM
proptop is offline
Find More Posts by proptop
Airplane Gearhead
Central N.Y.
Joined Jan 2005
Yes...if you try to hand start it, be careful...especially if you get it a bit too juicy...it can kick like a mule. Don't try to flip it through compression...just bounce it back, off compression...and if it's primed properly, it will start and run in the correct direction.
proptop is offline Find More Posts by proptop
Old Jan 29, 2013, 12:37 PM
Reginald is offline
Find More Posts by Reginald
Reginald's Avatar
Belgium
Joined Aug 2004
And do use a heavy glove ! I do have a Graupner one with extra rubber tubes inside.
Reginald is offline Find More Posts by Reginald
Old Jan 29, 2013, 01:24 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I use a leather glove on the hand doing the prop flipping. It helps prevent the nasty cuts, but it can still hurt if it back fires on me.
What I do is prime the engine some, I choke the carb, then turn the prop over several times to get fuel into the carb/engine. Then I hook up the glow ignitor, then I give it a back flip and most of the time the engine fires right on up.
At the beginning of this video clip you can see the back flip method.
ASP 180 engine test run 02 MOV (4 min 36 sec)
earlwb is offline Find More Posts by earlwb
For Sale Mokie 210 XL F/S trojant28 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 03, 2009 05:49 PM
Discussion What would be a good 35cc/moki 210 3d airframe?/ outofsight 3D Flying 2 Nov 12, 2008 07:14 PM
For Sale FS: Moki 210 with Inverted Bison, Perry pump and prop BoneDoc Aircraft - Fuel - Engines and Accessories (FS/W) 3 Feb 11, 2006 09:45 PM
For Sale Bisson Pitts Moki 180 or 210 muffler drakelgd Aircraft - Fuel - Airplanes (FS/W) 0 Jul 09, 2005 08:23 PM
