Old Jan 29, 2013, 04:03 AM
mdem is offline
Find More Posts by mdem
mdem's Avatar
Australia, VIC, Carrum Downs
Joined Oct 2012
Help!
¿?Servo stutter question¿?
Hello everybody, quick background:
- Just got 9xR this morning
- Installed Orange DMS2 module
- Using DMS2 LemonRX
- HXT900 servos (also tried HXT500)
- 2s LiPo as RX battery
So today I got my 9xR in the mail, installed the Orange DMS2 Module, upgraded to latest er9x firmware via USBasp.
Wanted to see if my RXs worked that I ordered from LemonRX (I wanted very small ones for a small glider).
They did work after I noticed I needed to change the channel settings in er9x.
I used a 2s LiPo as the RX power since I that’s what I had on hand, it was at 7.65v, the R can handle upto 10.2v, so there shouldn’t be a problem as far as I can see on that front.
Got everything working but my servos keep stuttering/fluttering/jittering, whatever you want to call it.
It does it pretty much on any channel and on any servo I use. Not 100% of the time, but enough for me not to use them in any plane.
Anyone have any ideas, maybe I’m doing something wrong I don’t see?
I took some quick videos of my binding process and the stuttering itself so you know what I’m trying to say, along with pictures of the setup I used, battery (on a checker), and spec sheet of the RX in use.
Any help would be great.
-Thanks
mdem
RX specs:
https://www.dropbox.com/s/0bro5jp9o8...RX%20specs.jpg
RX1/2:
https://www.dropbox.com/s/8njmx0si5nnkyne/RX%201.JPG
https://www.dropbox.com/s/knfm085iupefezj/RX%202.JPG
Setup picture:
https://www.dropbox.com/s/wyg6mpl31a8wc97/Setup.JPG
Module:
https://www.dropbox.com/s/rv5r49ce58...X%20module.JPG
Battery check:
https://www.dropbox.com/s/jmd5g4o2at...ry%20check.JPG
Bind process + stutter:
(video)
https://www.dropbox.com/s/2hglvf7bth...%20stutter.avi
Stutter again:
(different servos)
https://www.dropbox.com/s/7qq6ybsojc...%20stutter.avi
mdem is offline Find More Posts by mdem
Old Jan 29, 2013, 04:17 AM
AussieNewbie is offline
Find More Posts by AussieNewbie
A regular at PP
Joined Jan 2013
Here's a foolproof trouble shooting guide.
Q: Did you buy the servos from Hobbyking?
A: If yes, they're essentially crap servos.
AussieNewbie is offline Find More Posts by AussieNewbie
Old Jan 29, 2013, 04:42 AM
dingo is offline
Find More Posts by dingo
knee ligaments are over rated
dingo's Avatar
Melbourne , Outer East .
Joined Dec 2003
Quotte
I`m not sure what your saying here . You used a 2s lipo at 7.65 volt for your reciever power . But your R ( assuming this is your transmitter ) is ok for 10.2 volt . Most servo`s don`t handle much more than 6 volts .
dingo is offline Find More Posts by dingo
Old Jan 29, 2013, 05:04 AM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Originally Posted by dingo View Post
Quotte
+1. You're lucky the servos are still working at all - at least they were unloaded. They get whatever voltage is applied to the Rx bus, in this case the full 7.65V from the 2S pack. Good thing it wasn't fully charged at 8.4V. Unless a servo is rated as high voltage, assume a max of 6.0V. And for cheapies, assuming 5V is probably safer.
Some folks get away with 2S LiFe unregulated at 7.2V max for Rx and standard voltage servos,, but not 2S LiPo.
scirocco is online now Find More Posts by scirocco
Old Jan 29, 2013, 05:07 AM
mdem is offline
mdem's Avatar
Joined Oct 2012
Oh I see, yeah I used a 2s LiPo as my receiver power pack, thinking the LemonRX could handle it no problem, but I forgot the servos can only handle 6v..
Do you think pushing 7.65v through the RX into the servos would be causing the problems I'm having?
I don't have any other batteries on hand, I'll have to use power supply at brothers house next time I go.
Thanks again
mdem
Old Jan 29, 2013, 05:11 AM
mdem is offline
mdem's Avatar
Joined Oct 2012
Ok, I understand where I went wrong haha. Honestly just went over my head, to check what the servos are rated for.
So I'm guessing the excessive voltage is the reason for the stuttering from what you guys are saying.
Ha, well that's why I asked, I'm still new to this and I will make mistakes
Thanks for the heads up.
Will have to go through and check all my servos in case I did any damage to them before I use them for anything.
Old Jan 29, 2013, 05:12 AM
dingo is offline
dingo's Avatar
Joined Dec 2003
I`d try a normal 4 cell rx pack & try outdoors away from tin sheds etc & see what happpens .
Old Jan 29, 2013, 05:22 AM
mdem is offline
mdem's Avatar
Joined Oct 2012
I Don't have a 4cell RX pack, never needed one before so never though to buy one, although I might since they are good for test beds.
I'll just have to go to brothers house, he have a power supply with a variable voltage output.
Old Jan 29, 2013, 05:39 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Have you got an ESC handy that you can run through the rx then the servos on the rx aswell? The ESC's UBEC should do the trick for you.
Teamsherman is offline Find More Posts by Teamsherman
Old Jan 29, 2013, 05:50 AM
mdem is offline
mdem's Avatar
Joined Oct 2012
Yeah I have a few spare ESCs handy but none of them have any connectors on them.
I'm in no rush, waiting on another order from HK with parts that were missing in my little glider anyway, so cant build. Have some time.
I'm just happy I found out what I was doing wrong so I can avoid it next time.
Old Jan 29, 2013, 06:00 AM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
That's not at all true btw. When value and number of planes in the air because of that value are factored into the equation, the HXT900 is probably the best servo on Earth.
They're strong, robust, and a little power-hungry, which is understandable given the high-range strength. Hitec HS-55s are at least 4 times the price, and they're not better in any quantifiable way.
H2SO4 is online now Find More Posts by H2SO4
Old Jan 29, 2013, 08:59 AM
MclF1 is offline
Find More Posts by MclF1
CRASHING IS THE EASY PART
MclF1's Avatar
Australia, NSW, Oatley
Joined Sep 2011
Thanks again
mdem
try it with a bec
MclF1 is offline Find More Posts by MclF1
Old Jan 30, 2013, 02:01 PM
16141 is offline
Find More Posts by 16141
Cliff
16141's Avatar
Australia, QLD, Pacific Paradise
Joined Oct 2011
What dingo said.
Cliff
HXT900 and HXT500 are excellent servos
16141 is offline Find More Posts by 16141
Old Jan 30, 2013, 02:58 PM
AUSELECTRIC is offline
Find More Posts by AUSELECTRIC
Joined Nov 2004
HTX 900 must be ok If used in smaller DS planes and wings.
AUSELECTRIC is offline Find More Posts by AUSELECTRIC
Old Jan 30, 2013, 04:07 PM
Member #1
Joined Aug 2011
Hmm, I don't think I use anything but HXT servos. My parachutist has metal gears and the FunCub too but the rest are HXT.
Discussion Stuttering Motor with a twist FreneticKinetic Power Systems 9 Jan 23, 2013 11:08 PM
Discussion Brushless motor stutters at high speed zer0g Power Systems 8 Jan 18, 2013 03:40 PM
Question Motor stuttering? joker24458 Foamies (Scratchbuilt) 7 Jan 12, 2013 04:20 PM
KAN950 making my servos stutter! rmasonjr Batteries and Chargers 9 Mar 01, 2004 12:28 PM
Stuttering Servos safetyboy Slope 7 Oct 29, 2002 11:01 AM
