Old Jan 28, 2013, 11:41 PM
savage0102 is offline
Find More Posts by savage0102
Joined Jun 2012
Is this engine good for Thundercat 31?
Hi, Boaters!
Is this Thunder Tiger .46 engine a good one as an upgrade engine for a Pro Boat Thundercat 31?
Here is the link. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAHSX
According to the specs, while the stock Dynamite .32 engine of Thundercat is 1.18 hp at 28.000 rpm, Thunder Tiger .46 engies' power is 2.46 HP @ 23,000 rpm.
If this .46 engine is good enough as an upgrade, is quite bit of midofication necessary to mount it in the TC 31? Also what prop would be the best one for this engine in the TC 31?
Advices from experienced boaters will be greatly appreciated! Thanks!
savage0102 is offline Find More Posts by savage0102
Old Jan 29, 2013, 11:03 PM
Ron Olson is online now
Find More Posts by Ron Olson
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
You'll find that it will some some work to drop it in there as the output shaft is different as the Thunder Tiger uses an SG type shaft because it's made for a clutched engine.
In this case your giving up one thing for another, HP or RPM.
Ron Olson is online now Find More Posts by Ron Olson
Old Jan 31, 2013, 01:19 AM
Joined Jun 2012
Thank you Ron for your response! I guess I shouldn't go with Thunder Tiger engine.
Isn't there more powerful engine than the Dynamite .32 engine with an affordable price? Thank you again!
Old Jan 31, 2013, 08:39 AM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
There's always more powerful but they come at a price unfortunately.
I've seen guys try to drop in better ones but there is the work of getting it in there. Usually the exhaust system seems to be the biggest headache.
Let's assume that you didn't blow your engine up as maybe you did or didn't. There are a few things that can be done to get a little more power out of it. First and easiest mod is to port match the header. Pull it off and you'll see how it chokes down the flow. Get a Dremel and open it up as that can be worth about a 1,000 or more RPM (!) increase there alone! The carb is considered a Sport carb as actually the whole engine is. That's like running and trying to breathe through a straw. I've seen where some have adapted a Super Tigre carb to get more air and fuel to it.
The stock prop, well, sucks. Try an Octura M-445. We spent a day testing props on one of these from my box of props and on radar found that one to work best from what I had handy. If you see elsewhere about that prop on that boat, you know now where it came from. It may not be the best one for it but just what I had at the time.
Get some weight towards the back. Place a 10-12 oz. tank in the right rear sponson. You can leave the stock one in place if you'd like. This will allow the hull to get more air under it.
Old Jan 31, 2013, 09:42 PM
Joined Jun 2012
Hi, Ron! Thank you very much for your advice again!
I have already done the exhaust header porting, as you recommended. And I saw that you recommend Zipp Kits 444 prop on a different forum, so that I have ordered it, and it will be delivered tomorrow (I am excited for that prop, since the stock prop is a crap.).
Could you tell me which carb of Super Tiger (possibly the part number, too) of it, please? In addition, does this carb perfectly fit into the hole of the Dynamite .32 engine without any issue?
I think I should get the carb that you mentioned rather than buying a better engine, because I don't want to be kicked out of home by my wife (lol)! Thank you again!
Old Jan 31, 2013, 10:31 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
The 444 should be a good prop as I forgot about that one!
As far as the carb goes, it seems like it was from a .46, probably off a plane engine.
Old Feb 01, 2013, 10:30 PM
Joined Jun 2012
Thank you for your response, Ron!
If you don't mind, let me ask one more question, please. Is removing some shims under the engine head a good idea or not? If so, how many sims should be removed? I hope it does not burn the glow plug so quickly. Thank you again!
Old Feb 01, 2013, 10:37 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Sure! Usually ProBoat puts 2 of them in and you remove one after a short break-in period. Most marine engines only have about .0012" of head clearance.
Old Oct 13, 2014, 01:22 PM
duty is offline
Find More Posts by duty
Joined Aug 2014
hey ron I took my head off the other day and thiers 3 shims 2 are like siver and then a real thin like copper almost type of one which ones can I remove ??
duty is offline Find More Posts by duty
Old Oct 13, 2014, 01:29 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
Leave the copper one in.
Old Oct 15, 2014, 01:20 PM
duty is offline
Joined Aug 2014
Originally Posted by ron olson View Post
leave the copper one in.
thank you !! its really ashame that all the posts about this great boat died off !!
Old Oct 15, 2014, 03:17 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
When they quit making the boats then the postings kind of die off.
I did see one for sale last night on Facebook without a lot of time on it and the guy was taking offers. I was really close to making one as it looks like I could do a build on one showing how easy it is to modify one for next to nothing. Combined mods might cost $40.00 which is dirt cheap if you can gain 10 MPH.
Old Oct 15, 2014, 09:28 PM
duty is offline
Joined Aug 2014
when they quit making the boats then the postings kind of die off.
I did see one for sale last night on facebook without a lot of time on it and the guy was taking offers. I was really close to making one as it looks like i could do a build on one showing how easy it is to modify one for next to nothing. Combined mods might cost $40.00 which is dirt cheap if you can gain 10 mph.
send me the link if you dont want it ill buy it !!
Old Oct 15, 2014, 10:17 PM
RC boat Rock Star
Kalamazoo, MI
Joined Apr 2004
If you're on Facebook, here it is: https://www.facebook.com/groups/2439537306/ . His name is Travis Hitsman.
I had to do some looking as there's a lot of RC boat groups on Facebook.
OK, I just had another guy hit me up letting me know that he has one for sale also: https://www.facebook.com/mark.farmer.3781?fref=ufi
Old Oct 16, 2014, 05:44 AM
duty is offline
Joined Aug 2014
thanx ron it wouldn't let me send him a message on fb im not friends with him are you ? how much does he want for it ?
Discussion Rebuilding a Shoestring Stunter. What engine is good for this model? RknRusty Control Line 5 Jan 27, 2013 09:56 PM
Discussion Pro boat ThunderCat 31 prop question Thundercat31 Racing Boats - Internal Combustion 35 Aug 16, 2010 10:30 PM
Discussion Best Prop for Proboat's Thundercat 31 Tbone2000 Racing Boats - Internal Combustion 12 Jul 23, 2009 10:46 PM
For Sale Proboat Thundercat 31 trade for blade 400 hoofhearted Boats (FS/W) 0 May 24, 2009 07:33 AM
Discussion Thundercat 31 harleridr Racing Boats - Internal Combustion 2 Aug 01, 2008 05:45 PM
