That looks like a RC Car slide valve carburetor on a model airplane engine. The needle valve sticking up like that tends to be a giveaway. A number of different brands made carbs like that too. But it does have some similarities to Picco, OPS, Ofna and some others though. The complicated direction changing parts for adapting it for airplane use is interesting. I hadn't seen that before.
Latest blog entry: My Low Wing plane
Joined Aug 2004
No way, Craig.
Webra had their own sort of slide-valve carburettor. It was called Dynamix and its slide-valve was flat and worked differently in that the fuel-control 'needle' moved in parallel (not in its center, like in this carburettor's cylindrical slide-valve) to the slide-valve, within the fuel inlet tube. Here are a couple of photos. The engine is not a Webra either, even though their Black-Head did wear its muffler similarly... |
| Thread Tools | |
| Sold 2.5m nimbus vintage sailplane(help id please) | steeg | Aircraft - Sailplanes (FS/W) | 3 | Jan 20, 2013 03:15 PM |
| Discussion Need Help ID'ing Transmitters NOW WITH RCVRs | oddshot | Indoor and Micro Models | 23 | Jan 19, 2013 07:47 PM |
| Help! 26cc ID and Carb help !!??? | Colin Geisel | Engines | 3 | Apr 09, 2012 04:20 AM |
| Help! Carb ID | Jason_WI | Engines | 3 | Jun 30, 2010 10:57 PM |
| Question Can you id these carbs? Test your knowledge! | iamplanecrazy2 | Engines | 1 | Jul 01, 2005 01:50 PM |
