Espritmodel.com Heli Air
Old Jan 28, 2013, 09:04 PM
Every day Im FPV'n
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
ChanYote66's SUPER SKY SURFER Build (lessons Learned)
After building my first Super Sky Surfer from Banana Hobby I got to enjoy some great flights and awesome footage from its ~4 hours of flight. Then it decided to commit suicide and release the main wing from the body and fall 400ft to its death reaching 60-70mph before hitting nose first on asphalt
This Thread is focused on the second build and everything I wanted to do to the first after its wreck.
Lets start off with the First build...
Description: Name: Blue flood.jpg
Description: Name: RD32Pod.jpg
Description: Name: wing wires.jpg
Description:
EPIC Flight!
SSS FPV - Sunset over Oak ridge (9 min 15 sec)
And the Final footage Before that terrible day...
Super SkySurfer Lights (still under construction) (1 min 38 sec)
Super Skysurfer DOSD+KK2.0 (5 min 41 sec)
The Failure...
Description: Name: IMG_0017[1].jpg
Description:
chanyote66 is offline Find More Posts by chanyote66
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
So...
Let the Second Build Begin!
Ill add the Pics for now and then Add details soon...
Reinforcing the Wing area...
I started by cutting a tiny groove around the wing area and under the body, Then I cut open the Motor area to install the 55A Turnigy Trust ESC and cut a air scoop hole. I then reglued the halves together, wrapped 3 strands of paracord strings (the inside of paracord) into the grove, and then soaked in gorilla glue. After that It got covered in Fiber tape, A light coat of Epoxy, and then 3mil vinyl.
Description: Name: install ESC.jpg
Description: Name: Cord glue.jpg
Description: Name: IMG_0084.jpg
Description: Name: vinyl wrap.jpg
Description: Name: Wrap 2.jpg
Description:
Fixing wiring...
The wings have two servos already, and then when you add wiring for lights it would be a mess to connect at the field (and its too big to keep in one piece) So I used 6 position Latching Connectors From TE electric to connect all servos and light controls.
Description: Name: IMG_0120.jpg
Description: Name: IMG_0121.jpg
Description: Name: IMG_0124.jpg
Description:
Making it shiny... without LED's
The Decals were cut from 3M™ Scotchlite™ Reflective Graphic Film Series 580 E and 3M™ Scotchlite™ Reflective Material - SOLAS which has parts covered in red permanent marker.
Description: Name: body reflex.jpg
Description:
Bringing some Light to the Project...
I ran some wiring out to the tail, wingtips, and Flood lights for plenty of lighting. The LED Strips are (RED) (BLUE) (GREEN) And the 3W White LED's are found at Home Depot and are Philips 2.5-Watt T3 LED (you can also see here that I moved the Servos To the tail since the stock Push rods are so terrible.)
Description: Name: IMG_0116.jpg
Description: Name: tail servos.jpg
Description: Name: IMG_0129.jpg
Description: Name: IMG_0126.jpg
Description: Name: IMG_0127.jpg
Description:
Getting Ready for FPV!
The Pod was hand built from 1mm CF from Hobbyking and uses two Servos a turnigy 180degree and a Turnigy MG90S. The Cameras are two PZ0420's One with the Stock 3.6mm lens and the other with a 25mm MTV Lens that will be a Zoom.
Description:
Old Jan 28, 2013, 09:05 PM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
Place holder...
Old Jan 29, 2013, 06:59 AM
United States, IN, Fort Wayne
Joined Dec 2012
Did you relocate the elevator servo as well?
RandallJ is offline Find More Posts by RandallJ
Old Jan 29, 2013, 10:10 AM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
Yes, it is on the other side of the rudder servo. The linkage was also flipped over so it is a "Pull" for up ele rather than the stock "push" for up ele...
Chris
Old Jan 31, 2013, 12:02 PM
Crash test dummy....
mattthomas78's Avatar
United States, TN, Waynesboro
Joined Mar 2012
I'm subbed!! Great work so far!!
mattthomas78 is offline Find More Posts by mattthomas78
Old Jan 31, 2013, 01:04 PM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
Thanks!
I have it about ready for flight...
Sort of wish i got pics or video of replacing the pushrods with the wiring...
I used the pushrods to pull the shielded servo wire to the tail.
Chris
Old Feb 08, 2013, 11:06 PM
Creator of the 1st 6S HT-Flip!
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Looking sick!
flohio117 is offline Find More Posts by flohio117
Old Feb 09, 2013, 12:16 AM
Crashaffinity on youtube
CrashAffinity's Avatar
Canada, BC, Summerland
Joined Nov 2012
very sick.... now i'm gonna have to plan on just catching up to this build
CrashAffinity is offline Find More Posts by CrashAffinity
Latest blog entry: DJI F550 build w/naza
Old Feb 09, 2013, 07:47 PM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
lol...
Step 1: get your Dragonlink setup...
After that your close!
Old Feb 09, 2013, 08:41 PM
Joined Nov 2012
Originally Posted by chanyote66 View Post
lol...
it looks so peaceful in it's box besides... i just HAVE to see just how far my DX8 will take me! 3km as of friday, gonna shoot for 4 tomorrow
Old Feb 10, 2013, 09:34 PM
Canada, AB, Mundare
Joined Mar 2011
12000' in cold weather was my best with the dx8, now if only my DL would get back to me.
Beerwiser is online now Find More Posts by Beerwiser
Old Feb 10, 2013, 09:44 PM
Joined Nov 2012
in that case i feel bad... mine's sitting here right in front of me begging to be installed
but my spotter was complaining that he couldn't see my plane too well, so i painted it bumble bee on the bottom and fluorescent on the top, check it out, i totally think chanyote66 should go with my painting scheme. If anything it's extremely annoying to just about everyone the fluorescent doesn't really come through well in the photo, when we took it out in the sun today it was almost blinding
Old Feb 10, 2013, 10:02 PM
Every day Im FPV'n
chanyote66's Avatar
Joined Dec 2011
Nice!
Old Mar 07, 2013, 07:58 AM
AstarJoe's Avatar
United States, TX, Uvalde
Joined Mar 2013
Chris,
Could you post a picture of the LH rear (ele linkage) as well? Love the build. Inspiring me for my next SSS build. Also, in regards to the CF FPV tray, why not saw off the "instrument panel" portion on the front that angles up and flush it out all the way to the nose and make a simple flat tray? Would give you some more room up front if you needed it. Something like this:
AstarJoe is offline Find More Posts by AstarJoe
Discussion Lessons learned the hard way. What are yours? franke Multirotor Talk 65 Feb 01, 2013 02:33 AM
For Sale Graupner Sky Surfer paraglider NIB - Reduced WinglessB Aircraft - Electric - Airplanes (FS/W) 1 Jan 25, 2013 10:45 AM
Help! Mini Sky Surfer Build PRNDL Electric Plane Talk 6 Jan 13, 2013 12:33 PM
Discussion First DLG Build - Super TopSky 2.0 - Lessons Learned tdogg77 Hand Launch 5 Jun 08, 2012 06:10 PM
