Old Jan 28, 2013, 08:49 PM
spoinkster is offline
Find More Posts by spoinkster
Joined Jan 2013
Need help adding to my HK cart...
Please see my post @ http://www.rcgroups.com/forums/showthread.php?t=1819984 if you can help a newb...
Thanks!
spoinkster is offline Find More Posts by spoinkster
Old Jan 28, 2013, 10:26 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
You got a lot of parts you should never need, but that's OK, you can use them in the next plane. The ESC and servos will last a long time and I have yet to break a glider prop. looks like you are good to go.
If you are in the US, misc parts can be picked up from headsuprc with $2 shipping.
Have fun....... a glider like that will stay up a long time with only occasional motor use to get it back to altitude. You should get at least 30 min flying with one battery.
Oh, ordering lipo's from HK is iffy these days due to postal regulations. If you are in the US I'd suggest ordering them from:
headsuprc.com
hobbypartz.com
http://www.chinahobbyline.com/
http://www.haiyinstore.com
All have US warehouses, or use the HK USA warehouse for batteries.
ps - I see you are north of me a bit so all the USA comments apply.
Additionally, don't any include backordered items in you order as they will hold everything till the backordered items come in which might be awhile. And use PayPal to make the purchase.
hoppy is offline Find More Posts by hoppy
Old Jan 28, 2013, 11:51 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Wow looks like a good start! Like hoppy said, back ordered items can take a while. Also, always be careful with wall adapters for using lipo chargers. They often times cannot supply enough juice and can cause problems but as long as you keep the charge rate low, you should be fine. You are going to love your bixler!
Edit// It also never hurts to have spare battery connectors, servo extensions, heat shrink and even a lipo bag wouldnt hurt.
3d astronaut is offline Find More Posts by 3d astronaut
Old Jan 29, 2013, 07:50 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Each battery supplier uses a different connector (or so it seems), so ordering a dozen from HK of your favorite makes sense.
Generally, most motors to ESC use 3.5mm connectors. I'd get a set of those.
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC)
And some Silicone Wire, 16ga red and black
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red
Shrink tubing, a meter of 2, 3, 4, and 5mm (Like Turnigy 4mm Heat Shrink Tube - RED (1mtr)) One of red and one of black if you want to keep color code.
Battery connectors - Nylon XT60 Connectors Male/Female (5 pairs) GENUINE
Old Jan 29, 2013, 05:17 PM
Joined Jan 2013
Thanks! Great advise on the connectors. I've heard about issues on the fiberglass getting every where with the charging bags so I was planning on using a spare (plastic coated) safe I have laying around.
Awesome. I have access to 3M shrink tubing at work. Can speaker wire be used for this type of application or do I need to stick with silicone wire?
Old Jan 29, 2013, 05:53 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Any kind of wire can be used, but the flexibility and resistance to breaking from bending makes the Silicone wire much more desirerable for the battery to ESC connection.
Old Jan 29, 2013, 11:23 PM
Joined Sep 2011
After a ton of use, my lipo bags start to do this. Occasional use like charging at the field, fly ins etc. seems to be fine. They are cheap enough to replace though. As long as you have some sort of fire protection, you should be good
Old Jan 30, 2013, 08:03 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Be careful about using any old lipo bag, many of them are worthless for protection.
Here's some test data.
http://www.rcgroups.com/forums/showp...6&postcount=14
Help! Need help with my FPV uav project. Soren64able Engines 9 Feb 02, 2013 04:00 PM
Discussion Need help adding to my HK cart... spoinkster Beginner Training Area (Aircraft-Electric) 10 Jan 30, 2013 07:21 PM
Discussion HK 250 need help plemay Electric Heli Talk 3 Jan 12, 2013 09:29 PM
Discussion Needing help replacing my ESC DCDetector Power Systems 1 Jan 05, 2013 04:31 PM
Discussion my boat needs some help devansh Racing Boats - Electric 2 Jan 02, 2013 06:31 PM
