Old Jan 28, 2013, 06:11 PM
Joined Jan 2013
Product Idea
I am a student on a design team to make a process for quickly making new wings for gliders. I would love any input that anyone would be willing to give.
The idea is to make a vacuum-molding process that will quickly make wings out of thin wooden veneers by epoxying veneers together and then vacuum molding them into a female mold.
What are your thoughts? If this idea works, and if you could buy a mold for a very low cost, would you be interested? Would you scrap the idea and only go with composites molded from a very expensive mold?
I appreciate the help and will let you know how the project goes.
Thank you,
bradygarn
bradygarn is offline Find More Posts by bradygarn
Old Jan 28, 2013, 07:29 PM
In you face flying
timbuck's Avatar
gold coast australia
Joined Aug 2008
Hi brad.
A few of us build. Composite planes using vaneer as part of the lay up. As one of my best friends has been in the vaneer industry for a long time.
That process will work , although depending on the type if wing build. It doesn't like going around curves very well.
The problem is crash resistance. It shatters with out using composite fibers with it.
I've personally been down the road of plastics..and polycarbonate.... They work very well and are strong. BUT. On the down side once damaged are very hard to repair .
Also there are so many spray plastic and polymers around these days , I've spend million of hours over the last 5 years toying with idea's. Plastic Rotor molding also interests me also.
As all of these thing take a lot of time and money chasing the right product of technique.
Solid core structures are the best by far for strength. Depending on what type if plane you are referring to will depend on the TYPE of build you need.
What are you going to build ???
Tim
Composite structures do break , but are easily repaired in a lot of cases.
I've been down this road for a long time , and also may others have.
timbuck is offline Find More Posts by timbuck
Old Jan 28, 2013, 07:50 PM
Kevlar Piņata Corporation
Aerogance's Avatar
USA
Joined Sep 2008
Cheap composite parts from cheap moulds if you don't care about the final quality.
Aerogance is offline Find More Posts by Aerogance
Old Jan 28, 2013, 09:09 PM
Joined Jan 2013
Thanks for the comments!
We are first going to make a wing to be used on a plank.
Strength was one of our questions with regard to using wooden veneers. would lining the inside with composites help with the strength?
The reason for attempting wood veneers is that way we don't have to have an expensive mold, since the veneers won't pick up the flaws in the mold.
Could compound curvature be introduced to the wing by sanding after the airfoil has been molded?
Old Jan 28, 2013, 09:28 PM
In you face flying
timbuck's Avatar
Joined Aug 2008
Yes , you could put glass on the inside...although a balanced lay up or skin is much stronger.. Better to do the same on inside and out or the vaneer.
What vaneer are you thinking of using ??
We use single .5mm hard wood in our lay up's.
Yes compound curves like tips etc could be but you loose airfoil accuracy.
Tim
Old Jan 28, 2013, 09:40 PM
Joined Jan 2013
Thank you very much for the insights.
I agree with and like the idea of making a balanced lay up for the wing.
As far as which veneers to use, my group hasn't decided. But thank you for letting us know what kind you use.
Old Jan 28, 2013, 10:42 PM
Aerogance's Avatar
USA
Joined Sep 2008
You can do it old school and use balsa blocks at the wing tips that you can sand to a nice shape.
Old Jan 29, 2013, 04:09 AM
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
If you can, investigate how the 'Simprop' range of gliders are made. They would appear to use wooden skins in female moulds but with a foam core blown inside them. I don't know what sort of moulds they use but for them, compound curves aren't a problem.
Shedofdread is offline Find More Posts by Shedofdread
Old Jan 29, 2013, 05:48 PM
Joined Jan 2013
I really appreciate all of your comments.
Thank you
Old Jan 29, 2013, 11:37 PM
prodjx's Avatar
Joined Jan 2007
The Enigma DLG come's to mind and it used thin balsa as a sandwich of Glass balsa glass and then bagged. This process goes away's back with bladder molded fuses for Locheed and DeHaviland aircraft. So there's alot of info out there I'm sure and here on the group's.
prodjx is offline Find More Posts by prodjx
Old Jan 30, 2013, 04:08 PM
Joined Jan 2013
I will check that out, thank you
Old Jan 30, 2013, 04:41 PM
Arrarrar!
josh18's Avatar
Australia, VIC, Williamstown
Joined Jan 2010
Hey Brady, moulds don't need to be expensive. There are heaps of threads around on how to make moulds on the cheap. Research mould making out of poliester resin and chopped strand mat- super cheap and how most larger scale moulds are made I think. You can even make moulds out of plaster if you like but I dont think you will get many parts out of them.
Good luck with it.
Josh
josh18 is offline Find More Posts by josh18
Old Jan 30, 2013, 08:32 PM
prodjx's Avatar
Joined Jan 2007
Bagging carbon-wood-carbon would work out a little cheaper than just carbon. It's a variation on carbon-glass-carbon where you can get atleast 85% of the strength of a solid carbon lay-up at less cost. Also you alway's want to bag carbon lay-up's as opposed to just a contract lay-up. You want to wick out as much excess resin as possible before bagging too.
Discussion Wanted ideas of a product or a product to sell me camaroz28325 Aerial Photography 5 Jan 26, 2009 11:05 AM
Great idea for a new digicam related product JensJakob Life, The Universe, and Politics 2 May 23, 2002 06:52 AM
Gws+idea=new Products? Bleriot Parkflyers 2 May 06, 2002 12:25 PM
Product idea - Endpoint adjustor / ATV dgoebel Power Systems 2 Jun 27, 2001 03:41 PM
Product idea - ATV/Endpoint adjuster dgoebel Electric Plane Talk 0 Jun 26, 2001 08:38 PM
