Old Jan 28, 2013, 04:23 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
Question
Large hydro electric power ?
I have built 6 of these. They weigh 4 .5 pounds with the top skins off. Should add no more than 1/2 pound covered & varnished.
I want to let people use them with NON - expensive motors. How many watts & what motors & props would plane it ?
Thank you.
Rich
cyclops2 is offline Find More Posts by cyclops2
Old Jan 28, 2013, 06:51 PM
mozzyrocks is offline
Find More Posts by mozzyrocks
Australia, VIC, Blackburn North
Joined Feb 2011
Cost is all relevant to quality.
If you want rubbish then you pay peanuts.
However, there are some very cheap brushless setups available from Hobbyking.
I'd go with something in the 1000-1500kv on 4-5S with a 100A ESC.
mozzyrocks is offline Find More Posts by mozzyrocks
Old Jan 28, 2013, 07:58 PM
zozer is offline
Find More Posts by zozer
Steps? What steps?
zozer's Avatar
United States, TX, Humble
Joined Jan 2010
Geeze, throw us a bone guy. How long and wide is the hull? How wide is the tunnel? What is the speed goal? Run time length?
zozer is offline Find More Posts by zozer
Old Jan 28, 2013, 10:01 PM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
Seems to be a 45" x 20" hull. Nice & light though.
If it were mine, I'd try the TP Power 4092 1350kv on 6s. Only $100.00 for a good motor. From my experience, they are better than the Leopards.
http://kershawdesigns.com/TPPower.htm
A Swordfish or Turnigy 240 12s ESC. The ESC is always going to be the most expensive part if you want reliability.
Props, for me, would be starting with the m645, or the, ABC H5, Then the m447, working up to the X447/3 if the temps are good.
There will be other suggestions coming along soon, I'm sure.
785boats is offline Find More Posts by 785boats
Old Jan 29, 2013, 12:59 PM
JimClark is offline
Find More Posts by JimClark
JimClark's Avatar
United States, WA, Seattle
Joined Apr 2002
Scorpion 4035-800 look here for more info http://scalehydro.com/home
JimClark is offline Find More Posts by JimClark
Old Jan 29, 2013, 06:24 PM
cyclops2 is offline
Joined Mar 2003
I had bought the planes from the Scale Hydro Museum in Washington ?
Retired & finally finishing the 6 boats up. I Do lots of RC electric planes.
Did the 8' WWII PTB with a Novak Reversing Super Rooster ESC & a car battery.
But this size was just skipped by me. Thanks for the 4035 800KV motor .
What prop diameter & pitch is average ?
I have used the Octura props & drives in another smaller boat
Old Jan 29, 2013, 10:50 PM
JimClark is offline
JimClark's Avatar
Joined Apr 2002
they use a 57mm Graupner Series 2317 prop. I wasn't aware the Hydro Museum sells anything that big
Old Jan 30, 2013, 06:41 AM
cyclops2 is offline
Joined Mar 2003
Hi Jim.
Maybe when it first opened ? They had tons of plans when I ordered.
This is what my boat will be. Always did like the side pipes.
Old Jan 30, 2013, 02:26 PM
JimClark is offline
JimClark's Avatar
Joined Apr 2002
Ah so you just bought plan's. Must have been Newton Marine plans
Old Jan 30, 2013, 07:19 PM
cyclops2 is offline
Joined Mar 2003
BINGO ! Jim.
I could not remember. The plans are EXACTLY perfect.. Everything lined up very easily.
Rich
Old Feb 02, 2013, 02:28 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
So Rich what are the actual dimensions of the hydro LxW?
Amp Abuser is online now Find More Posts by Amp Abuser
Old Feb 02, 2013, 09:54 PM
cyclops2 is offline
Joined Mar 2003
They are 45" long x 20" wide.
Old Feb 03, 2013, 10:06 AM
zozer is offline
Steps? What steps?
zozer's Avatar
Joined Jan 2010
That boat is awfully large for a 4092 motor on 6S. Hydros this size take more power to plane off than do monos and cats. Most boats that size use 8S or 10S and a larger format motor. And a 45mm prop is a joke, I doubt it would plane a boat that size - normal diameters for 40"+ boats start at 57mm and go up to 70mm. Don't make the mistake of buying too cheap, then having to replace everything because it didn't work. Buying twice is an expensive lesson. Please listen to those who have actually built and run these large hulls, not guesses from those who are trying to be helpful but get it wrong.
If it were my boat (and I've built and raced FE boats up to 45") and I wanted to build on the "cheap", this is as cheap as I'd go:
Motor: Leopard 5692/730 (cheaper than the Scorpion and easier to cool)
ESC: Swordfish Pro 240HV or Castle ICE200HV
Batteries: 8S/2P/5000mAh packs with a minimum of 40C discharge rate
Prop: Octura x462 to x465
In my experience this setup should give reasonable reliability for the cost and will run the boat well. But an 1/8 scale 8S hydro is not the boat for the new-to-FE boater! Do not make this your first FE build. Start with an AquaCraft Revolt or UL-1 first. You will make mistakes which in the small boat will not cause much damage. In an 8S boat, the same mistake will cost a lot of $$$. Trust me, I have seen it happen at least ten times.
The above setup will run in the mid-50s, which is plenty for these hulls. There are three 1/8 scale round-nosed hydros in my club (one was built by Roger Newton himself) and they run great in that speed window. Much faster and they tend to blow off - no surprise, the originals did too. 55 mph translates to over 150 mph scale speed, right where the originals ran topped out. Have fun!
Here is what happens if you try to push the big boats too fast.
Old Feb 04, 2013, 10:02 AM
cyclops2 is offline
Joined Mar 2003
Thank you zozer.
I did not realize big electrics need HUGE wallets times the 6 boats....
I will go to the gasoline engine. Larger weed wackers on sale.
Thank you
Rich
Old Feb 04, 2013, 01:26 PM
cyclops2 is offline
Joined Mar 2003
I took a chance on a battery powered chainsaw motor for $25 as a test. At 20 volts & 2 speeds of 2.6 amps & 5.2 amps. What the heck. Seeing as how they are overloaded all the time. I will try it out.
Discussion Power system with large prop to give maximum free air to operate in Nereth Power Systems 10 Jan 27, 2013 06:10 AM
Sold Large Electric Retracts bruff Aircraft - General - Miscellaneous (FS/W) 1 Jan 23, 2013 11:39 AM
Two dlg kits for large electric sailplane rcbobcat55 Non R/C Items (FS/W) 0 Jan 04, 2013 08:40 PM
Discussion Exceed racing 49" hydro gas powered transformation to electric easy? kwjimbo06 Racing Boats - Electric 4 Nov 14, 2012 06:32 AM
Large, high-power/performance electric gliders ShredAir Electric Sailplanes 5 Jul 08, 2001 02:39 PM
