,, we spent a few hours helicoiling and making sure everything was safe.. a few days later he got rear ended and it went to the junk yard. I guess his dad is still mad because I see him walking a lot .. |
you know you've done a good job when the tech comes out from under ur car with a smile and screams to his buddy "Its all new!"
The shop manager was an ass & kicked me out of the garage but i explained to the store manager I was just curious about the process and he walked me back out.. I'm surprised how close i got it with the old parts and a tape measure
We have the BIG hunter, it will hold a flatbed car hauler... but the part in front of the lift is all the same... A little overboard on the toe in when you put it together...
I swapped out the motor in the 1999 Super Charged Buick Regal and did the front end while I had it apart(Subframe out and on the ground.)... It came off my rack went round the block for the test drive and on to the alignment rack where another tech dragged me over to a near perfect alignment without making any adjustments... I used a level and a tape measure. No adjustments were made. I had put on 4 new tires while it was in, the old motor was a leaker and the control arm rubber parts were bad from being saturated. Since I routinely drive this car at 80mph I like the front end to be nice. |
Latest blog entry: Latest things....
Total came out to $287 Not bad for a set of tires, but I still felt conned and haven't been to a Sears auto service since 1986. |
United States, LA, New Orleans
Joined Dec 2012
Hey Usta, is there a text to go with the picture?
Looks like a late 50s early 60s Formula Jr. or Formula III car set up for minimum traction on motor cycle tires(oops-Tyres) to slide around. This would be a set up for gymkhana events. The Brits are heavy into this, not as much as there was over here at one time. Last one I participated in we added a twist to the event,.Blind folded the drivers! We did require a navigator requiring 2 seat minimum carsThe Chassis is unidentifiable by me. could be a butchered OSCA or remotely a Lotus 18. These things were coming out of every where. All it took was a few bucks of tubing, a torch and rod of choice and several days to build a chassis to fit what ever legal engine and gearbox was laying around And another week to fit and hang components and suspension while someone was wheeling the aluminum body work. 2 weeks of work had you on the track ![]() Other than the big guys rarely was any design work done, chalk lines on the floor sometimes. Alejandro De Tomaso was know for having built his cars on sawhorses in the pig pen behind his fathers shop! Those were the day my friend! . |
I got a question for you car guy's. My wife has a 2010 Scion XB and the GoodYear tires that came on it wore out in 32K miles so I put some Michelin's on it. It drives perfectly straight but for some reason the outside edge of the tires are chewing up. I took it to the local shop to get an alignment and they said the toe was out. They adjusted it to spec. I had them rotate the back tires up front that showed none of the edge wear but they are now chewing up on the outside edge just like before the alignment. So I took it back in and they checked it again but said it was still in spec. Any advice would be appreciated.
Sorry to high jack the thread
![]() I saw one from Walmart where they managed to crack an aluminum pan. On the bright side Walmart pays it's repair bills in a timely manner.
Joined Dec 2012
All mention of caster should be in the negative. Starting with this post, I will correct self. Not sure what a Scion is. Toyota? Dampers and springs in good shape? No worn parts? Stock ride height? Did the Goodyear wear this way also? Goodrich T/As is the way to go. They stay balanced, carcass never separate from the belts(nylon belts) and for what ever reason flats are extremely rare. Their soft compound life span is short and 99% of drivers have no clue what to do with that level of available grip. Ware rating indicates this. Right now the Miata has some brand I don't remember but at the time was the hardest compound I could find, the wife is happy and even if I go out to have fun in the car it is livable. Bridgestone has some very good tires, possibly better than the BFGs for traction don't know about wear life. Same for Yokohama and several others. My opinion of Goodyear and Michelin is they do have a good advertising department. Firestone as well. Dampers and springs in good shape? No worn parts? Stock ride height? Add - camber if this is from straight line wear. Add + Caster if its only in corners. To much toe in can do this as well. How to tell which one in street driving conditions? Might have her drive it slowly in as tight a circle as possible while you walk, run beside the car. see if it seem to run up on the outer edge. Also look from static position might be able to tell. Or have her drive is in circle for 2-3 minutes and then check outer and inner tread temp with an infra red temp gun. Harbor freight has a decent and apparently accurate one. The inside should be 10-15deg hotter than outside. 5 deg difference in the reading should be ok. I found the Chevy Pick ups and Suburbans do much better and drive better when set to negative camber. The book calls for positive and the outsides wear fast. There are more conditions that can cause this sort of thing, an example could be 10" wide rims and tires for a geometry designed to handle 6" max widths. Good luck! |
Joined Dec 2012
Come to think about it I no longer allow anyone but me or my son who learned from me to touch anything on any of our vehicles. That's 11 street legal and 5 formula cars. Every now and the I have to learn a new computer system but that's not often. I don't care who it is when I have tires mounted part of the deal is I tighten the lug nuts or else where I go. ![]() I started noticing that every time I bought tires a few days later the front rotors would develop enough run out to be a problem. This happens from the uneven stress from those impacts slamming one lug nut home at a time, then get them good and hot stopping a time or 2 and we now have a nice set of warped rotors. ![]() Then have to pull and turn them. Have several brake laths so no real problem to do but just a pain plus might as well clean and pack bearings..... ![]() ![]() Now days I bring the torque wrench and do it in a cross pattern in at least 3 passes coming up to the spec for application. No more warped rotors and if the rim/tire needs to come back off I don't need a 40ft cheater pipe. ![]() Why I own all my own machinery , set up rig tubing benders and welding stuff and all else sorts of related stuff except a crankgrinding machine. Has gotten to where every place seems to screw stuff up. Had Craig Taylor at Taylor racing in Plano Tx. re-case a Hewland gear box. Craig and I raced in the same class so we were/are friends and while we B.S. his man is doing the job. And has trouble getting the rear bearing carrier to home up all the way. Before I could stop him to pull it back down an see whats the matter he smacked it with a rubber mallet. Ah there it is he say. I say what popped? Oh that's normal. me, thats B.S. This part is part of a chassis adjustment through being able to change any gears ratio in abot 15min at the track. we haul around over 50 different ratios when racing, so I had done this part 100s of times before. Got it home a tore it down. The rear bearing carrier was cracked between the upper and lower bore, that took a day of heliarcing and and clean up finally finished off with a bearing scraper. Now on to what went wrong. The bearing bore fro the input end was not flared enough to clear the shaft. Dremel tool took care of that part. This is why I own Hewland set up jigs! ![]()
| Thread Tools | |
| Alert Member scamming buyers... | Randy Shaw | Trader Talk | 121 | Jan 11, 2013 08:18 PM |
| Sold New 33% Hanger 9 wheel pants and 4" dubro wheels $30 Shipped | ddllzzrr | Aircraft - General - Miscellaneous (FS/W) | 2 | Jan 09, 2013 08:12 PM |
| Sold Wheels, Wheels, Wheels | tonealone | Aircraft - General - Miscellaneous (FS/W) | 6 | Jan 09, 2013 06:10 AM |
| Discussion Would you scam a scammer who scammed someone else? | flyer368 | Trader Talk | 5 | Sep 03, 2010 02:45 PM |
| Alert Scam Scam Scam! | Ionredline0260 | Car Talk | 3 | Jun 24, 2006 05:54 AM |
