Old Jan 28, 2013, 06:50 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Ha, I will give you that! My wife sets here alignment everyday.....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Jan 28, 2013, 07:07 PM
splatman is offline
Find More Posts by splatman
Vertical Wake
splatman's Avatar
visalia ca
Joined Dec 2002
Money well-spent, especially if you've done front end work. It's just not cost-effective to buy a new Hunter alignment rack! A car can go perfectly straight done the road and be severely out-of-alignment. The first clue is when you wear out front tires in half the time. At the cost of tires nowadays, it's too big of a chance. Some shops offer the no-adjustment= no charge (with a print out shows specs, adjustments made, etc.)
splatman is offline Find More Posts by splatman
Old Jan 28, 2013, 07:14 PM
saltyzoo is offline
Find More Posts by saltyzoo
saltyzoo's Avatar
United States, FL, Tampa
Joined May 2008
Originally Posted by bildo baggins View Post
Not as big of a scam as headlight alignment
I'll call you on that and raise you a "nitrogen fill".
saltyzoo is offline Find More Posts by saltyzoo
Old Jan 28, 2013, 07:18 PM
n00b-E is offline
Find More Posts by n00b-E
n00b-E's Avatar
Joined Sep 2007
Oh my gosh, dont even get me started on that racquet.
n00b-E is offline Find More Posts by n00b-E
Old Jan 28, 2013, 07:20 PM
RCWorks is offline
Find More Posts by RCWorks
RCWorks's Avatar
Joined Aug 2003
Originally Posted by Usta Bee View Post
I had the same basic GM A-body car, a 71 Skylark.
Re-did the front suspension myself when I was around 22 or so.
New lower ball joints, new bushings, new tie rods, new shocks, and new sway bar links and bushings.
Took the lower A-arms out the whole way, removed the ball joints with a sledgehammer, and a friend of my dad pressed the new ball joints into the A-arms with a small hydraulic press and a deepwell socket
I have a balljoint press, I can change the joints without removing the control arms. The book pays 2.4 hours a side.
I can do it in 90 minutes per side... While I get book to do the job, I can mak 4.8 hours in about 3 hours maybe less. I have been at it 32 years I have a few shortcuts...
RCWorks is offline Find More Posts by RCWorks
Old Jan 28, 2013, 07:28 PM
56S is online now
56S
Find More Posts by 56S
56S
Certified Balsa Breaker
56S's Avatar
Joined Nov 2006
I use a "Mixed gas" in my tires. Mostly nitrogen, then oxygen with a little greenhouse gas mixed in.
56S is online now Find More Posts by 56S
Old Jan 28, 2013, 07:36 PM
Usta Bee is offline
Find More Posts by Usta Bee
Closed Account
Joined Jul 2004
How long would it take you to replace the front struts on a car and reuse the old springs on the new struts ?.
Usta Bee is offline Find More Posts by Usta Bee
Old Jan 28, 2013, 07:42 PM
Wrench is offline
Find More Posts by Wrench
Wrench's Avatar
Joined Dec 2004
Never reuse the springs, replace it all if you're going to replace the struts. They make "Quick struts" that are reasonably price and install quickly.
RC which BJ press do you have? I have the snappy unit, it's sweet. I waited years before I bought an A frame bushing press, wish I'd done it years ago.
Wrench is offline Find More Posts by Wrench
Old Jan 28, 2013, 07:46 PM
RCWorks is offline
RCWorks's Avatar
Joined Aug 2003
Depending on the car 30 minutes to 1 hour... thats both sides. I have a pnumatic strut compressor... Getting the strut out and changed is easy, sometimes the holes don't want to line up on the top of the steering knuckle and that sometimes slows the process sometimes. (The lower control arm bushings and swaybar can add to the force needed for getting them back in...
Old Jan 28, 2013, 07:48 PM
RCWorks is offline
RCWorks's Avatar
Joined Aug 2003
Snap-on...
Old Jan 28, 2013, 07:51 PM
RCWorks is offline
RCWorks's Avatar
Joined Aug 2003
I have gotten a bit upset with snap-on lately... I have had replacement tools that look like Stanley... I don't think they were made HERE. This was a 3/8 ratchet and a 1/4 inch ratchet..
Old Jan 28, 2013, 08:04 PM
saltyzoo is offline
saltyzoo's Avatar
Joined May 2008
That probably costs a fortune to make.
Old Jan 28, 2013, 08:10 PM
fh64_lucky's Avatar
Joined May 2005
I shot a strut spring out of the fixture years ago, think it was a cadillac strut, didnt quite fit the press....boy thats 1 spring you dont want flying around the shop! Still got all my front end tools in garage collecting dust....been years since I pulled them out, they will prolly never be used agian, I dont work on my cars anymore, no patience left after working on heavy equipment over the years
Old Jan 28, 2013, 08:16 PM
56S is online now
56S
56S
56S's Avatar
Joined Nov 2006
Old Jan 28, 2013, 09:36 PM
Skrogg is offline
Find More Posts by Skrogg
Balsa is for doll houses
Skrogg's Avatar
Texas, San Antonio
Joined Aug 2004
I don't either but this car is special to me ,, I enjoy working on it ..
A chevy impalaSS chase on the highway u MUST SEE! (5 min 11 sec)
Skrogg is offline Find More Posts by Skrogg
Alert Member scamming buyers... Randy Shaw Trader Talk 121 Jan 11, 2013 08:18 PM
Sold New 33% Hanger 9 wheel pants and 4" dubro wheels $30 Shipped ddllzzrr Aircraft - General - Miscellaneous (FS/W) 2 Jan 09, 2013 08:12 PM
Sold Wheels, Wheels, Wheels tonealone Aircraft - General - Miscellaneous (FS/W) 6 Jan 09, 2013 06:10 AM
Discussion Would you scam a scammer who scammed someone else? flyer368 Trader Talk 5 Sep 03, 2010 02:45 PM
Alert Scam Scam Scam! Ionredline0260 Car Talk 3 Jun 24, 2006 05:54 AM
