Old Jan 30, 2013, 05:44 PM
ian murdock is offline
Find More Posts by ian murdock
ian murdock's Avatar
United States, NV, Carson City
Joined Jan 2007
Its Nevada there's always wind.
ian murdock is offline Find More Posts by ian murdock
Old Feb 02, 2013, 08:52 PM
1000MPH is offline
Find More Posts by 1000MPH
Objects in mirror are losing
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
The Dayton spot was a bust, it was covered in 10 ft tall junipers. On the plus side it was biggger than it looked on GE. We did find a couple more places that could be fun. Nothing epic.
1000MPH is offline Find More Posts by 1000MPH
Old Feb 05, 2013, 02:53 AM
jonoashton is offline
Find More Posts by jonoashton
jonoashton's Avatar
New Zealand, Wellington, Porirua
Joined May 2006
I am currently building a JW and wondered whether to hinge the elevons from the bottom or the top. I usually do the top because it looks better but is either way better than the other???
jonoashton is offline Find More Posts by jonoashton
Old Feb 05, 2013, 06:05 AM
Aerogance is offline
Find More Posts by Aerogance
Anyone can build! It's fun!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
You can use shorter horns if you bottom hinge ( assuming top drive ).
Aerogance is offline Find More Posts by Aerogance
Old Feb 05, 2013, 09:01 AM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
I like bottom hinged for the reason Aaron mentioned and Peter Wick recommends bottom hinging on planks.
IMO, the quality of the hinge is more important than location.
Old Feb 05, 2013, 09:19 AM
criterium1 is offline
Find More Posts by criterium1
Joined Jul 2011
should the JW elevons be hingned the way they are called out on instructions?
top and bottom?
remember this is a ds machine.........
aDSj
criterium1 is offline Find More Posts by criterium1
Old Feb 05, 2013, 11:44 AM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
I think jonoashton is asking about the location of the hinge pivot point, not the construction of the hinge.
IMO, the best hinge for a JW is 3 sets of tension hinges followed by a full length compression hinge.
The compression hinge only gives too much.
Repost..."Tension hinge/Z hinge/over-under, whatever you want to call them, will really lock in the position of your elevon, up/down, fore/aft, and help to establish the perfect hinge line. A compression hinge alone is difficult to make accurately and doesn't lock it in.
Do a search for tension hinge and you will find some good pics and diagrams.
here are some links...
golden advice from Daemon...
http://www.rcgroups.com/forums/showt...0#post20527330
http://www.rcgroups.com/forums/showt...0#post15686784
and some pics...
http://www.rcgroups.com/forums/showt...0#post15075801"
Old Feb 05, 2013, 09:25 PM
Aerogance's Avatar
Joined Sep 2008
Here is a sketch I made for the Mako. If you flip it upside down, it will work for bottom hinged surfaces. If you "wrap" the hinge line prior to applying the tape hinge, you won't need to do the tension hinge treatment. The straight piece of hinge tape maintains the tension while the per-wrap keeps the monokote from peeling at the hinge line during heavy use.
PDF here:
http://www.rcgroups.com/forums/showa...mentid=2880950
Old Feb 06, 2013, 03:24 AM
jonoashton's Avatar
Joined May 2006
Yep, you are correct. I was just wanting to know if the pivot point should be top or bottom. It looks like the general consensus is the bottom so that is what I will do.
Given that the wing trailing edge is carbon and the elevons are carbon as well (bagged), I was considering doing silicon hinges. Anyone tried silicon hinges on a foamie before?
Jono
Old Feb 06, 2013, 07:30 AM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Gregg's Gulp had silicone hinges...and it flew okay
http://www.rcgroups.com/forums/showthread.php?t=1572018
Old Feb 07, 2013, 01:53 AM
radacl69 is offline
Find More Posts by radacl69
New Zealand, Canterbury, Christchurch
Joined Mar 2012
I just recently bottom hinged my JW60, BEST THINK I COULDVE DONE TO IT. Made it way easier to get a good servo resolution off a top drive set up. Good Luck with the hingeing, ive used Alexs secret Ultra Clear Tape and has worked out super solid.
radacl69 is offline Find More Posts by radacl69
Old Feb 08, 2013, 07:36 AM
Joined Jan 2007
Hey guys got my JW kit in the mail yesterday!!! Now for another question, how to build the wing. I have been looking at build logs all week but they don't tell you which side to lay down on the beds so the other side has a di-hedral. I'm thinking it is the top surface that needs to be in the beds when gluing in the spars. Should be a fun build.
Old Feb 08, 2013, 09:14 AM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
You didn't get instructions?
Old Feb 08, 2013, 09:26 AM
Joined Jan 2007
Nope
Old Feb 09, 2013, 04:23 PM
1000MPH is offline
1000MPH's Avatar
USA, NV, Reno
Joined May 2003
Servos:
I use the servo wheels instead of the arms. I grind them down until they look like the pic. The clevis will need to be ground down to clear the hub. I usually grind the clevis about halfway, this allows about 90-95% of max servo throw. More than enough.
As you can see from the pics this setup is barely taller than the servo and will fit nicely in the JW wing. Don't forget the screws and NO threadLock on Karbonite!!!
Discussion Couple new additions - Stout JW60 and Light XR infopimp Slope 6 Jun 25, 2006 09:52 AM
Discussion Bowman JW60-VE2, Electric Twin Conversion dkimball Foamies (Kits) 5 Jun 03, 2006 02:55 PM
Discussion Finally trying to post some pics, JW60 Tehachapi Jim Slope 6 Mar 03, 2006 12:44 PM
Just ordered a JW60.. Couple Q's... THUREN Slope 55 Jan 10, 2006 02:49 PM
JW60 with or without ballast, advice wanted GLIDERGIDER Slope 7 Nov 22, 2004 06:33 PM
