Old Jan 27, 2013, 09:32 PM
old4570 is offline
Find More Posts by old4570
Australia, VIC
Joined Dec 2011
450 Basics [ stuff you need ]
Wow - so what do you need to fly a 450 .. Since this is posted in the beginner section of the forum , I will assume Noobness ...
First you need your heli and radio [ I will assume RTF to speed things along ] , and RTF can be had from $125 or so shipped to your door . [ Depending on where in the world you are ]
The first thing I would recommend is a Charger , iMAX B6 [ Can be had from about $19 ] , power supply [ $10 ] , maybe a Parallel charging board ? [ $9 if you want to charge more than one battery at a time ] A B6 with a built in power supply will start around $34
Batteries ? one is not enough ...
Tools = Hex drivers 1.5mm / 2mm / 2.5mm / 3mm [ you want 2 x 1.5mm ]
Pliers , standard and ball link , $5 each
Zip ties ...
Screw drivers [ phillips ]
Heli spares :
Hmmm , well , just depends on what your breaking ..
Main drive gear
Main rotor shaft
Feathering shaft [ make sure you get the right ones ]
Tail rotor shaft
Tail boom
Oh yeah - Rotor Blades ...
Servos [ I really like the TG9e from HK , cheap and good , a rare combo ]
Frame screws [ one bag should be enough ]
If you can live with one helicopter you wont need so many spares [ maybe ] , pictured is my nick nack boxes , the small stuff ..
Screws , motor mounts , feathering shafts , main shafts , tail rotor shafts , and so forth .. The more I got in , the more parts I needed , the deeper I got ..
At one time it took almost 2 months to get rotor blades out of China , local blades cost like $15 or more for a single pair , now I carry a few pair , well eeer , Im not sure ... Let me check ... Yikes , maybe more than your local hobby shop .. Thing is , I dont want to wait for spares .. Id rather get to one or two spares and order more than not have any .. I might go a month now without breaking anything , and suddenly there is a oops moment , and you need new rotor blades , feathering shaft , main rotor shaft and maybe a servo or three ..
A really huge oops might see you replacing 50% of your bird ..
Do you twiddle your thumbs for a month waiting for parts , or do you sit down , repair the heli and kick yourself for doing something silly and keep flying ?
Anyhow , parts , how much etc is very personal , but you should keep some , especially the more common parts that are bent or broken ..
Main drive gear , main rotor shaft and feathering shaft , these 3 things are probably the most common to go , with servos next ..
Thing is , once you carry spares - youl break something you dont have - Murphys Law ...
old4570 is offline Find More Posts by old4570
Old Jan 30, 2013, 10:06 AM
GooberSB is offline
Find More Posts by GooberSB
An Ordinary User
United States, VA, Fluvanna
Joined Jan 2011
I keep my spare parts in boxes now. I have spare servos (when you get your cyclic servos order 4 because when one strips you will end up replacing all 3 if you cannot get the exact same one to replace it).
Also, keep 5-10 flybars in stock. I bend them during transportation to a flying site or back home sometimes since I don't have a carrying case for all of my 450 helis.
QC on the cheap main shafts is pretty bad. Expect some to be slightly bent.
Not only 2 short 1.5mm hex drivers but also a long one.
A magnetic parts tray for holding those tiny screws and washers.
A couple of drive belts. They stretch and have to be replaced eventually.
A spare set of tail blades in case of a tail strike on the pavement. I have hit little pebbles while landing in the grass or on cement sidewalks with pebbles in the concrete.
GooberSB is offline Find More Posts by GooberSB
Question If you wish to charge the included battery from an AC power source, you will need the mikeydrc United Kingdom 5 Jan 28, 2013 04:52 PM
Sold Cleaning out stuff I don't need. Airplane stuff Ifly101 Non R/C Items (FS/W) 4 Jan 27, 2013 06:32 AM
Sold (Last re-list, Reduced) Basically Brand New TREX 450 Sport BNF $315 Shipped nautique Aircraft - Electric - Helis (FS/W) 2 Jan 09, 2013 12:35 AM
Sold (Reduced) Basically Brand New TREX 450 Sport BNF $325 Shipped nautique Aircraft - Electric - Helis (FS/W) 0 Jan 02, 2013 01:13 PM
Basic 3dx stuff, what I need. lift off Foamies (Kits) 1 Aug 12, 2004 03:33 PM
