Old Feb 06, 2013, 01:59 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
If I understand you correctly, yes. Once the 2 halfs are joined together, from the root cord it will be cut back, to square off the LE. for mounting. Don't have the amount handy, right now, but about 3.5" . Squared to where it meets saddle. I don't have everything written down, a lot of it is in my head! My dad, brother and I, have the ability to design stuff in our heads, and it comes out just as we planned! Most of the time!!
Need to get wing built first so I can get the saddle correct, then "relieve" some foam to accomodate the intakes. I had thought about this before hand. Will have 2- 1/8" 6-ply spars, front and rear..Once the entire wing is done , LE, TE, tips, hinges, servo and gear bays cut out, etc. it will be completly glassed.I also took into account, that all 3 Scorpion model are composite fuses, the 2 bigger, turbine versions have plug in wings. The E vesion has the one piece wing, so it has to be strong, to tie it all together. Never done a foamy before, don't want it to "fold" in half.
Only when I think the fuse meets my personal expectations, if not it's a do over, will the entire fuse be glassed!
At least that's the plan.
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Feb 06, 2013, 06:16 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
[QUOTE=CoolerByTheLake;24048742]If I understand you correctly, yes. Once the 2 halfs are joined together, from the root cord it will be cut back, to square off the LE. for mounting. Don't have the amount handy, right now, but about 3.5" . Squared to where it meets saddle. I don't have everything written down, a lot of it is in my head! My dad, brother and I, have the ability to design stuff in our heads, and it comes out just as we planned! Most of the time!!
The above is what's known as the"head cad"design system.Free to all users
Stuart A is offline Find More Posts by Stuart A
Old Feb 06, 2013, 08:17 AM
Joined Dec 2008
Originally Posted by Stupot46 View Post
The above is what's known as the "head cad" design system.Free to all users
Never thought of it that way. The difference between the other "CAD" and the "head cad" design system, try as they might, not everyone can do it!
Old Feb 06, 2013, 11:14 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
Scorpion CG
here's the CG I get for the Scorpion. I've left yours on the pic for reference. i doubt you'll go far wrong by using either. I would use yours as your most forward position and mine for your mid position. if you wanna get a bit wilder, you could move slightly more reawards. depends how stable you want your plane to be.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 06, 2013, 11:15 PM
Joined Jan 2009
forgot to add........................my CG is the blue line, which I'm sure you'd figure out without me saying anything, but there ya go. LOL.
Old Feb 06, 2013, 11:28 PM
Joined Dec 2008
Thanks Rich, Hope you can figure out the explaination on the method I used, in the PM I sent.
Old Feb 06, 2013, 11:29 PM
Joined Jan 2009
I'll figure it out if you can send me exact dimensions of the wing. just one side is enough.
Old Feb 07, 2013, 12:19 AM
Joined Jan 2009
new CG pic
here's the one you just sent me.
Old Feb 07, 2013, 12:26 AM
Joined Dec 2008
I will get you all the numbers you need tomorrow. Thanks a bunch, turns out harder than I thought.
Old Feb 07, 2013, 12:30 AM
Joined Jan 2009
forgot to ask.......................flaps or no flaps on your model?
we have a turbine Scorpion at our field. what an amazing flying airplane it is. and deceivingly fast too.
Old Feb 07, 2013, 02:07 AM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
This is 25% wing MAC.
Are you going to figure in where the NP is with the tail? The NP will change then you can the find where CG is (Static Margin).
p901P901 is offline Find More Posts by p901P901
Old Feb 07, 2013, 02:24 AM
Joined Dec 2008
It is so nice to have smart people like you and LuvEvolution7 to come to the rescue. I don't have a clue? I am working on getting all the measurements Rich asked for. I will PM you with numbers this afternoon.
Thanks for your help.
Mark
Old Feb 09, 2013, 03:08 PM
Joined Dec 2008
Still plugging away, getting things together. I want to have every thing in order before I start this. Lots of parts ordered, some of the wood/ply is special order, need the right stuff! But I thought I would share a few more photo's I just got today from my "source". Enjoy.
Old Feb 09, 2013, 10:56 PM
Joined Jan 2009
still plugging away at those numbers. if I get back early enough tomorrow, I'll have it done by tomorrow night. if not, it'll be Monday evening.
Old Mar 01, 2013, 09:43 PM
Joined Dec 2008
I guess it's about time for some kind of update, before this gets on the third page back!! I aquired my FFF and found it was a PITA to get the plastic backing off of. So in checking out the foamy scratch build forum I came across this foam: http://www.modelplanefoam.com/
looked like a whole lot better foam to work with. No plastic backing. no pin holes, and flat as a pancake, and ALL white. In the mean time I have been honing my skills trying to work out how to get some of the more complex curves and angles I want. It has been quite a learning experience.
Most of the stuff I ordered is here, servos, 6-ply plywood, of course the foam, and they just shipped all my fiberglass "stuff" today.
This going to be more difficult than I thought. Building it like a normal "park flyer" just won't work. They are all pushers, and for the most part have no room inside for all the EDF goodies, not to menton retracts. This will be truely a composite aircraft. foam, fiberglass, plywood, balsa and might even have a little CF to boot!!
Where I'm at now is still working out the best method of getting a "foam shell" strong enough to hold together while fiberglassing, and still retain all the shapes and angles. Sorry, no photos of my screw ups!!
I did have to modify the intakes some. You can see by the photo, that Aviation Design could have given more thought on the intakes. Way to big for a 90mm fan, and poor design to the fan from there. In some of the videos I have seen, there where comments made about its lack of speed, this may be some of the reason. I did consult AIR SALLY about this.
Enough for now, I hope to get on this pretty soon. Just a few things left to figure out.
2147
Discussion HELP me build a Quadcopter - Possibly the Turnigy Talon Quadcopter (V2.0) Carbon Fib JUCD VPR Multirotor Talk 17 Jul 09, 2014 04:01 PM
Discussion Seeking suggestions for next scratch build dglo Scale Kit/Scratch Built 29 Oct 29, 2013 08:12 PM
Question My next FPV build: wild questions Cobalt3000 Multirotor Talk 3 Jan 28, 2013 04:51 AM
Discussion Realized my mistakes, on the the next Tilt-Rotor build ilektron VTOLs 6 Jan 24, 2013 03:21 PM
