Old Jan 31, 2013, 11:01 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Great project Cooler. Looking forward to your progress.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Jan 31, 2013, 11:06 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Thanks Gary, You, know it will have the power!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 31, 2013, 11:25 PM
p901P901 is offline
Find More Posts by p901P901
p901P901's Avatar
United States, CA, Lancaster
Joined Jan 2009
How about honing years of experience into one package .
p901P901 is offline Find More Posts by p901P901
Old Feb 01, 2013, 12:29 AM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
you could also consider the MH series of airfoils. they would fit well in this application.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Feb 02, 2013, 04:35 PM
Lt599 is online now
Find More Posts by Lt599
Lt599's Avatar
United States, WA, Shelton
Joined Feb 2012
It looks like its going to be a fun build. I love the lines of this jet, will be watching the progress Greg
Lt599 is online now Find More Posts by Lt599
Old Feb 02, 2013, 05:28 PM
Joined Dec 2008
I think so too! Just trying to put together and finalize a "what I need to buy" list.
It just keeps getting bigger! Did run into one snag though, come to fine out the retracts I planned on using are not up to task. Waiting on a PM, on one's I inquired about.
I want to have most of the components "on hand" before I start. A couple of big ticket one's may have to wait a bit, like an ESC and batteries! AlthoughI see CC is coming out witha new line, so maybe there will be some deals on the older ICE models. Save a buck where and when you can. Out of curiousity, I had to see how it will look. The wing cores are over sized, and need to be cut down yet, that's why the rulers are in photo. LE will be on back side of them.
Happened to run across this last night. http://www.rcgroups.com/forums/showthread.php?t=1261890
Old Feb 03, 2013, 12:20 AM
Stuart A is offline
Find More Posts by Stuart A
You know nothing....
Stuart A's Avatar
Joined Sep 2011
Nice bench fly.You may need to beef that nose up a touch.........
Stuart A is offline Find More Posts by Stuart A
Old Feb 03, 2013, 01:53 AM
Joined Dec 2008
It is, looking a little "flimsy" at this time. The angle of the photo makes the T.E. of wing and stab, " appear closer than they are".
Thanks for checking in.
Old Feb 03, 2013, 06:28 AM
Stuart A is offline
Stuart A's Avatar
Joined Sep 2011
Some fool once said the camera never lies
Old Feb 03, 2013, 12:47 PM
CARL SCHIMNOWSKI is offline
Find More Posts by CARL SCHIMNOWSKI
Joined May 2007
Cooler
Which program did you use to draw out your airfoil. Thanks
Carl
CARL SCHIMNOWSKI is offline Find More Posts by CARL SCHIMNOWSKI
Old Feb 03, 2013, 01:02 PM
Joined Dec 2008
I just have the free Profili2 version. I did find out that you can modify the thickness of the airfoil. When you pull up airfoil Management, select Process and just play with it, see what you can do. Sometimes a window will come up and say you can't do this, just hit continue, may or may not work. For me it has all I need. Have Fun
Old Feb 03, 2013, 01:46 PM
Joined May 2007
Thanks I will try that. Im in Winnipeg Canada just north of Grand Forks, Hope it warms up
Old Feb 03, 2013, 02:19 PM
Joined Dec 2008
Yes, it's been cold here too. Getting tired of -20 in the early AM. Warm here now, 7 above, wild chill -13, but he suns out!! -14 for tonight. Tough on the heating bill.
Your just a stones throw away. Up nortt!
Old Feb 06, 2013, 12:37 AM
Joined Dec 2008
Not to much to show (visually), but lots of confirming measurments, etc.
If one can believe the IRS, my refund will in the bank Thurs. Let the ordering begin!! Have done some additional ground work, back in post #36, there was a link to a past E-Scorpion thread. I got a hold of one owners from original release, and he is going to send me some requested info. Should help a great deal.
I did make one purchase this week, some Spring Air main gear. Good to 15lbs!
Final choice on servos, Sorry JR's were not in the program.
HS-85MG+ Mighty Micro--Rudder's
Operating Speed (6.0V): 0.14sec/60° at no load
Stall Torque (6.0V): 48.6 oz/in. (3.5kg.cm)
Weight: 0.80oz (22.1g)
HS-225MG Mighty Mini--2-Aileron, 2-elevator, 1-steering
Operating Speed (6.0V): 0.11sec/60° at no load
Stall Torque (6.0V): 66.65 oz/in. (4.8kg.cm)
Weight: 1.10oz (31g
HS-645MG Ultra Torque-2-flaps
Operating Speed (6.0V): 0.20sec/60° at no load
Stall Torque (6.0V): 133.31 oz/in. (9.6kg.cm)
Weight: 1.94oz. (55.2g)
HS-81 Micro-Retract valve
Operating Speed (6.0V): 0.09sec/60° at no load
Stall Torque (6.0V): 41.66 oz/in. (3kg.cm)
Weight: 0.58oz (16.6g)
Total servo weight—11.56oz!
Did get to draw out projected ducting, this is to scale. The "D" in between, is intake shape. Figures out to be 3.54 sq in. just short of the needed 3.8sqin. Already have new one figured at 3.82sqin, close enough.
Need a trip to LHS, to order some 1/8" 6-ply plywood, perhaps a few other items from Bud Nosen. Good time of the year to buy it around here, cold and almost no humidity= no warping
Hang in there, this build might take awhile!
Old Feb 06, 2013, 01:32 AM
p901P901 is offline
p901P901's Avatar
Joined Jan 2009
Sounds like its a project .
Did you ever consider under cutting the wing that fits in the fuselage? The wing area around the ducts can be shaped and then reinforced. Then any airfoil could be used outside the fuselage profile.
Discussion HELP me build a Quadcopter - Possibly the Turnigy Talon Quadcopter (V2.0) Carbon Fib JUCD VPR Multirotor Talk 17 Jul 09, 2014 04:01 PM
Discussion Seeking suggestions for next scratch build dglo Scale Kit/Scratch Built 29 Oct 29, 2013 08:12 PM
Question My next FPV build: wild questions Cobalt3000 Multirotor Talk 3 Jan 28, 2013 04:51 AM
Discussion Realized my mistakes, on the the next Tilt-Rotor build ilektron VTOLs 6 Jan 24, 2013 03:21 PM
