Old Mar 06, 2013, 02:14 AM
isoaritfirst is offline
Find More Posts by isoaritfirst
isoaritfirst
isoaritfirst's Avatar
Not a Brummie/but close
Joined Sep 2005
Originally Posted by Lenny970 View Post
No, the AAA size is 800mah.
1500 is simply the number of cycles that the cells will supposedly deliver.
Cheers lenny , I had a quick look at AAA pack yesterday and made that same mistake.
At first thought it seems a strange way to market the cells, but I guess to most people capacity isn't much of an issue if you can just recharge as often as you like.
Bit different for us, where capacity and c rating are all important.
isoaritfirst is offline Find More Posts by isoaritfirst
Old Mar 06, 2013, 01:42 PM
Dyno Don is offline
Find More Posts by Dyno Don
Dyno Don's Avatar
United States, AZ, Surprise
Joined Jun 2003
What is the best rate to charge them at (2000 pk) ?
Dyno ..
Dyno Don is offline Find More Posts by Dyno Don
Old Mar 06, 2013, 02:16 PM
ttraver is offline
Find More Posts by ttraver
Team USA F3F Member
ttraver's Avatar
USA, CA, Carlsbad
Joined Feb 2011
Don,
I've been charging mine at 0.8A
t
ttraver is offline Find More Posts by ttraver
Old Mar 06, 2013, 02:29 PM
tomcat5109 is offline
Find More Posts by tomcat5109
tomcat5109's Avatar
USA, TX, Houston
Joined Mar 2004
I charge my 2000 mah AA rx (4 cell and 5 cell) and tx (8 cell) eneloop packs at .7 amp and cycle them down at .5 amp. The packs last very well at these rates. As insurance I replace the packs after 2 or 3 years. Then I disassemble them and clean up the cells and continue to use the cells in flashlights and other household things.
tomcat5109 is offline Find More Posts by tomcat5109
Old Mar 06, 2013, 02:32 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Recycling-
Reduce
Reuse
Recyle
Nice job reusing the cells in flashlights, TomCat!
R,
target
target is offline Find More Posts by target
Old Mar 15, 2013, 11:34 AM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
I have been charging as high as 1A on enloop cells for the last 3 years - not a single failure - I have 4 year old packs at 98% capacity still.
I typically charge at .8 but if I am in a rush ill bump it to 1.0A - I left a plane on overnight at the F3J contest in Phoenix (primary glider) and needed to put a charge on my pack fast - it did not heat up at 1.5 amps but I would not suggest this as a rule. IT did however peak at 1978 Mah which is pretty good!
webbsolution is offline Find More Posts by webbsolution
Old Mar 16, 2013, 10:55 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
1978ma into a pack in that situation doesn't tell you much, since you don't know the starting voltage. If it had been run down past normal bottom voltage, it could take MORE than the nominal rating.
I would cycle that pack if you haven't already to see where it really is. It could be fine, it could be that after leaving the battery on overnight, the pack was just depleted fully but not more. Cycling it should tell you.
Better safe than sorry, right?
R,
Target
Old Mar 17, 2013, 09:29 PM
Joined Jul 2007
Yup, when they gey home my packs get 3x cycled...all appear in the acceptable range so far.
Old Mar 18, 2013, 12:27 PM
ak79 is offline
Find More Posts by ak79
ak79's Avatar
United States, CA, Torrance
Joined Apr 2006
What voltage do life packs maintain, as in if you see it on the voltmeter you are ok? And what voltage is time to charge voltage? I've noticed my life pack stays around 6.3V
ak79 is offline Find More Posts by ak79
Old Mar 18, 2013, 09:13 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Mine are usually between 6.6 and 6.4 volts with the radio on.
SO HIGH! :-P
At 6.3, I would be looking to recharge.
R,
Target
Old Mar 19, 2013, 02:50 AM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Ali, try to charge the individual cells from current state and see how much each will take. I suspect either one of the cell is out of balance or just defective.
Here's a discharge curve for one of the hyperions Life @ .8A and an A123 @.5A, I've got tons more graphs if you need more .
fnnwizard is offline Find More Posts by fnnwizard
Old Mar 19, 2013, 08:36 AM
Kiesling is offline
Find More Posts by Kiesling
San Diego
Joined Aug 2004
Another thing to check is the calibration of what you are measuring the voltage with. If you are checking it with telemetry it may be off? I know some of the data logger's give different voltages compared to a real voltmeter. Something to consider . . .
Tom
Kiesling is offline Find More Posts by Kiesling
Old Mar 19, 2013, 04:00 PM
ak79 is offline
ak79's Avatar
Joined Apr 2006
I'm using just a normal hobbico volt meter. I don't have any Telemetry on the SD10.
Old Mar 19, 2013, 04:39 PM
Kiesling is offline
San Diego
Joined Aug 2004
Maybe you could borrow another voltmeter to see if it gives the same reading. Are you testing it under load? The reason I suspect the meter is that I would be surprised if the pack would stay at 6.3 for a long time - especially if it isn't under load. Tuan's graphs show the progression.
Does the pack cycle okay?
As a side note, it seems that the Hyperion packs like to be balanced charged every time they are charged. (I base this on the few packs I've seen people have trouble with were not always balance charged.) Not sure what cells you are using, but thought it is worth mentioning for anyone reading.
Tom
Old Mar 19, 2013, 04:58 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I haven't had much trouble with the hyperions in the planes going out of balance, but the 3 cell pack in my Tx is another matter.
I would say that I balance the Rx packs about every 6 charges or so.
I'm using the JR data logger to get the readings I'm getting (normally 6.6-6.5v) with the planes on.
R,
Target
Sold Or trade. Silly low price Image 2 M, V-tail, less rx. $345+ shipping TexasJohn Aircraft - Sailplanes (FS/W) 3 Feb 24, 2013 04:56 PM
Sold JR 11X updated to DSMX and Eneloop Battery HugoCraft Aircraft - General - Radio Equipment (FS/W) 2 Jan 21, 2013 12:18 PM
Sold New Eneloop 800 AAA Pack. epc2 Aircraft - Sailplanes (FS/W) 1 Jan 15, 2013 07:33 PM
Discussion NiMH internal impedance v aging/end-of-life deh6 Batteries and Chargers 6 Dec 19, 2007 05:18 PM
Life hits me hard - hate Polyurethane glue!!!v JensJakob68 Electric Plane Talk 6 Feb 19, 2002 01:12 AM
