Honestly Peter, I really don't think you need to change anything; Vic Smeed models were designed to FLY, and that is exactly what they all do, adding radio just makes sure you keep your model! Changing rigging, tailplane sections etc will just make them fly differently - not better. For proof of this look at the scores - hundreds - of Tomboy models being flown with radio now.
![]() Take the example of wing/tail incidence - Virtually all older FF designs (pre-bunt designs) have several degrees of wing/tail positive relative incidence. They were designed this way for a good reason; so that they would climb in a steep spiral under full (constant) power and then glide at a lower speed such that maximum lift to drag could be achieved. As we all experienced at one point in our FF careers (at least I did many times ), without enough rudder trim to keep it cork-screwing on the way up, it would loop over our heads, often sending us home with more pieces than we brought. In the content of RC control, where you'd like to fly in a straight line under power occasionally, you're pretty busy shoving various amounts of down elevator in with varying throttle settings when stock FF incidence settings are present. Reducing the wing/tail incidence reduces pilot work load under this common flight condition w/o measurably detracting from the low power/glide performance.John |
Northumberland, England
Joined Jan 2007
If the relative incidence of wing & tail is reduced then the cg would need to be moved rearwards (increasing pitch sensitivity) & a different range of motor/elevator would be needed this time with the model inclined to fly more like an average sports model than a vintage one. |
Perhaps all these comments are the answer of my problem with all the Junior 60s I have built, I don't know. The problem is that although carefully built as per plan with exact incidence angles CG, good amount of downthrust, the model always acts as tail heavy and I have to permanently apply down elevator, even when the motor has cut. (I use 3 channel propo) Solution? Increase sharply the positive incidence of the stabilizer. This has cured the problem. but why then in 1946 the original Junior 60 flew with the force arrangement shown on the plan? Comments welcome although I'm not talking of the Mam'selle. By the way, I fly at 3.000 meters elevation with a Chinese ASP .21 which is very reliable and powerful. Flying the Junior with smaller engines didn't help to solve the problem.
pat & Sun - Might I suggest an experiment --> take any of your current OT models with stock incidences and add a temporary shim under the TE of the wing so that you have 1~2 less positive incidence. No other changes. Fly it and let us know if you think it flew better or worse from a pilot workload standpoint.
John |
This is my last post on this point. John |
Joined Jan 2007
I always adjust the elevator & tweak the cg as necessary in the normal trimming process of any newly built OT model until it will fly hands off at low throttle. I've never yet changed the wing incidence or bothered to shim the tailplane seat. |
Joined Jan 2007
Edubarca, I've nearly finished re-furbing & electrifying a Junior 60. I don't want to hijack this thread so when the Jnr's complete I'll open a new thread & perhaps we can discuss it in some detail comparing it with your experiences.
BTW I'm at sea level - about 200 yards horizontaly & 50ft above as I type.
John; the last thing I wanted to do was start and argument, I was merely pointing out that I know how my models fly and hence know perfectly well what the effect of reducing the wing incidence would be. Obviously my set-up works for me on the dozen or more vintage/nostalgia F/F conversions I have set up this way, yours works for you, fair enough there are usually more ways than one of achieving something. The point I was trying to make is that there is no NEED to change the setting in 99% of cases unless the model is either over-powered or you want to achieve different flying characteristics which suit your flying style better.
With that I'll shut up and apologise to PeterH for hijacking his build thread, I am looking forward to seeing the Mam'selle take shape and wish you success with it Peter, whatever set up you use. |
| Thread Tools | |
| Discussion FF conversion - - Vic Smeed's Mam'selle | PeterH | Sport Planes | 5 | Jan 30, 2013 01:28 PM |
| Popsy by Vic Smeed | olmod | Vintage & Old-Timer Designs | 241 | Mar 26, 2011 01:23 PM |
| Build Log Vic Smeed Tomboy r/c electric | orange&white | Vintage & Old-Timer Designs | 63 | Mar 10, 2011 12:46 PM |
| Vic Smeed Likely Lass? | wingbeat | Vintage & Old-Timer Designs | 4 | Nov 12, 2005 09:02 AM |
| Vic Smeed 'chatterbox' plan on UK ebay. | vintage1 | Vintage & Old-Timer Designs | 5 | May 15, 2004 12:55 PM |
