Old Jan 27, 2013, 12:51 PM
randmental is offline
Find More Posts by randmental
South Africa, GP, Centurion
Joined Oct 2012
Why use Lipos in TX / Controllers
Hi Guys
What do I miss - everyone seems to go to Lipo's for their TX/Controllers.
I have been using 4 x AA (2450mAh NiMh) and they have double the power capacity (Wh) than a 7.4V 2s 800mAh lipo that I can fit in that same space.
Even if the Controller can take a 11V / 3S lipo the max physical size drops the mAh capacity and thus the Wh, to way less than 4 x AA
Any ideas?
randmental is offline Find More Posts by randmental
Old Jan 27, 2013, 12:55 PM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
They don't know any better.
For transmitters that require 8 AA cells, a lipoly can be cheaper and will also be lighter. For me, they're not worth the hassle and I use AA Eneloops in all of my transmitters as I find them far less risky and more convenient.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 27, 2013, 01:14 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Originally Posted by mrforsyth View Post
... For transmitters that require 8 AA cells, a lipoly can be cheaper and will also be lighter. For me, they're not worth the hassle and I use AA Eneloops in all of my transmitters as I find them far less risky and more convenient.
Mark
+1. I prefer to keep it simple, and I've had no problem with the stock 8-cell NiMh packs, varying between 800 and 1200mAh, supplied with my Futaba sets. This weekend I bought a 2000mAh Eneloop pack to replace a pack that's beginning to lose capacity. No fussy battery management -- I just put it on slow charge the night before I'm going flying.
abenn is offline Find More Posts by abenn
Old Jan 27, 2013, 01:17 PM
Joined Oct 2012
Thanks Mark
I also have no intentions to move, my TX uses 4 x AA driving, (I guess) 3.3V electronics, so there is no reason to go to Lipos or higher supply voltage to reduce losses as one would do on the heli side.
Guess they need to remember Ohm's and the other power laws .
Old Jan 27, 2013, 03:57 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
And there ya have it.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old Jan 27, 2013, 04:06 PM
rrg is online now
rrg
Find More Posts by rrg
rrg
rrg's Avatar
United States, KY, Edgewood
Joined Dec 2007
Seems like we are all in agreement.......
rrg is online now Find More Posts by rrg
Old Jan 27, 2013, 04:24 PM
PGR is offline
PGR
Find More Posts by PGR
PGR
Low AltiDude
PGR's Avatar
United States, CA, Costa Mesa
Joined Jun 2004
Only because the LiPo proponents haven't shown up yet.
They'll come, though. They always do.
Pete
PGR is offline Find More Posts by PGR
Old Jan 27, 2013, 04:37 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
Lost a plane from AA nimh batteries in the spring holder. A soldered pack no problem, but way to many weak connections on a spring type holder with normal cells. I've also had zero problems with a low discharge lipo pack, and being a 2650, the charge holds for a long time. Also had zero problems with my iPad with lipos, iPod, and so on. Carbureted cars were all the rage 30 years ago to😜
Underthetire is offline Find More Posts by Underthetire
Old Jan 27, 2013, 04:40 PM
So. Cal.
Interesting. I've been using Radio Shack AA holders in all of my transmitters for the last 7 years and have yet to experience even the slightest glitch.
Mark
Old Jan 27, 2013, 07:31 PM
Dave H. is offline
Find More Posts by Dave H.
Joined Feb 2008
I'm using the default 4.8v 2000mAh NiMH that came with my transmitter (DX8), however, the manufacturer also offers a 7.4V 4000mAh LiPo as an option. The optional LiPo is slightly larger, however the transmitter was designed for it, and comes with two differently shaped foam spacers depending on which battery you use.
So, one reason that some people may be going with lipos is that the numbers don't always work out the way they do in the original post.
Dave H. is offline Find More Posts by Dave H.
Old Jan 27, 2013, 08:05 PM
pilotpete2 is online now
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Pete
OK, I wouldn't want to disappoint anyone now, so here goes
When folks ask how can they put a Lipo in their tranny that takes loose AA cells, I say fuggedaboudit, just get some Eneloopers
Any use of a lipo, where one has to do some creative "bashing" to use a Lipo in their radio is not a good idea in my book. I'm also not that comfortable with using a fully charged 3S in place of an 8 cell Nixx that only charges to about 11.4V, though two diodes in the battery lead will fix that and also make the low voltage warning for the stock battery closer to what it should be for the 3S Lipo.
Many of our newer transmitters are designed with Lipos in mind, at least as an option. I'm running a 2S low C rated Tx Lipo made specifically for the Futaba 12FG and 8FG in my 8FG. Perfect fit, easy access to the balance tap and I can set the low voltage warning to where I want it, I set it a little higher than Futabas recommended setting for Lipo. With the Lipo, I slide the battery out of the bottom of the radio to charge it, usually while having lunch at the field.
At my club, there are more and more E-power only guys flying with Lipos, so you see more and more Lipos in the transmitters.
I guess it all depends
Pete
pilotpete2 is online now Find More Posts by pilotpete2
Old Jan 28, 2013, 02:54 PM
still4given is offline
Find More Posts by still4given
Sky Pilot
still4given's Avatar
Victorville, CA
Joined Jun 2006
I just starting using these LiFe packs in my older DX7's.
http://www.hobbyking.com/hobbyking/s...ter_pack_.html
They have worked well so far but have to be charged out of the Tx. I miss being able to just plug in the wall wart the night before and have it charge along with all my planes in the trailer. My new Tx is a DX8 and I have this pack in it.
http://www.hobbyking.com/hobbyking/s...ter_Pack_.html
That will charge on it's wall wart over night.
still4given is offline Find More Posts by still4given
Old Jan 28, 2013, 03:00 PM
Crashaholic is offline
Find More Posts by Crashaholic
trying to kick the habit
United States, CA
Joined Mar 2006
http://www.rcgroups.com/forums/showthread.php?t=821683
Crashaholic is offline Find More Posts by Crashaholic
Old Jan 28, 2013, 03:07 PM
Mike_Then is online now
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
...and that's the EXACT reason why I went away from NiMH packs in my Futaba 10CHG and went with a 9.9v 2200 mAh LiFePO4 pack. No wall-wart chargers to dig out from who-knows-where, no having to remember to charge the night before, no NiMH cells to cycle. I get about 10 hours out of the 2200 mAh pack and if I forget to charge it, I simply charge it at the field with my existing charging infrastructure in minutes and I'm good to go.
I know the OP said LiPo, but I use LiFePO4 so I don't over-zap my expensive radio. Nothing wrong with Eneloops, but I use what works for me. YMMV.
Mike_Then is online now Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old Jan 28, 2013, 04:12 PM
Jim Buzzeo is offline
Find More Posts by Jim Buzzeo
Jim Buzzeo's Avatar
Willmar, Minnesota, United States
Joined Sep 2004
yup, I use Lipo's in my Transmitters that were designed to use them at least optionally.
I've never liked needing to remember to charge my tx the night before... but also was never comfortable with 'fast charging' Nicad/ NiMH packs..
my personal answer:
I use Lipo's only in transmitters designed specifically for them.
when I need to charge them, I've got the equipment to properly do so even at the field.
(I've also got a couple older JR radios that were not designed for Lipo's... I don't use lipos in them.)
Jim Buzzeo is offline Find More Posts by Jim Buzzeo
Discussion using 2 lipos in parallel GaryX1001 Batteries and Chargers 5 Jan 28, 2013 03:07 PM
Discussion cheap controller board + tx all in one ?? saskya Multirotor Electronics 17 Jan 24, 2013 07:53 AM
Question Why LiPo's in a TX? Crashaholic Radios 205 Jun 11, 2009 03:56 PM
Discussion Is there any reason why I cant use standard TX batteries in my MC 12 roundthebend Radios 2 Dec 09, 2007 05:15 AM
Discussion Why lipos shouldn't be used in larger airframes tic High Performance 33 Mar 31, 2006 05:05 PM
