Old Jan 27, 2013, 10:24 AM
V_Okto is offline
Find More Posts by V_Okto
Joined Feb 2011
Help!
OSD Pro and PPM Rx, what to do with RUDDER ?
Hey Guys,
im using OSD Pro with v4 Logger on my Twinstar.
Signal is comming from a Frsky Rx set to sum PPM
all working great.
the only problem i have is were to connect the rudder servo ?
or were to get the rudder signal ?
cant connect it on the Rx because of the ppm, and the OSD has no rudder output
is it possible to get the rudder singal on AUX1/2 IN ?
thanks Billpa
V_Okto is offline Find More Posts by V_Okto
Old Jan 28, 2013, 08:55 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi, the OSD Pro does not have a way to support rudder - this would need to be connected from the receiver to the rudder servo directly.
Does the rudder output of the receiver not continue to operate, when PPM sum is selected?
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 29, 2013, 02:56 AM
V_Okto is offline
Joined Feb 2011
no it just outputs ppm.
maybe you can think about an rudder out (without mixing) for the next alpha if the osd is set to PPM on AUX1/2 ?
would be great. but for now i just dont use rudder.
Old Jun 16, 2013, 05:32 AM
Barney1942 is offline
Find More Posts by Barney1942
Joined Sep 2011
I found my Rx still had some outputs and just had to shuffle the channels to suite. this was a FrSky D8R-PlusII.
Barney1942 is offline Find More Posts by Barney1942
Discussion 1 battery or 2? Help with power to ET eLogger & OSD Pro flywmoi Eagle Tree Systems 4 May 29, 2013 08:22 PM
Discussion What to do with Sandy Hook Fokker Ace Life, The Universe, and Politics 14 Jan 15, 2013 11:13 PM
Question 1 battery or 2? Help with power to ET eLogger & OSD Pro flywmoi UAV - Unmanned Aerial Vehicles 0 Jan 10, 2013 12:24 AM
Discussion what can I do with this? karlik Foamies (Scratchbuilt) 6 Jan 03, 2013 08:26 PM
Discussion OSD PRO with PPM RX srnet Eagle Tree Systems 1 Oct 07, 2010 12:25 AM
