Old Feb 03, 2013, 02:15 PM
gene6029 is offline
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
I'd make sure there isnt a gap or airspace under your sheeting, so as when you draw the bolt up tight it doesnt draw in your sheeting.If there is a gap or air space i'd fill it in with scrap balsa. Also like Tom said, putting a thin sheet of lite ply over the area where your bolt passes thru will help tremendiously.( good idea) If you do go the rout of tapping the wood, you should harden the threads with thin CA,then run the tap back thru, thats one way to harden the threads. Pretty soon you'll be asking how to cover this thing!....Gene
gene6029 is offline Find More Posts by gene6029
Old Feb 03, 2013, 03:02 PM
chaos2984 is offline
Find More Posts by chaos2984
Joined Mar 2011
yea i have alot of scrap and good balsa and ply lying around the workshop lol. ill build it up. Im not sure what the wing bolts are, i havent opened the hardware bag yet. I was going to finish building before i hindged anything and installed hardware. Ill build it up to take up the gap. Thats what the manual said was to tap and ca the threads. I never tried that way before. I just dont want to go back and fix it afterwards
chaos2984 is offline Find More Posts by chaos2984
Old Feb 03, 2013, 03:57 PM
gene6029 is offline
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Well you doing things right & asking questions when in doubt. Thats how we all learn. The more you build, the easier it gets because each time you build,you learn a little more. Its a good feeling to fly something you built.....Gene
Old Feb 03, 2013, 07:26 PM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Don't worry too much about making mistakes. We all make them.
Besides. It's only balsa. It can easily be fixed.
TomCrump is offline Find More Posts by TomCrump
Old Feb 04, 2013, 11:27 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Your Contender is looking just fine. Like Tom says, don't worry about mistakes. Heck, I've had planes that were nothing but one big mistake. The first mistake was buying the kit
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: Helping a club member
Old Feb 04, 2013, 06:18 PM
Joined Mar 2011
yea I've built 3 arf's and want to step into kits and i thought this was a easy enough kit to be my first. Didn't do much building this weekend. I was to busy getting ready for the Raven's superbowl game and we came home with a victory. AWESOME but back to building tomorrow
Old Feb 04, 2013, 10:03 PM
Joined Mar 2011
ok got some time so i mounted the leading edge sticks and started sanding them. tell me what you think so far
Old Feb 05, 2013, 12:42 PM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
The photo is a bit blurry but it looks like you've taken a bit to much off at the glue line of the leading edge. (the sheeting is getting thin) It is an easy thing to do this and I'm guilty of it myself. I've found if you take some masking tape and place it on the part you don't want sanded it helps quite a bit. Sand to the level of the tape and then remove the tape. You only have a tiny amount to sand and it's much harder to over sand the sheeting in your case. Other wise it's looking good.
ken
Old Feb 05, 2013, 06:47 PM
Joined Mar 2011
yea when i was rounding the edge i sanded into the sheeting by accident. and didnt notice it till it was done. will it be a problem or no
Old Feb 05, 2013, 07:36 PM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
Is it the whole length of the wing or just one end? If one end or spot, I would be tempted to fill with some light weight spackle. You can get it at any store with a hardware department. It is the container when you pick it up it feels empty. It sands like balsa but has no strength of its own. Just fill the "empty"spot and sand to the correct shape. Structurally I don't think you will loose much strength, it will just mess with the aerodynamics of the wing a bit and look kind of funny. You might not even notice the different fly quality. If you could get a couple of better photos, from a couple of different angles it might help us to make a better diagnose if it is a problem.
Ken
Old Feb 05, 2013, 08:31 PM
Joined Mar 2011
ok ill post some more pics. I worked on the wing a little more and got half of the LE sanded round. I found a technique that works so i dont sand the sheeting and i can still sand it round.
Old Feb 05, 2013, 08:36 PM
Joined Mar 2011
pics of leeding edge rounding
Old Feb 06, 2013, 10:45 AM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
If your fussy about the shape, just throw some of the light weight spackle on the wing and sand to shape. I think you'll be fine.
Ken
Old Feb 06, 2013, 08:55 PM
Joined Mar 2011
i think it will be ok. But this is my first build. You have to tell me if it will be ok.
Old Feb 06, 2013, 09:01 PM
kenh3497 is offline
kenh3497's Avatar
Joined Jul 2011
LOL It will be OK
Like I said, if you want to, a little of the light weight spackle will hide your mistake. I've been there If this is the worst mistake you ever make you are better than 99% of us.
You are doing fine!! Keep up the good work.
Ken
Discussion My First Kit Build Contender build chaos2984 Electric Warbirds 2 Jan 28, 2013 08:29 AM
Discussion I think I'm ready to build my first kit sport...... Myko Electric Plane Talk 10 Jan 10, 2013 12:15 PM
Help! My First Build - Can Someone Check My Parts List? jelled123 Multirotor Electronics 2 Jan 05, 2013 11:35 AM
