Old Feb 02, 2013, 06:16 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I like it !
Those razor planes do a nice job, but they sure create a mess. LOL
TomCrump is offline Find More Posts by TomCrump
Old Feb 02, 2013, 08:53 AM
chaos2984 is offline
Find More Posts by chaos2984
Joined Mar 2011
ohyea they do. But this was my first time using one. So i took it easy not to go overboard and plane off to much. So i took my short and long sanding bars and just sand the rest.
Also will it be ok if the TE isnt 100% same shape all the way across? Its pretty dam close but for being a noob im sure its not 100% I think its close and has the shape of the air foil.
Today im going to be tackling sheeting the LE / ribs of the wing. 2 of ribs where the aileron servos mount dont have cutouts or notch for where the sheeting lines up all the rest do. Will that make a big difference in the end or should i do something to combat that?
chaos2984 is offline Find More Posts by chaos2984
Old Feb 02, 2013, 09:01 AM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Do your best on the TE, and you'll be fine.
For the LE, lay your sheeting up on the wing, and see how it looks If it looks bad, you'll have to make adjustments before you glue it on.
Old Feb 02, 2013, 10:38 AM
Joined Mar 2011
well the sheeting will be fine on the wing i lined it up. I was just curious as to y it doesnt have the step on 4 ribs of the whole wing. just the 2 for the servo mounts on each side. Or where the servo rails glue to
Old Feb 02, 2013, 11:24 AM
gene6029 is offline
Find More Posts by gene6029
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Can you show us a close up picture of what you are saying, im not following your question.....Gene
gene6029 is offline Find More Posts by gene6029
Old Feb 02, 2013, 12:05 PM
Joined Mar 2011
ok ill take a pic in a bit its lunch time lol
Old Feb 02, 2013, 01:14 PM
Joined Mar 2011
look where my fingers are there is no ridge where the spar is. but on the other rib in the pic there is a ridge what u all think
Old Feb 02, 2013, 01:48 PM
Joined Mar 2011
oh i think i figured it out the cutouts are behind the servo so you can cover the servo with sheeting i think
Old Feb 02, 2013, 02:38 PM
Joined Mar 2011
just put the first 2 wing sheets one what u guys think
Old Feb 02, 2013, 05:13 PM
gene6029 is offline
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
Moveing right along! Just when i figured out what was going on in your picture, as i scrolled down to reply to you, i saw that you figured it out Never built a contender, but its on my bucket list. It was a very popular plane when it came out. Your doing fine, keep it up....Gene
Old Feb 02, 2013, 05:54 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
I'm with Gene. It looks like that area will be sheeted with the servo access panel.
Nice work !
Old Feb 02, 2013, 09:25 PM
Joined Mar 2011
ok got both LE sheeted and sanded really good. sheeted the servo holes. and cut off the jig tabs and installed the spar bar supports. Also when i removed the wing from the plans and flipped it over the TE support jigs would not hold the wing. The outter two would fit but not the center one. It wouldnt rest on the center one like the outside ones. Is this a cause of concern for the wing. The wing looks straight and the sheeting has no wrinkles or dips in it. ???
Old Feb 03, 2013, 05:30 AM
gene6029 is offline
gene6029's Avatar
Wilson NC 27896
Joined Apr 2009
As long as the wing looks straight you'll be fine. I'm thinking the center section is going to get sheeted also ( where the two wing halves join)......Gene
Old Feb 03, 2013, 12:57 PM
Joined Mar 2011
yea they get sheeted and i sheeted the one side last night, one thing im worried about is the wing bolts since the wing gets sheeted wont i crush the balsa with the sheeting and should I install blind nuts instead of trying to tap out the wood with a tap like it says for better support and longevity of the model. should i reinforce the top side of the sheeting since the wing bolt pannel doesnt side flush with the top side sheeting. wont it just crush the sheeting??
Old Feb 03, 2013, 01:18 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Assuming that you are using 1/4-20 nylon bolts to mount the wing, tapping, and hardening the grooves, will be fine.
If you are not comfortable doing that, blind nuts are a suitable alternative.
A lite ply reinforcement scabbed to the balsa sheeting, should prevent any crushing.
Somewhere, I purchased some nylon, 1/4" washers, that I use to do the same thing. I just glue them to the covering.
Discussion My First Kit Build Contender build chaos2984 Electric Warbirds 2 Jan 28, 2013 08:29 AM
Discussion I think I'm ready to build my first kit sport...... Myko Electric Plane Talk 10 Jan 10, 2013 12:15 PM
Help! My First Build - Can Someone Check My Parts List? jelled123 Multirotor Electronics 2 Jan 05, 2013 11:35 AM
