This thread is privately moderated by melsailsnorth, who may elect to delete unwanted replies.
Old Jan 26, 2013, 11:27 PM
melsailsnorth is offline
Find More Posts by melsailsnorth
Trader Rating: 162
Fight for the Right to FPV!!!
melsailsnorth's Avatar
United States, CA, Chico
Joined Dec 2010
Trader Rating: 162
Sold
700TVL 1/3" SONY Super HAD CCD Color Camera NTSC/PAL camera
Purchased two of these and as it turns out I just need one. Brand New and powered on just once to test that it works. Here are the specs-
Description:
- SONY Effio Chip,Support OSD Menu conrol
- CCD type: 1/3" Sony 960H Exview HAD CCD II
- Product name: SONY 700 TVL
- Size:: 38mm*38mm
- Pixel: PAL:1020H596V NTSC: 1020H508V
- Effective picel: PAL: 976H582V NTSC: 976H494V
- Signal format: PAL/NTSC (N CCD is672)
- Resolution:700TVL
- Digital noise reduction:2DNR,support 0-16 grade adjustment
- OSD Menu:Support
- Min lumen: 0.01LUX/F1.2
- SNR: ≥48dB
- Video out put:1.0Vp-p/75Ω
- AGC (automatic gain control) :0.25/0.50/0.75/1.00 adjustable,max up to 55db
- White balance methodpen/close
- HLC High light compensation
- Elsctronic Shutter: 1/50(1/60) - 1/100000 second
- Gamma correction: 0.45/1.0
- Lens: 3.6MM Glass lens
- Voltage: DC12V30%
- Working current: 70MA
- Working temperature: -20℃--60℃
Since I have two of these I was able to compare the two and they both show some limitations with the firmware and OSD adjustments. Great High Res picture on default settings but I was not thrilled with the OSD parameters or their effect on the picture. Maybe someone that knows more about this camera then I can get more out of it. I was just able to confirm that both cameras displayed the exact same characteristics as I tried to tweak settings. Seems whenever you try to move from stock settings, really strange artifact would start appearing (again, this was exact same with both cameras, so not a manufacturing flaw). These are $42 cameras on ebay and I guess you get what you pay for. As I said, default settings seem good and very nice picture. All in all, for the price, you can't beat this high resolution CCD camera. I had painted both with a silicone H20 proofing, but removed it from this one since I'm not keeping it. There may be a slight bit of leftover residue from this. The little video connector was also cut in prep for making an FPV harness and an RCA was added to the large stock harness so that you can utilize the osd controller on it. Just decided one's enough. Paid $40 and waited a month. Asking $40 despite shipping and fee's and you will have this in a few days.
melsailsnorth is offline Find More Posts by melsailsnorth
Old Jan 27, 2013, 01:34 AM
redodedo is offline
Find More Posts by redodedo
Trader Rating: 114
HD FPV on a 4m glider
Canada, BC, Richmond
Joined Dec 2012
Trader Rating: 114
im really quit interested. is it $40 shipped??
redodedo is offline Find More Posts by redodedo
Help! 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera OSD Menu 2.8mm lens not working bighead93 FPV Equipment 18 Jan 10, 2015 10:01 PM
Sold 2.4GHZ 100mW Tx/Rx WITH 1/3-inch SONY CCD Camera NTSC momofx Aircraft - General - Miscellaneous (FS/W) 5 Oct 29, 2012 01:33 PM
Help! How to hack 600TVL SONY SUPER HAD CCD D-WDR Color Board Camera OSD Menu 2.8mm lens seearestacey FPV Talk 1 Jun 04, 2012 02:22 PM
Sold 1/3" Sony Super HAD, Color, PAL format board camera, NIB kdill2160 FPV Equipment (FS/W) 2 Sep 18, 2011 07:15 AM
Sold 900MHZ 100mW Tx/Rx & 1/3-inch Sony CCD Camera NTSC daskip87 FPV Equipment (FS/W) 2 Sep 16, 2011 08:49 AM
