Old Jan 26, 2013, 09:02 PM
GallopingGhostlr is offline
Find More Posts by GallopingGhostlr
Vintage Aircraft Lover
GallopingGhostlr's Avatar
United States, NM, Clovis
Joined Jan 2013
Tatone Calumet Converted to Tongue Muffler.
I had problems with a Tatone EM-4 09-19 Calumet muffler. The Enya .19-VI TV ran very hot with it, it was very restrictive. Well, I turned lemons into lemonade. Trimming the inner baffles did not help, so I turned it into a tongue muffler. Now I have a light weight muffler for the Testors McCoy .19 Red Head.
It works, but I don't have a DB meter, so I can't quantify effectiveness. IOW, you are on your own, YMMV.
GallopingGhostlr is offline Find More Posts by GallopingGhostlr
Last edited by GallopingGhostlr; Jan 26, 2013 at 09:07 PM. Reason: Clarify copper cap by expanding note in 3rd picture.
Old Jan 27, 2013, 08:01 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
Designed an airplane for the K&B 4011. I did not leave enough space between the end of the muffler and the wing. I measured the area of the muffler outlet. I drilled enough 3/32 holes in the muffler to give me about 10% more area than the original outlet. I cut off the original outlet and plugged the hole. It worked fine.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Jan 30, 2013, 06:23 AM
Joined Jan 2013
In this case the muffler has a very small expansion chamber, almost next to none. One doesn't get the adiabatic expansion with each exhaust puff of the engine that would happen with a standard muffler. I ended up doubling the 1/4 inch (6 mm) diameter exit. Since I will be using it on a 33 in. (838 mm) wingspan Midwest P-40 Warhawk profile, it will spend its time 4-2 cycling at a slightly lower RPM. I'll know more when I fly, but it should be acceptable.
For Sale New Tatone TT-60 Pitts Style Muffler No.11434 Paulsitive Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jan 20, 2013 01:49 PM
For Sale Tatone Universal Upright Pitts muffler for 45-85 engine. jrotor Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 23, 2007 02:20 AM
For Sale Tatone Universal Upright Pitts muffler for 45-85 engine. jrotor Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jun 19, 2007 12:56 AM
Discussion tatone muffler for cox .049 gzkpez 1/2A Planes 0 Jun 23, 2006 06:59 PM
Tatone pitts muffler asp .090 Ants Engines 0 Jan 26, 2005 02:28 PM
