Old Feb 15, 2013, 03:20 PM
DutchVince is offline
Find More Posts by DutchVince
DJI Phantom pilot
The Netherlands, GE, Culemborg
Joined Jan 2013
At last totally jello free for about 1 dollar 1080p at 30 fps
I decided to make a wire suspension with solid electrical copper wire.
It is very soft and should dampen vibrations well.
Also the rubber/plastic insulation won't hurt.
I attached two bits of foam to the Phantom and ran the wires in between making sure they would not touch the screws running through the foam and the plastic plate that holds the foam to the Phantom.
The GoPro goes on top of the platform. In this way the wire can be longer and the GoPro won't stick out under the landing gear. The platform is a plastic end cap of a carton tube, the kind you send posters in. The GP is attached to the platform with 2 rubber bands (in case one snaps) running through 2 slots in the platform and held in place by half a clothes pin.
The whole setup feels solid and flexible at the same time
Hmm, I added 4 attachments, photo's, can't see them anywhere...
I'll put them on my ftp server in stead...
I'm very pleased with the result:
Windmills (1 min 32 sec)
DutchVince is offline Find More Posts by DutchVince
Old Feb 15, 2013, 05:29 PM
Bo Lorentzen is offline
Find More Posts by Bo Lorentzen
FPVpilots do it remotely
United States, CA, West Hollywood
Originally Posted by Flyingskwerrl View Post
Bo, can you explain more about using the fiber optic cable to see the status light? I've been wondering about a low tech way of seeing it in FPV. I know about osd's but I'm still doing research on them. Maybe I can get along without...
Its really pretty simple. Wheels came up with it, use a piece of fiber-optic cable, I cut up a old audio cable and cut the thick cable then pulled out the fiber in black liner, it is about 2.5mm thick. I simply stuck then one end on the edge of the LED thing in the back. and the other end I put at a angle pointing to the lens about 1cm away from the lens to reduce the size in the image. done, now I see blinking lights litterally.
Bo Lorentzen is offline Find More Posts by Bo Lorentzen
Old Feb 15, 2013, 05:33 PM
Originally Posted by ThePhantomMenace View Post
Another question...If I go with the Fat Shark Attitude, I'm assuming I will need a Tx, Battery (for goggles), and cable to connect my GoPro 2 to the tx? Am I missing anything? Also, reading a lot about what tx to get. I just want one that will provide good range, however, not anything beyond my sight of the phantom.
I swear by immersionRC stuff. it operate on the same system as FatShark.
Check into a kit pack on the FatShark Predators, they come with the kit camera, video TX, goggles and goggle battery and charger. roughly $280 ready to play.
You power the vtx from the extra cable in the Phantom, pull it out through the one leg like the antenna and compass, put a plug on it and connect it to the vtx, the vtx will power the camera, and you can get cables that will connect your GoPro to the vtx and even power the GoPro from the vtx if you like.
Old Feb 16, 2013, 05:59 AM
Johnopyro is offline
Find More Posts by Johnopyro
Ireland, Kerry, Tralee
Joined Jan 2013
Originally Posted by vayrus View Post
gimbal modified from tmf g10
The original tmf g10
antivibration sorbothane
and this..
thanks!
whats this like with the stock legs on, will it fit or do you have to extend the legs ?
Johnopyro is offline Find More Posts by Johnopyro
Old Feb 16, 2013, 11:24 AM
ThePhantomMenace is offline
Find More Posts by ThePhantomMenace
ThePhantomMenace's Avatar
United States, PA, Pittsburgh
Joined Feb 2013
Thanks Bo...think I'll check into the Predators
ThePhantomMenace is offline Find More Posts by ThePhantomMenace
Old Feb 16, 2013, 02:08 PM
saskya is offline
Find More Posts by saskya
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Where can you get those rubber parts but only the rubber damper
saskya is offline Find More Posts by saskya
Old Feb 16, 2013, 07:23 PM
vayrus is offline
Find More Posts by vayrus
Joined Jan 2013
More modīs
I am a surfer and my work will be on water and all components waterproof
My phantom will be like aquacopter.
osd gps
gopro black usb
osd
gps
vayrus is offline Find More Posts by vayrus
Old Feb 16, 2013, 07:26 PM
vayrus is offline
Joined Jan 2013
waterproof gimbal, (imu board, servos)
Old Feb 16, 2013, 08:22 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Vayrus,
I am looking forward to some Phantom surf videos.
Don't forget that the esc's and VTX need airflow for cooling.
Good luck!
wavekatcher is offline Find More Posts by wavekatcher
Old Feb 16, 2013, 08:34 PM
@Vayrus, coool project. I have been thinking about the exact same thing.
Curious, why dont you simply dump the Pahntom into a aquacopter.? other than it being a bit bigger and heavier than a Phantom. and personally I like the phantom size just as it is.
Old Feb 17, 2013, 06:41 PM
fun2av8rc is offline
Find More Posts by fun2av8rc
Fly Micro Scale to Full Scale
fun2av8rc's Avatar
United States, VA, Brandy Station
Joined Nov 2011
Following this thread is like drinking water from a fire hose
You mention below that you got the goggles with "the kit". What is the kit and where can one buy the kit? Is it 5.8ghz? I really like the cam on top of the Phantom - great for FPV orientation. Would you mind opening your Phantom and snaping a few pix of the cable you talked to @Tim about?
thanks,
Jim
Originally Posted by Bo Lorentzen View Post
@Tim, yes you can definately power your FPV gear from the Phantom, there is a cable already inside, open the shell and push it through the cable port , then put a plug on it so you can plug it into the video transmitter to power everything.
@ThePhantomMenace I have the predator goggles, got them with the kit including a vtx and a camera. hooked it up to power the video/camera from the Phantom, it only require putting plugs on the cable already waiting inside the phantom hull.
I have started to mount the camera backwards a bit under the belly to keep it from getting hit by bright light, it keeps the camera from blacking out when facing the sun. and I made a small post to mount a fiber optic cable on so I can see the blinking status light. picture is my phantom this weekend, I flew it with the Replay on top, a bit bouncy and props in the shot, but no jello, good Replay.!
You can barely see the video tx board under the belly and the bend down video antenna.
fun2av8rc is offline Find More Posts by fun2av8rc
Old Feb 17, 2013, 09:33 PM
thanks,
Jim
Jim, try this link yes it is 5.8 video
http://www.hobbyking.com/hobbyking/s...dProduct=20672
Actually, i have started flying the camera on the bottom of the Phantom, because the body shadows the camera from the sun, if the camera sit on top of the body you will get a black-out when turning into the sun while flying. that is why you want to be under the body with the camera, I fly mine about 1.5-2 inches back from the front.
The power cable is inside, if you open the box you will find the cable, it is grey and LOOSE, only the one end is attached, you can see it in most of the sets of pictures already posted of the inside of the Phantom.
Bo
Old Feb 18, 2013, 04:24 AM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
Let's get an extended leg upgrade! We need some room for our gimbals. I want to have this ready before the BL gimbal is released. Any shops want to give us this? Higher and wider would be nice!
beamen is offline Find More Posts by beamen
Old Feb 18, 2013, 05:49 AM
vayrus is offline
Joined Jan 2013
ready
cutting
perfect holes
perfect balance
thanks!
Old Feb 18, 2013, 09:04 AM
rxwarrior is offline
Find More Posts by rxwarrior
Joined Jul 2011
Dx8
Hi I'm old and not very good with technical stuff, I was wondering if anyone knows how to set up a spektrum dx8 on a phantom? That way I wouldn't have to carry two transmitters and maybe I could have the RTH on a separate switch.
rxwarrior is offline Find More Posts by rxwarrior
For Sale e-Flight F4 phantom tam jet 1409 2y 8s upgraded motor and fan!! holeshot203 Aircraft - Electric - Jets (FS/W) 6 Jan 31, 2013 10:32 AM
Cool DJI Introducing Phantom w/GPS Flight Control DJI INNOVATIONS Multirotor Talk 1 Jan 07, 2013 08:18 PM
New Product DJI Phantom Available at AddictiveRC/RcHobbyHelicopter Now! johnIn2SonAZ Multirotor Talk 2 Jan 05, 2013 01:35 AM
Off Site DJI Phantom RTF GotHeliRC Aircraft - Electric - Multirotor (FS/W) 2 Jan 04, 2013 03:18 PM
