Old Feb 06, 2013, 02:42 PM
vayrus is offline
Find More Posts by vayrus
Joined Jan 2013
gimbal modified from tmf g10
The original tmf g10
antivibration sorbothane
and this..
thanks!
vayrus is offline Find More Posts by vayrus
Old Feb 06, 2013, 03:11 PM
beamen is offline
Find More Posts by beamen
Joined Sep 2011
and this..
thanks!
Wow. So it has it's own gimbal HW (bypassing the bad Naza gimbal)?
Isn't that setup WAY too heavy for the Phantom? Have you installed longer landing gear?
Let's see a video!
beamen is offline Find More Posts by beamen
Old Feb 06, 2013, 03:14 PM
icube is offline
Find More Posts by icube
Joined Feb 2013
Hi guys, a newbie here, a quick question. how do you guys practice flying your quads? is there some names for some specific moves? what do you guys suggest to a newbie to practice? get a software simulator?
icube is offline Find More Posts by icube
Old Feb 06, 2013, 03:21 PM
heli001 is offline
Find More Posts by heli001
Triple Tree Aerodrome
heli001's Avatar
Charlotte, NC
Joined Feb 2002
Get a Horizon MQX...best 100 dollars you will ever spend.....! Great for teaching the basics...
heli001 is offline Find More Posts by heli001
Old Feb 06, 2013, 03:33 PM
figgoat is offline
Find More Posts by figgoat
CunningStuntsFPV
figgoat's Avatar
Greenland
Joined Dec 2012
Get a simulator and as above^^^^^^buy something to practice on. Phoenix, Realflight or Aerosim are good options.
http://www.hobbyking.com/hobbyking/s...or_System.html
http://www.multiwiicopter.com/produc...tor-usb-dongle
http://www.realflight.com
http://www.phoenix-sim.com/
HTH
figgoat is offline Find More Posts by figgoat
Old Feb 06, 2013, 03:37 PM
jcmendo01 is offline
Find More Posts by jcmendo01
Joined Nov 2012
I started with a Blade MQX, I still love that thing btw. Before the MQX, I used to fly numerous coax helis, that you can purchase at the mall. A couple weeks of flying and getting used to orientation you should be more than capable of flying the Phantom.
jcmendo01 is offline Find More Posts by jcmendo01
Old Feb 06, 2013, 03:41 PM
vayrus is offline
Joined Jan 2013
Let's see a video!
well, I have reduced weight on the top and landing. +/- 100gr
the gimbal weighs after being modified ----125gr
I hope to reduce more weight in the battery.
many people are lifting a lot of weight without reducing.
Old Feb 06, 2013, 03:50 PM
beamen is offline
Joined Sep 2011
Cool. Can't wait to see the video
Old Feb 07, 2013, 12:23 AM
Joined Nov 2012
Osd
Anyone using OSD units when they are FPVing? If so, what are you using.
Old Feb 09, 2013, 01:11 AM
Joined Nov 2012
thin graupner prop for motor
I just installed new Graupner props, however, on one of the motors, the prop still spins freely. Seems like the props shaft is thinner than the others. Has anyone had this problem? I solved it by adding a washer between the prop and nut. Any other ideas why is did this?
Old Feb 09, 2013, 01:28 AM
Bo Lorentzen is offline
Find More Posts by Bo Lorentzen
FPVpilots do it remotely
United States, CA, West Hollywood
@Vayrus, wow, that looks really good and like the weight is in a very meaningful range. can't wait to see some videos from this.! Nicely done.!
Bo Lorentzen is offline Find More Posts by Bo Lorentzen
Old Feb 09, 2013, 01:34 AM
Been working on a set of skip off the ground and bounce like crazy legs. at first it seemed like a great idea. and I put these together to clear the ground with the vtx and FPV cam under the belly of the Phantom. unfortunately that is not enough space for the GoPro frame mount..
DJI Phantom with FPV lowrider legs - torture test 1 (0 min 37 sec)
Old Feb 09, 2013, 02:51 AM
red1one is offline
Find More Posts by red1one
red1one's Avatar
United States, MI, Ann Arbor
Joined Mar 2012
Originally Posted by FITandFUEL View Post
Fat Shark Dominator googles w/ 5.8ghz receiver module
5.8ghz Immersion RC transmitter
And I simply run it off the GoPro
- On that note I tried to make a 10 pin cable myself with a 4 and a 5 pin cable but no luck. Waiting for one to be delivered in two days along with a basic OSD ($14.99) for battery feedback. Right now I'm using a Hero2 with a cable I put together in 5 minutes.
So far it flies great! This is my first try at FPV and I can get pretty decent range with LOS. Far enough that I couldn't see the quad with my bare eye (I was testing the range and knew how to get back if it cut out). Trees and obstructions do significantly limit the range though.
basic osd for $15. where please nice set-up
red1one is offline Find More Posts by red1one
Old Feb 09, 2013, 02:55 AM
red1one is offline
red1one's Avatar
Joined Mar 2012
Originally Posted by cleverpork View Post
Oh, here's some footage with the aforementioned lego mount. Stabilized in FCP X. The minor warping is caused by the stabilization process.
http://vimeo.com/58609340
Also, all of these are low lit and when in brighter conditions I do get jello, which is driving me mad...
did you do any color grading in FCP - your colors look saturated in a great way?
Old Feb 09, 2013, 03:00 AM
red1one is offline
red1one's Avatar
Joined Mar 2012
for jello, look at snake river prototyping. they make a snap on adaptor for the new gopro3 that accepts a 55mm nd-4 neutral density filter (you can pick these up cheap on ebay) it will eliminate jello in sunny conditions. adds only minimalweight and makes the gopro look bug-eyed cool. i did find i needed to mod my mount to adjust CG.
For Sale e-Flight F4 phantom tam jet 1409 2y 8s upgraded motor and fan!! holeshot203 Aircraft - Electric - Jets (FS/W) 6 Jan 31, 2013 10:32 AM
Cool DJI Introducing Phantom w/GPS Flight Control DJI INNOVATIONS Multirotor Talk 1 Jan 07, 2013 08:18 PM
New Product DJI Phantom Available at AddictiveRC/RcHobbyHelicopter Now! johnIn2SonAZ Multirotor Talk 2 Jan 05, 2013 01:35 AM
Off Site DJI Phantom RTF GotHeliRC Aircraft - Electric - Multirotor (FS/W) 2 Jan 04, 2013 03:18 PM
