Old Jan 26, 2013, 04:16 PM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Build Log
EXTREME FLIGHT 5020/Torque-220kv motor-latest surfwatch video
I had this EXTREME FLIGHT 220kv motor in back draw for couple of years so finaly I decided to fit it in this 2meter H2K cheapo EXTRA that was collecting dust just as well. After few bench tests using various props motor gets pretty warm running on 10S so might cut down props or try 9S.
Stand offs had to be extended to 130mm to fit the covel and theres lot of room to move batteries around. Horrendous wet weather spell outside so back to building, Joe.
jofro is offline Find More Posts by jofro
Old Jan 27, 2013, 02:15 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
So what size is this plane? 65" or 2 meter (80")?
rebell is offline Find More Posts by rebell
Old Jan 27, 2013, 03:22 PM
jofro is offline
Joined Jan 2010
No instruction manual with this model so there are few things left to your imagination. My initial thought was this kit is for E-power but looking at at closer I believe its designed for 25-30cc IC, having a tunnel for the tune pipe/canister. There are no parts for Rudder instalatlion so I built up new provision for MG servo and X-wire pull-pull hook up. All other controls are well designed with strong double horns, ball links and 3mm L&R th. push rods. Major floods outside so back to building, J.
Old Jan 28, 2013, 01:06 AM
jofro is offline
Joined Jan 2010
Public holiday today, 500mm of rain in 24 hours, great time for building, J.
Old Jan 29, 2013, 01:51 AM
jofro is offline
Joined Jan 2010
160A, ESC fitted to the canister tunnel for best cooling position with some air vents left open at the rear of fuse. Elevators fitted with new extention leads soldered to connect RX. Few more static test will be performed to check current, watts and RPM, selecting right prop before my test flights, J.
Old Jan 29, 2013, 09:14 AM
Ducky22 is offline
Find More Posts by Ducky22
Ducky22's Avatar
Canada, ON, Mississauga
Joined Apr 2011
Is that the Turnigy DLux 160HV? I am thinking about using it in my next project.
Ducky22 is offline Find More Posts by Ducky22
Old Jan 29, 2013, 03:35 PM
jofro is offline
Joined Jan 2010
Yes it is, I don't particulary like its enclosed design an no mounting tags, but hopefully it won't melt-down as this set up draws only 75Amps, J.
Old Jan 29, 2013, 04:21 PM
Ducky22 is offline
Ducky22's Avatar
Joined Apr 2011
I have not decided yet if I will go with it, I plan on pulling 130-140 through it. Keep me updated on its performance. I read the reviews and they seem positive, but, taken with a grain of salt.
Old Jan 29, 2013, 06:57 PM
jofro is offline
Joined Jan 2010
Just looking at that ESC, I wouldn't like to pull out of it more then 100-120A. J.
Old Jan 29, 2013, 07:24 PM
jofro is offline
Joined Jan 2010
I just finished testing 4 different props and putting down all figures to compare. Above motor is recommended for 88' Extra, that I would be very concern to power it with. I was supplied with it APC22x10E which would bring down this
motor to meltdown state in no time reading 85A/3000W/5200Rpm.
Slightly better figures using T20x10wood at 73/2650/64-6500.
Cutting it down to 19&3/8 and rounding the tips nicely I got 55/1850/6400 with impressive 7+kg static pull.
Another try was T/SF20x10wood resulting in 64/2100/6000.
So it will be one of the two above that will suit this 76" size model IMO, J.
Old Jan 30, 2013, 02:48 AM
jofro is offline
Joined Jan 2010
All ready for test flights, but have to wait a while for the field to dry out after this weeks floods, J.
Old Feb 01, 2013, 03:35 AM
jofro is offline
Joined Jan 2010
Just back from the field hoping to maiden it but it was horrendously windy 30-50km/h!! I was tempted but it wouldn't be pretty, instead had few flights with my hotted up "Mirage" handling the wind gusts lot easier. Hoping it will settle in the morn, J.
Old Feb 01, 2013, 04:47 PM
jofro is offline
Joined Jan 2010
Had a 3min quickee this morn after some work at the field, very pleased with it, I think it will be very enjoyable model after few adjustments. I was only guessing my CofG position, it was considerably nose heavy so I got heaps of room to move batteries back. Analyzing my video footage, I had couple of nasty scares but all it needed was some power to get out of it. Motor was pretty cool, after this short flight, back on charge to see how much current I drawn during my short test flight, J.
Old Feb 01, 2013, 08:46 PM
jofro is offline
Joined Jan 2010
Short footage of first flight consuming only 850mA, great news meaning I might get 5-6 min. of flying, enjoy, J.
P1050445 (3 min 37 sec)
Old Feb 02, 2013, 07:38 PM
jofro is offline
Joined Jan 2010
Had few more flights testing SF prop, unfortunatelly can't get correct sizes so more cutting, shaping and ballancing to get perfect match for my set up, happy flying, J.
Sold Losi Mini T RTR $65 rcpilot7321 Cars - Cars and Parts (FS/W) 5 Jan 30, 2013 08:24 AM
Sold UMX Extra 300 3D BNF **New $65** TonyTypeS Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Jan 03, 2013 01:44 PM
For Sale Cox 15 with Extras L@@K $65.00 Shipped. Nice VampeD4 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 04, 2009 08:59 PM
Sold Team Losi Mini-t with extra's For Sale $65 shipped HeliStyle Cars - Cars and Parts (FS/W) 3 Mar 15, 2009 08:58 PM
Sold FMA cellpro 4s almost brand new with extra pigtails $65 shipped av8rOC Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jun 04, 2008 02:48 PM
