Old Jan 26, 2013, 03:53 PM
Feliperc is offline
Find More Posts by Feliperc
Planes & Falconry my passions
Feliperc's Avatar
New York
Joined Mar 2010
Do you "dry" your engine when it won't be use for a while???
Hello.
I would like to know what you do with your engines when you put your planes away for winter (in my case).
Some people says that I have to remove the fuel from the engine when it won't be used for a while starting the engine with no fuel in the fuel tank until it goes off. Other people says that I should keep some fuel on it because it has oil and it will help to avoid corrosion. Other people says that it doesn't matter (either way is ok).
Thank you for sharing your knowledge,
Felipe.
Feliperc is offline Find More Posts by Feliperc
Old Jan 26, 2013, 04:07 PM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
I drain the tank and plug the fuel lines then run the engine dry and apply after run oil liberally throughout. What kind of oil is a matter of much(heated) debate.
jeffie8696 is offline Find More Posts by jeffie8696
Old Jan 26, 2013, 04:15 PM
datsunguy is offline
Find More Posts by datsunguy
Joined Jun 2011
Leaving fuel in it is the worst thing you can do.
datsunguy is offline Find More Posts by datsunguy
Old Jan 26, 2013, 07:23 PM
Kit_Builder is offline
Find More Posts by Kit_Builder
YAY the tourists are GONE
United States, MA, Sandwich
Joined Feb 2010
There are 2 ways to turn off a engine
1. While the engine is idling you close the throttle
2. With the engine on Wide open throttle you pinch or remove the fuel line
Now option 1 is a bad way to shut an engine off at the end of the day or close of the season be because it will leave fuel in the crankcase
Option 2 is a better way to turn off an engine. Because it does not leave as much fuel in the engine as just closing the other way.
Option 2 is usually refered to as "running the engine dry"
Kit_Builder is offline Find More Posts by Kit_Builder
Old Jan 26, 2013, 07:34 PM
downunder is offline
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
Other than having a crash option 2 is the the way all CL engines stop at the end of every flight and rust is virtually unheard of. Running dry doesn't mean running dry of oil though, just the fuel.
For storing over the winter, if your fuel has some castor in it then it'll be fine as is. If all synthetic then give the internals a good coating with an auto trans oil which will keep all the surfaces protected. Some synthetics tend to dribble off metal parts leaving them exposed to air and moisture.
downunder is offline Find More Posts by downunder
Old Jan 27, 2013, 05:16 AM
surfer_kris is online now
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
With all castor fuel you have the protection, but it is still good to lubricate with another oil so that it doesn't freeze up as the castor goes from oil to resin...
surfer_kris is online now Find More Posts by surfer_kris
Old Jan 27, 2013, 06:39 AM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
After -run oil in an engine covers all the spaces corrosion wants to get to.
If the engine is off the airplane, a zip-lock bag is good for storage, after oiling.
If still installed, stuff the muffler and carb openings with small pieces of paper towels, or cloth, to keep critters and moisture out.
I don't like 'dry' engines.
epoxyearl is offline Find More Posts by epoxyearl
Old Jan 27, 2013, 07:45 AM
kwj48 is offline
Find More Posts by kwj48
probro 2567
kwj48's Avatar
Midlothian,VA
Joined Jan 2006
While all of the statements are true to nitro engines. With gasoline engines you can leave the fuel in the tank. It will help to keep the carb diaphram flexible and the tygon ( if using it ) flexible also. And even though many 2 stroke oils come with stabilizers in them I like to add a little extra in the mix.
kwj48 is offline Find More Posts by kwj48
Old Jan 27, 2013, 04:00 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
+1
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Jan 27, 2013, 11:34 PM
gerryndennis is offline
Find More Posts by gerryndennis
gerryndennis's Avatar
New Zealand, Canterbury, Christchurch
Joined Jun 2008
Hi Felipe,
I assume you are talking about glow engines? Yes your engine will thank you for some TLC when you lay it up for the winter
I agree with the others, best idea is to run your engine dry at the end of the days flying. Pinch or disconnect the fuel line from the carburettor with the throttle wide. Try and restart the engine a few times until it stops firing. This will burn of as much methanol and nitromethane as possible but will leave behind a good coating of oil.
If you use a castor based fuel then, as Downunder points out, the castor left behind will do an excellent job of coating the engine internals and protecting them from rust. As Surfer Kris says though, castor oil can gum up over time. This is only really a problem with ball bearing, ringed, or four stroke engines. If you run your engine with gummed up bearings the balls may skid and cause wear. A four strokes cam followers, valves or ring may stick giving running difficulties if not damage. None of this is a problem though, a little bit of heat and a solvent (fresh glow fuel will do) at the beginning of the season will free things up nicely before your first start. So castor is an acceptable storage oil, and very good for one week to the next.
Downunder is right about synthetic oil's shortcomings for engine storage. Some manufacturers add a plating agent to make the oil stick to the metal surfaces better, and anti corrosion agents. Many would disagree but I have found that these additives work fine for me, I have several engines that have been stored for several years with no corrosion or gumming up. I give my engines a generous helping of the same synthetic oil that I use in my fuel before I store them.
Most people would advocate the use of an after run oil as epoxy earl says. I used to use a 50/50 mix of kerosene and automatic transmission fluid on a daily basis with excellent results in two strokes. I got a bit of wear with four strokes though, probably because the oil was a bit thin. That wouldn't be a problem for winter storage though. The idea of the kerosene was to help get the oil fully distributed throughout the engine, over time it would evaporate leaving the oil behind. I never gave it time. You could just use straight ATF. There are proprietary ARO's out there, they cost more but I don't know if they offer any thing more than ATF. Don't use WD 40, it's not a good storage oil and will loosen any rust that might be in your engine which will then turn into a grinding paste.
You probably won't need to remove your engines and put them in a zip lock bag just for winter, but its a really good idea for long term storage, and certainly wouldn't hurt for the winter.
At the end of the day it's worth the small investment in time to run your engine dry and then add an ARO before laying it up
Just wanted to give you my experience but it matched the other posters so I ended up summarising their posts as well.
Dave H
gerryndennis is offline Find More Posts by gerryndennis
Old Jan 28, 2013, 03:34 AM
DarZeelon is offline
Find More Posts by DarZeelon
DarZeelon's Avatar
Israel, Center District, פ"ת
Joined Nov 2003
Good post, Dave H!
DarZeelon is offline Find More Posts by DarZeelon
Old Jan 28, 2013, 10:03 AM
Feliperc is offline
Feliperc's Avatar
New York
Joined Mar 2010
Thank you so much for sharing.
So, this is only for NITRO?
My engines are DA50 and DLE 55 (gasoline).
Thank you again for your time,
Felipe.
Originally Posted by gerryndennis View Post
Hi Felipe,
Dave H
Old Jan 29, 2013, 04:00 AM
Joined Jun 2008
Well that kind of makes my post a bit redundant, yes I was talking about glow (nitro) engines.
I'm afraid I have little experience with petrol (gasoline) engines so I'll leave that to the experts. I'm sure someone will give you the information you need soon
Dave H
Old Jan 29, 2013, 04:02 AM
Joined Jun 2008
Thanks Dar
Dave
Old Jan 29, 2013, 10:30 AM
Feliperc is offline
Feliperc's Avatar
New York
Joined Mar 2010
From DA:
Felipe,
Generally, if you are going to store the motor for a long period of time you do want to run the gas out of the carb. Overtime the gas will become very thick and like a gel and can cause damage.
Jeff
Desert Aircraft
Thank you so much for your help guys!!!!!!
Question How much leeway do I have when choosing a common prop/fuel for a range of engines? murcielago Engines 6 Jan 22, 2013 02:55 AM
Discussion Do you need separate battery for your LED lights?! DYORD Multirotor Talk 8 Jan 15, 2013 08:29 AM
Discussion glue won't dry when adding spar to wing grfcon Slope 8 Jul 22, 2009 07:56 PM
Discussion What brand of After Rnu Lubricants do you use for your engine Starguard Off-road Cars 4 Jun 28, 2006 09:04 PM
