Old Jan 26, 2013, 01:58 PM
jeff262 is offline
Find More Posts by jeff262
farmington, mn
Joined Sep 2003
are gyro stabilizers worth the money?
i have a albatross and a DR.1 both made of balsa and the dr.1 is coated in silk. needless to say both of these planes took me a huge amount of time to build and the albatross has a high wing loading so it is unstable and the DR.1 is very easy to loose orientation with all the wings, it looks like one big wing when it gets to high. i was curious as to what people thought of adding in some of the new stabilizers like the Gardian from eagletreesystems.com do they actually help that much in squirly planes? i once had the FMA optical stabilizer and that was a huge peice of junk, every time it saw a hill the plane would bank. i think it cause more crashes then it saved. is anyone using one of the new ones and what do you think and what kind is good one to use
thanks jeff
jeff262 is offline Find More Posts by jeff262
Old Jan 26, 2013, 02:09 PM
scottc39 is offline
Find More Posts by scottc39
scottc39's Avatar
USA, MN, Shakopee
Joined Sep 2004
i think a gyro is a good tool to use, i used them on helis yrs ago and the gyro kept me in the hobby. many will say its a cheating crutch but use it any way you want i say.
scottc39 is offline Find More Posts by scottc39
Old Jan 26, 2013, 02:34 PM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
That's exactly what it does Jeff, takes the squirlyness out of it. A buddy has the Eagle tree system and I have the HK orange stabilizer and they both make planes that you'd be afraid to take out in the wind a none event. The gyro can think quicker than I can when the wind makes the wing take a dip. They work well on scale models of high value, very hairy 3D planes and trainer planes. Just a stability add on.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Jan 26, 2013, 02:56 PM
jeff262 is offline
farmington, mn
Joined Sep 2003
What happens in a tip stall, do they make the plane unrecoverable since they are fighting the stall and not letting the ailerons to the center point to get airfoil back over the wings?
Old Jan 26, 2013, 03:43 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I don't have the gyros in a particularly tipstally plane But I know, in the Zoombi 3D plane, When you go gradually up into a hover, the wings don't oscilate back and forth, as without the gyro. There again the gyro can stop it before it starts quicker than I can. Makes me look good, even when I ain't. All I really can say is, however it flies now, it will be smoother.
Gord.
Old Jan 26, 2013, 06:56 PM
Grantham Kid is offline
Find More Posts by Grantham Kid
Chasin' that Neon Rainbow
Grantham Kid's Avatar
Australia, QLD, Grantham
Joined Oct 2012
I have 2 Orange V2 models and a JR gyro and an EagleTree Guardian due this week. I love them. The Orange and JR are the easiest to use whereas the EagleTree can be as complicated as you make it, but is a very powerful device, as is the Blue Ice. Ask your question here on the dedicated Eagletree Forum. http://www.rcgroups.com/forums/showt...96644&page=200
Good Luck.
PS. Nice plane, I'd hate you to lose it.
Grantham Kid is offline Find More Posts by Grantham Kid
Latest blog entry: A bit about me
Old Jan 26, 2013, 08:20 PM
matiac is offline
Find More Posts by matiac
AMA 994002
matiac's Avatar
United States, RI, Westerly
Joined May 2012
Yes they do help. Immensely. Took an ill-mannered warbird, and made it almost trainer-like in it's habits, but some people would consider it a "crutch", and I suppose if you used it all the time it would be. If you can switch it on/off, and just use it to get the plane in the air, then I don't see where that's really cheating, or using a crutch...
matiac is offline Find More Posts by matiac
Old Jan 27, 2013, 12:59 AM
DustBen is online now
Find More Posts by DustBen
DustBen's Avatar
United States, AL, Birmingham
Joined Dec 2011
Once the airfoil stalls, ailerons are ineffective.
If anything, the recovery method is "nose down", and "throttle open" to regain airspeed so the wing can begin flying so ailerons can become effective once again.
DustBen is online now Find More Posts by DustBen
Old Jan 27, 2013, 09:45 AM
shahram72 is offline
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
I'm pretty sure your controls override the gyro unless the gain is too high, but if you are leaving the stick centered, then yes, the gyro will do it's own thing.
shahram72 is offline Find More Posts by shahram72
Data Which discount batteries are worth the money? fosjef67 Batteries and Chargers 11 Mar 18, 2012 02:34 PM
Question Carbon Props - Are the worth the money ? sharonx Multirotor Talk 6 Feb 10, 2012 11:25 AM
Question Are lipos worth the money?? fatuba99 Electric Plane Talk 147 Sep 04, 2005 06:32 PM
Alert Are rotopods worth the money? k2b2 Fuel Heli Talk 10 Aug 28, 2005 05:50 AM
GWS receivers Are they worth the money ??? yshimoni Radios 6 May 19, 2004 06:51 PM
