Old Feb 10, 2013, 10:00 AM
Fidelity101 is online now
Find More Posts by Fidelity101
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
I was running 3S 5000 mah packs but flight times were 7-10 minutes for some reason. (maybe to cold) so I purchased a 3S 8400mah pack for a good 15 minute flight. I'm pulling about 453mah a minute with the current setup.
Fidelity101 is online now Find More Posts by Fidelity101
Old Feb 18, 2013, 11:37 AM
Go fast, pull up.
Joined Nov 2008
I am STILL getting the toilet bowl effect once in a while. Sometimes it just has a mind of it's own and wants to bank hard right. I am forced to leave GPS mode and go into ATTI mode for a few minutes until I can hover in place and then switch back to GPS mode.
I have no idea what's causing this issue because it's random and it's 50-100 feet in the air, so there can't be much interference around. I was hovering over a friends house and it was rocking back and forth like the gains were to high...not sure what's causing this either since I haven't changed anything and it's been fine for the last 10 flights. But while jittering, it just pulled 10-15 degrees hard right, back, left, forward, etc...into a large toilet bowl effect (TBE) at a faster and faster pace.
If I ever decide to give FPV a try, this is going to be a deal breaker.
Old Feb 19, 2013, 06:15 PM
bighead93 is online now
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
I just tried my RTH this past weekend and it was a bit scary! I hooked up the lipo in the middle of an open field with nothing but me around it. It locked on to the GPS in about 30 seconds. Took off and flew out about 60 feet. Went from ati to RTH, quad leveled and climbed to around 60', turned quickly around and started back. Once it got to about 20 feet from where I took off it began to toilet bowl around me and started to gain a bit of speed so I took over and landed. I tried it a couple of more times with the same results. What am I doing wrong?
bighead93 is online now Find More Posts by bighead93
Old Feb 19, 2013, 06:57 PM
Go fast, pull up.
Joined Nov 2008
If you find out...please let me know because I'm having the same problem!
The one thing I haven't tried is actually calculating the EXACT CG location for the cm measurements within the naza software for the GPS. Mine are "estimated" based on the physical center of the hex...but I can't image that a slight error would cause the TBE.
Sometimes, I've been able to recalibrate the compass and that has reduced or temporarily eliminated the TBE. Also, do you have your GPS rotated to account for the delta between magnetic north and true north? In Buffalo, NY, it's about 10 degrees counter clockwise.
I think Sacramento, CA, is about 14 degrees to the right...or clockwise.
Old Feb 19, 2013, 07:24 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Thanks for the info! I know this is a stupid question but how would I adjust for that? I too am trying to figure this out!
Old Feb 19, 2013, 07:35 PM
Go fast, pull up.
Joined Nov 2008
The arrow on the GPS unit is suppose to point directly forward initially. That arrow is the North point on the built in compass...which oddly enough is also the location where the cable comes out of the GPS unit. (seems backwards)
Anyway, I would start by making that point directly forward and testing it in flight. While in GPS mode fly a straight line. If it starts to drift left, rotate the GPS to the right. Also, visa versa. Once you have it exactly right, it should be able to track a straight line all day long.
Old Feb 19, 2013, 09:33 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
That is how I have mine set now. I do notice that when I switch into GPS that my tail drops a bit and then levels out. Think I might try settin the CG mark a bit further forward in the programming and see if that helps. I will keep you posted and thanks for the help!
Old Mar 01, 2013, 04:09 PM
Go fast, pull up.
Joined Nov 2008
Did the settings change help with your GPS?
I went back out today after investing in 6 new perfectly balanced Carbon Fiber blades. The vibration is GONE...but the TBE is even worse now. It's really starting to annoy me that I can't figure out what the issue is.
In ATT mode, it hovers in place pretty well with zero wind. As soon as I switch to GPS mode, it banks (usually left and then back) into a steeper and steeper bank until it's a good 25-30 degrees of bank and going VERY fast. At this point, I have no choice but to remove GPS mode or face an imminent crash. I'd really like to figure out why it works sometimes and not others.
Old Mar 02, 2013, 06:10 PM
Go fast, pull up.
Joined Nov 2008
Problem "MAY" be solved. I went back and found my actual CG on the Z axis and I was 2cm off. I also realized that, even though the battery was directly above the NAZA, the CG was slightly off center...so the NAZA was about 1-2cm away from the CG. I moved the battery over to the right and got the hexacopter to balance directly over the NAZA and now it works perfectly. I'm not sure if it was the CG balancing or the 2cm change in the software, but I'm not going to play around with it as long as it continues to work.
So far, I've had a 15 minute flight and an 18 minute flight with excellent GPS locking. I can go full speed (about 35-40mph) and then immediately come to a stop with zero TBE. I went up about 56 meters and it just stayed in place for about a minute before I lowered it. Also, the bouncing on landing while in failsafe mode is completely eliminated as well. Not sure if it's because of the CG change, change to the NAZA GPS values, or just the new CF props, but I'm very impressed with this setup now that it's working correctly.
Old Mar 15, 2013, 11:38 AM
Go fast, pull up.
Joined Nov 2008
For anyone following this thread...the issue was my CG being off by about a half inch. Once I moved my heavy battery to the right, the CG was dead center over the MC and the TBE is completely gone. I've had about 15 flights since then without a single issue. :-)
Old Mar 15, 2013, 11:52 AM
Ryan5508 is offline
Find More Posts by Ryan5508
Ryan5508's Avatar
United States, MI, Wyoming
Joined Dec 2012
mine never comes back home. Even though its set to return home it always lands in place. It has only done it one time when I 1st flew it. Since then never.
Ryan5508 is offline Find More Posts by Ryan5508
Old Mar 17, 2013, 08:41 PM
Go fast, pull up.
Joined Nov 2008
Are you putting the naza in fail safe mode? I'm not sure what would cause it to ignore the settings and just land...short of a low battery warning
Old Mar 28, 2013, 12:42 AM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
What props did you end up getting? My RTH is getting better but still need to dial in the CG. Getting closer!
Old Mar 28, 2013, 06:59 AM
Go fast, pull up.
Joined Nov 2008
CG is apparently VERY important. It was off by 1/2" and that's what caused me months of issues. I'm using Gemfan carbon fiber 10x4.5 props and the vibration is very low.
The Gemfan nylon fiber props were horribly off balance at the prop hub which causes serious vibration. I spent a good hour trying to balance them and finally tossed them out once I gave these cf props a try.
Old Mar 28, 2013, 03:21 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Good to hear on the CF Gemfan props as I just ordered a set. How exactly do you figure out the CG? I assumed that the X axis is the front to back and Y/Z are left to right?
Wanted Dji F450 Naza gps with Futaba T8J Venom93corba Aircraft - Electric - Multirotor (FS/W) 4 Mar 22, 2013 11:28 AM
Sold DJI F550 With NAZA GPS and Photohigher AV130 R Hudson Aircraft - Electric - Multirotor (FS/W) 6 Jan 29, 2013 10:31 PM
Sold SOLD DJI Naza 450 with GPS LED and Lipos Tada Aircraft - Electric - Multirotor (FS/W) 8 Jan 15, 2013 10:52 PM
Sold DJI F550 with Naza and GPS flymustangs Aircraft - Electric - Multirotor (FS/W) 3 Jan 13, 2013 12:43 PM
Discussion dji naza with gps and 1.2 ghz downlink issues? ppatron Multirotor Talk 7 Jun 22, 2012 08:26 PM
