United States, SC, Irmo
Joined Sep 2011
Thanks jasmine, you've been a great help. I learned something today. Hopefully I will be able to tweak it good enough to fly. Eventually the head will be changed out to a nice V2 purple one I have and maybe this platform can go in my scale MD500 body. Let's get it airborne first. Tomorrow I will work on repairing my crashed Hausler 450 V2 which needs a new main gear and feathering shaft maybe (those V2 shafts are thicker) The blades look OK, can I reuse them?
mmmm.... it's a judgement call really. I don't re-use blades that have been crashed, but sometimes it's probably ok. CF blades can develop micro-cracks you can't see and that can cause unexpected failures - uh... the blade explodes. So, I don't use them again but I know people who do.
United Kingdom, England, Bradley Stoke
Joined Mar 2001
Just wanted to pop back in to say thanks for the advice given. I moved the balljoint in a little on the servo horn and adjusted my hover pitch to give higher head speed and after about 5 flights today I can confirm I'm no longer suffering the wag or lack of authority.
It's also helped reduce the amount of drift in hovering. It's not completely gone but its very manageable ![]() Now I just need the wind to stop gusting (0-25kph!) and I might get a chance to try a real lift inverted hover! Thanks! |
Joined Mar 2001
Well, it's been going a long time now, I doubt it will get canned anytime soon. On the same note, keep family guy coming our way
![]() Incidentally, after I posted this I took it back out as the wind had died down and binned it on the second battery tail span 270 degrees, then I corrected it wrong and in she went from about 8feet. Ordered a full 450GT v2 kit as they have it in the Uk warehouse. It seems mine was a bit of a v1/v2 hybrid. |
The tail lost control by itself? What all are you running on it now? Don't feel too bad, I crash almost every time when my helicopter does something I didn't command, unless I have lots of room to recover. I have the HK450 Pro GT... it's all "pro" frame and everything, did you order that or the old style with four frames? Reason I ask is because I think the Pro is way better quality - but it's not compatible with the old ones for the most part.
Joined Mar 2001
Yeah, I know it sounds odd but the tail span its self. I'd be inclined to think its the gyro.
Still using the Esky kit while I wait for the orangeRx receivers to turn up. Acer-lab D12-MG servos on everything. Looking to get a spartan quark gyro when funds allow. I ordere the regular 4 piece version as it shares parts with my current one. I might opt for the Pro next time if its much better? Main reason I didn't is its not all CF and alloy like the other one.... Ryan EDIT: this is the one I went for.. http://www.hobbyking.com/hobbyking/s...x_Compat_.html |
This one is metal and CF where it counts...
http://www.hobbyking.com/hobbyking/s...x_Compat_.html Seems to be decent quality also, but I had to change a few things on it. |
Joined Mar 2001
Torque tubes put me off a bit, how do you find them?
Also, what did you replace on it? If I go for one next time ill order the additional parts at the same time. Noticed these are also out of stock which would meant more time not flying
This is before any of the replacement parts, and you can hear how loud it is, but it flies ok.
| Thread Tools | |
| Question First FPV flight tomorrow Radian Pro | DbleX | Video Piloting (FPV/RPV) | 2 | Jan 26, 2013 12:25 AM |
| Discussion First flight.... | s.lagard | Beginner Training Area (Aircraft-Electric) | 6 | Jan 21, 2013 08:55 AM |
| Discussion First attempt backward flight / Fitec tail servo failure | Mellowdave | Mini Helis | 5 | Jan 20, 2013 05:26 AM |
| Video HK450, First Flight (hover), | Vipula AD | Electric Heli Talk | 12 | Mar 03, 2010 09:32 AM |
| Discussion First "flight" (aka Crash!) with HK450 | Glasswalker | Beginner Training Area (Heli-Electric) | 14 | Aug 27, 2009 10:54 AM |
