Old Jan 28, 2013, 05:36 PM
1parrothead is offline
Find More Posts by 1parrothead
1parrothead's Avatar
United States, CO, Loveland
Joined May 2011
It was a guy & his wife & brother that removed the gas regulator into the house,
Changed the thermostat to one that would give off a spark - trying to collect insurance $$$.
These class valedictorian's inquired at the utility company the day before about removing the regulator( ! ), had boarded the family cat, and were at a casino when the explsion occured.
They have been charged with 2 counts of murder.
1parrothead is offline Find More Posts by 1parrothead
Old Jan 28, 2013, 05:43 PM
Robert Pulse is online now
Find More Posts by Robert Pulse
Robert Pulse's Avatar
Davenport, Iowa
Joined Apr 2007
Boom
DUH !
Bet they didn't see that coming
Bob
Robert Pulse is online now Find More Posts by Robert Pulse
Old Jan 28, 2013, 07:00 PM
superinstaller is offline
Find More Posts by superinstaller
superinstaller's Avatar
United States, SC, Greer
Joined May 2006
My wife hates leaks!
superinstaller is offline Find More Posts by superinstaller
Old Jan 28, 2013, 07:12 PM
Joined May 2006
Also my wife complained about the dryer taking twice as long to dry so I took it apart and found the fan housing (had to remove the rear panel while unplugged ) was 50% blocked w dust trash and lint, I cleaned the vent pipe every year too. Now it works like new =O
Old Jan 28, 2013, 08:12 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
I have been soldering copper pipes and larger copper wires (with a tip designed for it) with those little hand held propane tanks for years. Never had one leak yet. I have a couple spare cylinders in the garage and the one working cylinder in the back porch. I always take the torch tip off when I'm done it goes into the top tray of my all all steel plumbers tool box. Where it wont be a problem if its hot.
Glad you got yours out of the house in time.
Also in the garage I have a quantity of plain gasoline, gas mixed 30:1 for the weed eater, Oxy/Acetylene set, a separate Acetylene torch, some kerosene, a 20lb propane tank, a small quantity of nitro-methane glow fuel, diesel fuel, motor oil, various cans of spray paint, starting ether, chlorinated brake parts cleaner, wd40, rust buster, butane, a couple of 20,000BTU wick type kerosene heaters a couple of kerosene salamander type heaters 50,000 and 55,000BTU. Yeah I lite up all the heaters on the rare occasion when I want to work on my car in the winter. The Uprights just run flat out where they don't smell and the salamanders run on a thermostat, a bi-metal moving contact type. And hanging on the wall between the people door and the overhead door is a scared 10Lb ABC extinguisher.
The only accidental fire we had was when the wife put a polyethylene cutting board on top of the kitchen range shortly after using the range. The still hot burner grates set the cutting board on fire. A passing neighbor came in and used the new as in less than a week old 5LB ABC that we keep in the kitchen to put it out. Could have been worse. Just a lot of white powder to clean up and a few new range parts.
Apismelifera is offline Find More Posts by Apismelifera
Old Jan 28, 2013, 08:14 PM
modelerman is offline
Find More Posts by modelerman
Ed Croughwell
modelerman's Avatar
New England
Joined Mar 2007
Here's one.... Just happened yesterday. Her boy friend's plumbing equipment was in her trunk.
http://boston.cbslocal.com/2013/01/2...t-in-stoneham/
modelerman is offline Find More Posts by modelerman
Old Jan 28, 2013, 08:23 PM
Davenport, Iowa
Joined Apr 2007
It may never happen to you but it only takes once.
Old Jan 28, 2013, 08:26 PM
Davenport, Iowa
Joined Apr 2007
Dryer fires
http://www.youtube.com/results?searc....1.EPssTCy-dfo
Need I say more?
Old Jan 28, 2013, 08:47 PM
jwood45 is offline
Find More Posts by jwood45
United States, GA, Alpharetta
Joined Jan 2012
Benzomatic, I think this is the correct brand but not certain, had a recall several years ago for their Mapp gas cylinders. It seems that the neck of the bottle could fail at the weld and possibly explode during use. Check your cylinders folks!
jwood45 is offline Find More Posts by jwood45
Old Jan 28, 2013, 09:14 PM
Davenport, Iowa
Joined Apr 2007
Oops
http://news.consumerreports.org/reca...re-hazard.html
Old Jan 28, 2013, 10:39 PM
Muddyduck is offline
Find More Posts by Muddyduck
USA, NJ, Toms River
Joined Sep 2010
Several years ago it was decided to remove CFC's as propellant from aerosol cans of almost everything. In the infinite wisdom of whoever is in charge of infinite wisdom and cost containment, the CFC's were replace by other compressed gasses. Butane was one of the most common. Have been out of that industry for a good while so I do not know if that continues. If it does and you want to scare @##% out of yourself and the neighbors, hold an open flame in front of a an aerosol of perfume or hair spray and squirt. Remember the James Bond movie. Very open space, please .
Muddyduck is offline Find More Posts by Muddyduck
Old Jan 29, 2013, 07:58 AM
xrx1113 is offline
Find More Posts by xrx1113
xrx1113's Avatar
United States, FL, Lehigh Acres
Joined Aug 2011
ups !!! , pulling the torch off mine as soon as i get home.
xrx1113 is offline Find More Posts by xrx1113
Old Jan 29, 2013, 08:05 AM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
And how about Redi Whip? full of NOS... rubbing alchohol, or your averaged bottle of cooking oil that gets left by the burner and gets super heated.
Its all due to plain stupidity when you think about it, must be some kind of new natural order thing the gods have cursed us with.
ApexAero is online now Find More Posts by ApexAero
Old Jan 29, 2013, 08:14 AM
PropsnWings is offline
Find More Posts by PropsnWings
Scale Aerobatic Pilot
PropsnWings's Avatar
Joined Jun 2011
Originally Posted by Robert Pulse View Post
Lots of people think that those expandible plastic exhaust pipes will work but I dont recoment them as they kink and block the air flow from the dryer, collect lint and puncture easly. I have my dryer hard piped to the outside. You still have to clean them regularly, along with the dryer. The dryer traps (most) are only about 60% efficient at catching all the lint. Run your hand across a little used shelf in the laundry room and if you have a lot of dust you may want to give your dryer a check up.
Bob
Ya had a dryer at the local daycare catch fire from build up of lint inside the dryer. I always take the back off the dryer at least once a year or more and carefully shop vac it out. You'd be surprised how much lint builds up in there.
PropsnWings is offline Find More Posts by PropsnWings
Old Jan 29, 2013, 08:18 AM
CCkiter is offline
Find More Posts by CCkiter
United States, MA, Dennis
Joined Nov 2012
http://www.capecodtoday.com/article/...pane-explosion
I was working in my Store about a mile away as the crow flies when this happened. It was a loud bang. The Driver heroically moved the propane truck away from the fire despite being badly burned.
CCkiter is offline Find More Posts by CCkiter
Discussion Building a Workshop - What is one thing you can't do without in your workshop? Salter Foamies (Kits) 8 Sep 08, 2014 08:59 PM
Sold FMS 5 Channel B-25 bomber with bomb bay C. Alan Aircraft - Electric - Airplanes (FS/W) 8 Jan 26, 2013 01:15 PM
Sold Bomb Drop kit with Bomb shua757 Aircraft - General - Miscellaneous (FS/W) 0 Jan 06, 2013 10:32 AM
Discussion Bomb, bomb, bomb.... bomb bomb Iran! wingbeat Life, The Universe, and Politics 66 Jul 04, 2008 02:54 AM
Discussion Bomb bomb bomb, bomb bomb Iran... Miami Mike Life, The Universe, and Politics 33 Apr 30, 2008 05:12 PM
