Old Jan 26, 2013, 07:59 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
Build Log
200% 90mm EDF Jetset44 Super Bandit sport jet build
Being that i had just finished my AU117 40mm F-35A i dedcided that i will build a sport jet of some type of sport jet for a 90mm EDF powers system i had sitting around doing nothing i may aswell build a plane around it... so after some searching i came across Jetset44's Super Bandit EDF and instantly fell for it so i wrote up a plan of action :
Scale Super bandit plans to 210% for poster printing (52 sheets)
Super Bandit Shopping list:
.C90 12B Replacement blades and Carrier(just in case)
http://www.hobbyking.com/hobbyking/s..._Fan_Unit.html $19
.7 Sheets of 6mm Depron
.1 Sheet of 3mm Depron
.4x 1m long Hollow CF Rods
.Hot glue sticks
.x4 Tubes of UHU Por
.2mm ply & balsa
.5S Capable Lipo Charger
.Retracts and struts?
.Pin hinges
.linkage stoppers
.Wheel collars
.Servo linkage covers
.Finishing Epoxy
.2x Flat 3mm CF strip
[COLOR="rgb(72, 61, 139)"].Wheels[/COLOR]
.Control horns
.Battery straps x2
.Velcro M/F
.High AWG servo extensions
.2mm Drafting Mylar: http://www.hobbyking.com/hobbyking/s...C_1_Metre.html $1.99
.Parklite In Black and Gold
.Multi-tool
.Leaded Solder
.Bullet Connectors
.Lighter
.x2 Sullivan or Dubro FLexi-cable Linkages
To Do List :
.solder on Connectors on motor and ESC
.Solder up Wiring Harness For Wings
.Build and Sheet Wing in Balsa
.build Battery Tray, Wing-box and EDF as One piece (build fuse around it)
.Fit EDF, ESC and Lipo and Route Extensions
.build Fuselage
.build Cooling Vents into Fuse, Just below Canopy and in-front of intakes
.Build the Bandit as Round and Smoothed And Sleek As possible
. Fiberglass Wing
.Cut and hinge Contorl Surfaces
.Decide on Full Flying stabilizer or not
i will print the plans tomorrow and Begin building soon afterward
K
Keenan smith is offline Find More Posts by Keenan smith
Old Jan 26, 2013, 09:26 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Here's build from back in April 2011
SUPERBANDIT..like BVM!! EDF 4.5" now you can made at home!!
http://www.rcgroups.com/forums/showthread.php?t=1417066
photo album link still works
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jan 26, 2013, 06:22 PM
Joined Dec 2010
Edited First post ...
**this post is reserved for a Future update. **
Old Jan 26, 2013, 08:38 PM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Keenan, should be a good build, but, you'll need a larger battery..w
Waltjg is offline Find More Posts by Waltjg
Old Jan 26, 2013, 09:48 PM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
4000 min
D_FAST is offline Find More Posts by D_FAST
Old Jan 26, 2013, 10:16 PM
Joined Dec 2008
In the photo in the first post, of the fan, the caption reads" EDF With 1500kv motor Fitted 2.5kg of thrust which is around 7.6lbs"
The 7.6 lbs should read 5.5 lb thrust. You would need 3.45Kg thrust to get 7.6lbs.
Old Jan 27, 2013, 04:59 AM
Joined Dec 2010
Oops ... Got my menta convrsions wrong.... Ill order another battery in a few days probably a 5000mah 5s 60c nano tech .....
Im goint to b printing the plans laer today so updates will b here a little later on
K
Old Jan 29, 2013, 12:33 AM
djacob7 is offline
Find More Posts by djacob7
Zen in the art of foam
djacob7's Avatar
United States, CA, Fremont
Joined Jan 2009
Watching...
djacob7 is offline Find More Posts by djacob7
Old Jan 29, 2013, 08:58 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
And probably a more robust ESC but you should be able to verify when testing the power set-up on a test stand.
alexandermh is offline Find More Posts by alexandermh
Old Jan 29, 2013, 09:25 AM
Joined Dec 2010
On 5s i was drawing 95A WOT so for 6s operations ill upgrade to a 120A HV Esc ...
Old Jan 29, 2013, 11:49 AM
Fairborn, OH
Joined Nov 2009
Good idea. It's always a good idea to have a little head-room (and not rely too much on the ESC rating).
Old Jan 29, 2013, 06:56 PM
Waltjg is offline
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Keenan, when dealing with the EDF's and especially anything over a 70mm, your going to have to think of high amps, hi voltage, high capacity/C rated batteries. Everything on something like this is high capacity right down to the connectors you use. I noticed you had an XT60 on the 100 amp esc,, not big enough, go to 4mm bullet connectors, you'll find that that is what the larger batteries come with. Good luck, w
Old Jan 29, 2013, 07:34 PM
Joined Dec 2010
Yup.... Those are xt60's i have ised these up to 75a and they worked fine, but being that i wont even be using that edc in the plane any more i may aswell solder on the connectors i use.
I will be ordering either a CC 120A HV ESC or a Red Brick 120A HV ESC and soldering on some 4mm bullet connectors, (being that red brick has served me well in the past (i may go for the R.B. Esc ) and a larger capacity lipo e.g. Nano tech 5000mah.
Im considering skipping the 5s operations and going straight for 6s (my motto is more power for a reason!)
k
Old Jan 29, 2013, 11:17 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
subbed.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Build Log Jetset44's Super Bandit EDF Mac8 Foamy EDFs 2060 Sep 06, 2016 03:32 PM
Wanted EJF Sport Jet 90mm CARL SCHIMNOWSKI Aircraft - Electric - Jets (FS/W) 0 Jan 15, 2013 12:23 AM
For Sale 101mm edf can also be used for 90mm jets 30shiped sherlockshah Aircraft - Electric - Jets (FS/W) 0 Jan 12, 2013 01:00 AM
Discussion Min-E-Bandit 90mm Sport Jet Build Tumbler Foamy EDFs 28 Jan 29, 2007 11:33 AM
Video JetSet44's Super Bandit EDF Planted. King_Ice_Flash Electric Plane Talk 3 Sep 04, 2006 10:48 AM
