Old Jan 26, 2013, 06:40 AM
davereap is online now
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Building Micro and Lightweight RC kites and models using CF Rods and fabric/film
I started indoor flying only recently and have been exploring the smaller model designs that are available...
One of my favorite ultra light models is the Vapor , which as you know is a CF and film build and is an easy slow flier.
It occurred to me that since lightness is a major factor in any these indoor models, and ,as the vapor uses the CF and film construction, that some of my larger kites designs would do very well in the indoor venues when made at reduced sizes
My definition for any kite is that it should be a rod and fabric/film build..
So this includes flat kites and more normal plane shapes like the vapor
For indoors a lot of indoor venues, they now have weight limits with about 100gms as the top limit, but for general use lightweight to me goes up to double that
davereap is online now Find More Posts by davereap
Old Jan 26, 2013, 06:49 AM
davereap's Avatar
Joined Feb 2005
My night kites thread is here, and through it you will find redraws of various rc kites...As well as some foamies that were rebuit in kite style
http://www.rcgroups.com/forums/showthread.php?t=987191
The simple kite was my starting point for a smaller version
Inspiration when I started redrawing, came from the IFO and LiteBug
A mix of the 3 is giving very good results
Here is the basic 'simple' as a starting point... at this size it will fly in larger indoor venues...
Old Jan 26, 2013, 07:06 AM
davereap's Avatar
Joined Feb 2005
here is the design processed through a series of redrawing and rebuilds
V1 lines was built exactly as seen .. but missed on the plan, is the size of the bracing rod on the elevons, this was 2mm CF and the horn was fixed to this rod... the holographic foil is just UHU glued to the rods , it was not shrunk, although it will heat shrink..
the structure is well light, stiff and strong...
but I was trying to go lighter...
V2 built as seen.. and although I used narrower rods and a lighter film covering the weight ended up again at 35gms AUW..
The extra bracing rods and a set of wheels added the weight back on..
V2 flies fine... although it is slow in the roll it cruises arround about half again as fast as a vapor on a 5gm motor at less than half throttle... lovely, smooth and easy, it will loop from level cruise
Old Jan 26, 2013, 07:25 AM
davereap's Avatar
Joined Feb 2005
Now was the time to be critical..
V2 flies good but....
Looking at the V2 there are a couple of things that can be improved...
The leading edge can come forward by at least 1" with the new position still leaving enough room to fit the prop in the front open area curve..
The pushrods go out at an angle.. it works fine but a straighter run would be better.. The bracing rod where the horn is fitted can be moved in closer to the end of the curved aileron...
This lets you fit the two rod ends onto one longer hinge tube, now you dont need the horns rod to be so big..
the redraw to a V3...
Old Jan 26, 2013, 07:35 AM
davereap's Avatar
Joined Feb 2005
Flying the V2... was lovely..... the COG was set at 70mm back from the leading edge...
The model was slow, smooth and easy, it could do very tight circles, loop from cruise, but it was slow in the roll..mostly becaue it was flying slowly and I lacked the power get it to speed and to use the motor in high alpha maneuvers...
Our hall is unheated and at zero degrees it just kills my little 1 cell lipos....Back at home, in the warm, I have loads of vertical
Old Jan 26, 2013, 07:41 AM
davereap's Avatar
Joined Feb 2005
The V3 will be passed by as a result of the way the V2 flies.....the V2 is slow and easy..the V3 should be even slower and more docile which for me is going the wrong way...
To improve the roll I have again redrawn....its now a V4... by slightly reducing the area down to 1sqft it will have to go a touch faster..Ive kept the length the same but reduced the span... longer narrower models should roll faster..
this the V4....
Old Jan 26, 2013, 08:13 AM
davereap's Avatar
Joined Feb 2005
the vapor..features an all flying tailplane and rudder and is where I am going ...all flying surfaces give best control at the low speeds..so how about a cross between the vapor and the carbon traveler and a kite...
The vapor is too fragile for aerobatics, but works well
The traveller is just a bit big for what I want... the original has a quoted 50+ft of CF in its build, so that is expensive
yes they are now plane shapes... but rod and film.. so a new thread is started for the plane shaped models
http://www.rcgroups.com/forums/showthread.php?t=1822911
Old Jan 26, 2013, 10:08 AM
davereap's Avatar
Joined Feb 2005
Strength.... a mid air with a 3d model caused the damages shown in the pic... first flight... mine crashed and bounced, the 3d carried on for a couple of seconds then his prop disintegrated and he crashed...we all laughed.. its just too many models in too small a space..
all great fun...
All my rods were fine and I carried on flying with the film flapping, it didnt seem to make any difference...I need to remember the tape next time
Repairs...
With the depron down the middle each side is covered seperately, so its easy to fix.. it takes a while though as the material is well held on by the UHU...first remove the film, then remove the old glue, that takes a while.. the new cover then doesnt take long to fix and shrink
next job....lights
Old Jan 26, 2013, 12:47 PM
davereap's Avatar
Joined Feb 2005
Thinking of an all flying model......more thoughts on the design this a kite crossed with a plane fuz..
Old Jan 30, 2013, 08:14 AM
davereap's Avatar
Joined Feb 2005
here is a biplane version, with all moving surfaces...18" span and 1.8sqft of horizontal area..use different rod sizes if you feel they are more appropriate
Moved to new thread here
Old Jan 30, 2013, 12:37 PM
davereap's Avatar
Joined Feb 2005
The version2 kite that had a midair was recovered and now ive added lights...
3 leds each side plus an 85Mah lipo to run them.. .the AUW is now 40.5gms..
Adding the little lipo is usefull because it was flying nose heavy.. now its spot on my predicted COG..
The lights are running at very low amps, nowhere near their optimum ..
edit.. in fact my predicted cog is too far back, its nicer flying a bit forward, and it loops well from that position, with very tight turns, but rolls are still a problem..I am thinking the elevons act as brakes, and half way through the roll the airspeed is down too low to get the roll continuing...more power will be the solution but its so nice and easy as it is.. the lights are visible but perhaps a bit dim with hall lighting on
Old Feb 01, 2013, 12:09 AM
davereap's Avatar
Joined Feb 2005
started on the all flying frame
Ive a new thread started for conventional plane shaped models in CF and film
here...
Old Feb 01, 2013, 12:17 AM
davereap's Avatar
Joined Feb 2005
My flying buddy wants an easy flier so I have drawn up a Vapor type for SU micro gear..gone to double the Vapor area as the SU setup is a lot more powerfull....
edit....I will do a build log for this as its turning out very nice for the micro ar6400 gear, and put it over in the indoor section..
Calling it the Whisper..@20"span...here are its pictures..as seen in the final pics it weighs 27gms now... so it should end up at 40 or so as he also wants some LEDs put on it... cheeky S** that he is ....lol
Here is the build log for the Whisper and its a new thread for the non kite models I am developing...
maiden.
The Whisper..Indoor micro model (1 min 4 sec)
Old Feb 12, 2013, 11:22 AM
davereap's Avatar
Joined Feb 2005
I had this frame already built but decided it would be good with a 10g motor and lightweight gear..It had too big an area for the 1 cell setup , and was plenty strong, so I thought 2 cells and some light gear would be better suited..
Ive used a 2 gm orange micro dsm2 rx with 3 x2gm servos and a 6A esc and 10gm motor..all is working fine..
next to cover the wings and fit the elevon pushrods
The rods used were 3mm main fuz, 2mm spars and 1.5mm for the main curve and bracing... 1.5mm for the elevon bends
Old Feb 13, 2013, 10:48 AM
davereap's Avatar
Joined Feb 2005
This latest simple has worked out well... The AUW is 90 gms with a 300 2s lipo. The little 10gm motor has more than enough thrust for vertical and draws under 3A using a 7x3.5gws prop..
Its one of those models where it all feels right...
The 18micron bag material went on with a few creases, but an iron at 107-110 degrees will shrink it nicely as can be seen in the pictures
The AUW is 90 gms exactly.. so its very close to 2ozsqft in its wing loading
Link RC kite build logs.. show your kite and link it to your build log davereap RC Paragliders and Kites 19 Mar 31, 2016 06:03 PM
Question Has anybody scratch built these RC acrobatic Kite designs from Singapore? Amazing!! Nucc10 RC Paragliders and Kites 3 Apr 01, 2013 05:40 PM
Help! Lightweight Fabric Covering Tom Smith Giant Electric Planes 14 Jan 10, 2013 05:31 PM
Discussion Using Power Kites for RC Paragliding NCSU12Aero RC Paragliders and Kites 1 Jan 03, 2013 09:55 PM
