Old Jan 28, 2013, 12:02 PM
600Bob is offline
Find More Posts by 600Bob
United States, OR, Canby
Joined Aug 2011
Originally Posted by Fig Newton View Post
I have to agree with Eflightray and David Hipperson here. Coming from an internal combustion background, you simply DO NOT put your fingers in the path of the prop. In my opinion and what I am reading on various forums, starting in the hobby with electric powered planes it seems that people tend to get a different complacency about the engine and yet it can and will bite, sometimes with serious results. Expecting the transmitter or even the speed controller to keep you safe is a gamble at best. When the battery is connected you should treat your engine like it is running. That's where coming from a gas background makes this easier to do.
The difference here is that an IC engine doesn't start if you happen to bump the throttle stick. It's not just about fingers, you can be behind the plane doing a control check and bump the throttle and have it takeoff, same with an IC engine, having and "off" switch can increase safety by one more level. It's a common feature with electric helicopters and the DX6i supports that feature in heli mode so why not in ACRO too? It is supported in the DX8 and I use it for my few electric planes.
Having a feature doesn't mean you have to use it, but not having it means you can't.
600Bob is offline Find More Posts by 600Bob
Old Jan 28, 2013, 05:01 PM
Mark Harper is offline
Find More Posts by Mark Harper
United States, IN, Evansville
Joined Feb 2006
try a mix
Just use this mix to put your throttle hold on the Aux 2 switch and then you won't have to butcher up your radio.
AUX2 -> THRO
RATE: -100% / 0%
SW: ON
OFFSET: -100
Mark Harper is offline Find More Posts by Mark Harper
Old Jan 28, 2013, 06:18 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
AUX2 -> THRO
RATE: -100% / 0%
SW: ON
OFFSET: -100
so you move the esc plug to aux2 then do that mix ? Sweet !
fastfwd is offline Find More Posts by fastfwd
Old Jan 28, 2013, 08:54 PM
600Bob is offline
Joined Aug 2011
AUX2 -> THRO
RATE: -100% / 0%
SW: ON
OFFSET: -100
The DX6i does not have an AUX 2 switch. Only the D/R, gear and flap switches are available in the Mix menu. I tried a Mix using Gear>Thr. and couldn't get it to work.
Old Jan 28, 2013, 10:50 PM
Fig Newton is offline
Find More Posts by Fig Newton
Fig Newton's Avatar
United States, TX, Burnet
Joined Jan 2013
Which is exactly why the posts I agreed with and then commented on state that you should treat the electric engines as "on" when the battery is connected. I think we are splitting hairs here though. I get your point in asking for an extra safety measure when dealing with electric motors. But it still boils down to the individual taking the appropriate safety measures when working with either a running glow motor or a powered up ESC and electric motor. I was testing some radio changes to my Corsair the other day. Instead of having to worry about a prop catching me off guard I just removed it. I put it back on when I was done making radio adjustments. You can put in all the switches you want but at the end of the day the only way to truly guarantee you won't lose a finger in the prop is to keep it out of the area the prop is in. Don't get me wrong, I am all for safety features, but when you let them lull you into being complacent you are asking for an accident.
Fig Newton is offline Find More Posts by Fig Newton
Old Jan 29, 2013, 12:03 AM
mutski is offline
Find More Posts by mutski
mutski
United States, AK, Fairbanks
Joined Jan 2011
If you bind the Dx6i to your plane, then turn it off while leaving the airplane battery connected, it binds again almost instantly when you turn it back on. No need for a throttle hold for airplanes - just shut off the transmitter, do what you want to the plane and turn it back on. Easy, safe, doesn't require soldering.
I too have tweaked the throttle with the neck strap. For that reason, I now turn the transmitter off as soon as the plane lands. No problem then to carry the transmitter when I retrieve the plane. I usually fly till the battery needs changing, but if I want to launch again, I just switch the transmitter on and it binds in a flash.
Throttle hold makes more sense with helis - a quick disconnect for the rotor when you know it's about to crash. With planes, there is more time to recover, and if they crash, the spinning propeller doesn't do the same damage as a helicopter rotor.
mutski is offline Find More Posts by mutski
Old Jan 29, 2013, 12:07 AM
600Bob is offline
Joined Aug 2011
^ Be prepared to catch heck for turning off the TX while the RX is still powered up.
Old Jan 29, 2013, 01:51 AM
rcmaverick is offline
Find More Posts by rcmaverick
rcmaverick's Avatar
Australia, NSW, Sydney
Joined Mar 2012
Putting a switch is by far the most elegant solution. You just enable throttle cut on all your models and off you go.
Connect everything and just before launch set the throttle to ON
After landing set the throttle to OFF and then do whatever you need to do.
rcmaverick is offline Find More Posts by rcmaverick
Old Jan 29, 2013, 02:20 AM
mutski is offline
mutski
Joined Jan 2011
I guess if they wanted me to leave the tx on they'd have made it possible to use throttle hold with an airplane.
PS - What's the risk? Could the rx bind with a different tx if I ever flew with another RC pilot nearby?
Old Jan 29, 2013, 11:48 AM
600Bob is offline
Joined Aug 2011
Well actually I think the risk is minor. However if someone did not properly setup the throttle failsafe turning off the TX first could cause the motor to go to full power, also if the ESC has auto low stick detection it might cause some issues, I found that out while setting up a CP heli once.
Old Jan 29, 2013, 08:05 PM
bigblueswope is offline
Find More Posts by bigblueswope
bigblueswope's Avatar
United States, GA, Loganville
Joined Aug 2012
Not so fast there my friend...
Depends on the receiver and ESC.
Some of my planes, turn of Xmitter and no issue.
One of my planes, turn off the Xmitter and the motor starts up.
The only way to ensure an electric motor doesn't bite you is to disconnect the power.
bigblueswope is offline Find More Posts by bigblueswope
Old Jan 29, 2013, 09:20 PM
600Bob is offline
Joined Aug 2011
If you are using a Spektrum RX and the motor starts when you turn off the TX then the failsafe isn't programmed, rebind the RX and it should work correctly. If using some other RX then I don't know.
Old Jan 29, 2013, 10:39 PM
Steve 0 is offline
Find More Posts by Steve 0
Slope-a-Dope
Steve 0's Avatar
United States, UT, Draper
Joined Dec 2012
Good thread topic for a noob who bought the DX6i. I tested the throttle chop button while checking out the TX and thought a universal throttle kill toggle switch for all models bound to it would have been a better idea.
Reminds me of my Global Sun solar oven I purchased a while back and baked some brownies in it around the time of the winter solstice to see how it performed in low sun. Just like spinning props on gas or electrics...they both "bite" when you get too close....the thermometer on my oven read 250F when I pulled the fully baked brownies out and brushed my wrist against the "no gas or electric juice" oven wall. ZING! Burnt wrist.
I've already had a shirt sleeve brush the throttle stick inadvertly. Lucky me, it was my Mini Vapor sitting on the ground in front of me. Still a wake up warning to be more alert.
Steve 0 is offline Find More Posts by Steve 0
Old Jan 29, 2013, 11:23 PM
Joined Aug 2012
They're HK Orange 6 channel RXs.
I'll try rebinding, thanks for the tip.
Old Mar 25, 2014, 11:50 AM
Suko is online now
Find More Posts by Suko
Suko's Avatar
United States, WA, Mukilteo
Joined Apr 2013
I've heard that if you install a toggle switch on throttle hold that you need to go back through all your models and set sum throttle sub trim to prevent the motors from spinning at 0 stick throttle. Is this true?
Suko is online now Find More Posts by Suko
Discussion How Do You Throttle Calibrate an ESC with Red Wire Cut daskim Multirotor Electronics 1 Jan 14, 2013 01:05 PM
Discussion Ice 100 cuts off at high throttle delta2001 Power Systems 6 Jan 07, 2013 11:51 AM
Question Spektrum DX6i Throttle Cut and Throttle Hold sonicserve Mini Helis 31 Feb 02, 2012 11:47 AM
Mini-HowTo DX6i Throttle Cut Tip daylight99 Electric Plane Talk 7 Jan 24, 2009 09:26 PM
Discussion DX6i Throttle Cut - Throttle is now stuck "ON" Hemoglobin Radios 1 Sep 13, 2008 11:47 PM
