Old Jan 25, 2013, 10:38 PM
candy76man is offline
Find More Posts by candy76man
alienfpv, warpquad, goby180
Tampa,FL
Joined Dec 2003
phoenixrc and 2603 walkera radio problem
Hi, I'm trying to get my 2603 walkera tx to work with phoenixrc v4 but can't figure one thing out.
When I switch to idleup on the tx the pitch won't go negative, it goes down to center when I am at mid throttle properly but then goes back positive instead of negative like it should to allow inverted flight. Any ideas what could be causing this? I'm sure it's something simple but I haven't been able to figure it out.
I have a 2801pro that is working fine with no fiddling beyond the standard calibration wizard.
candy76man is offline Find More Posts by candy76man
Old Jan 26, 2013, 11:08 AM
Tampa,FL
Joined Dec 2003
No ideas anyone?
Everything works fine except idleup. Let me see if I can explain a bit clearer.......In idleup it has a V curve for throttle like it should but the pitch goes from neutral at midstick to full positive pitch at top and bottom...it should go into negative pitch as I drop the throttle below midstick but it's going positive instead so the pitch curve looks like a V, instead of a / which is the way it should be.
Old Jan 28, 2013, 03:53 PM
Tampa,FL
Joined Dec 2003
surely someone has run into an issue like this before? or have I yet again been the victim of a unique one of a kind problem that no one has ever had before?
Old Feb 05, 2013, 12:36 PM
flyingfinn is offline
Find More Posts by flyingfinn
Joined Feb 2013
WK 2603 w/ Phoenix
I have Phoenix 3.0 and have the same problem with the 2603. At one time, I could enable 3D flying by hitting the "3" key, but my 8 year old son must have disabled it and it no longer works. Did you ever find the solution with your 2603 & Phoenix?
flyingfinn is offline Find More Posts by flyingfinn
Old Feb 11, 2013, 04:59 PM
Tampa,FL
Joined Dec 2003
No, I feel like it should work since the 2603 is a 6 channel radio but I guess there is some limitation or special setup required that I can't figure out.
Oh well, it is for my dad to use with a sim and he's mainly interested in fixed wing and may try a heli or two but I don't think he has much interest in helis....It just bugs me that I can't get it to work
Help! quad radio help Walkera 2801 pro Sodbust Radios 1 Jan 26, 2013 12:11 PM
Sold Walkera WK-2801pro 2.4G 8-CH Radio w/lipo,case, and blue anodized thumb knobs! stretch1100 Aircraft - General - Radio Equipment (FS/W) 5 Jan 25, 2013 04:14 PM
For Sale walkera 2402 radio for sale Jsejalisco Aircraft - General - Radio Equipment (FS/W) 0 Jan 16, 2013 10:50 AM
For Sale Walkera 2603 Radio/rx And v400 Upgrades penz83 Aircraft - General - Radio Equipment (FS/W) 2 Apr 25, 2012 10:04 PM
Sold Walkera V120D03 & CB100 W/ WK-2603 TX Walkera V120D03 & CB100 W/ WK-2603 TX PSP Doppleganger Aircraft - Electric - Helis (FS/W) 2 Feb 23, 2012 03:26 PM
