Old Feb 16, 2013, 01:35 PM
electrontube is offline
Find More Posts by electrontube
Joined Jul 2012
I'm using the atmega 8 , the circuit diagram will not work for the atmega8 , you need to download the pin diagram for the atmega8 and install the xl and power ....risitors. ...and then it will work the schematic is for the 48 and the atmega8 pins do not match.
and the analog circuit works just fine too maybe not as good as microcontroller. need to take off a few parts and it's 1 work for 2 batteries not 3 and it works fine with 2s batteries
electrontube is offline Find More Posts by electrontube
Old Mar 08, 2013, 08:34 PM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
hey Bruce abbot
I did successfully with atmega8 smd ( use crytal resonator )
I see ,LED on, when plug in output mtor brushed, LED off ,and when convert signal LED On ( version 0.6 )
Is it work that way?
pusle sinal is 1.1ms and 1.9ms ? why 50% joystick of tranmiter is motor start run , 100% jostick motor run 80% speed ?
I use esc brushless tunygy 30a .( I convert brushed to brushless for helicopter my f45 )
thank a lot
fantasy1988 is offline Find More Posts by fantasy1988
Old Mar 09, 2013, 12:39 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
The LED will be fully on when the PWM input is at zero volts. When the motor PWM is connected the LED will vary in brightness depending on the PWM ratio (0% PWM = off, 100% = full brightness).
Perhaps the PWM signal is distorted and not being properly measured. Measure the PWM input voltage with a multimeter and record the values for different stick positions. What voltages do you get at:-
Low throttle?
50% stick?
100% stick?
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Mar 10, 2013, 09:18 AM
Joined Oct 2012
thanks BRUCE
led on/off by PWM signal
I am set up esc min THR and max THR , it is work well
I will make two circuit for my helicopter f45
Old Apr 18, 2013, 02:56 AM
Hasi is offline
Find More Posts by Hasi
Hasi's Avatar
Austria, Stmk., Graz
Joined Sep 2011
Hy Bruce!
Could you please also make a FW for the Atmega8 using the internal oscillator (8MHz)? It would be really helpful...
edit. I don't need it anymore, as it is possible to flash the escs.
Hasi is offline Find More Posts by Hasi
Old Apr 18, 2013, 10:11 AM
Joined Oct 2012
Originally Posted by Hasi View Post
Hy Bruce!
You should use external fluctuations, its stability
I met a lot of cases errors chip oscillator because frequency deviations
if you still want use internal oscillator 8mhz , yo need Fuse bit for atmega before load program
Old Oct 25, 2013, 11:27 PM
rc my life is offline
Find More Posts by rc my life
Joined Nov 2012
hello Bruce
I can increase speed the conversion ? software currently speeds slow ,so it is suitable for convert Motor main .
But motor taill is need speed quick
where is command line change speed convert in code ? I am not yet understand
rc my life is offline Find More Posts by rc my life
Old Oct 27, 2013, 08:25 AM
Joined Jan 2001
Originally Posted by rc my life View Post
hello Bruce
To improve the response speed you can increase the servo output pulse frequency in the source code. Most ESC's can handle 200Hz.
Code:
.EQU	FRAMETIME = 10000-1 ; Servo pulse repetition period (40000=20mS)
                            ; Reduce this value to increase frequency,
			    ; eg. 10000 = 200Hz (OK for Hobbywing ESCs)
Old Apr 27, 2016, 08:28 AM
sammywhiskas is offline
Find More Posts by sammywhiskas
Joined Apr 2016
Udi u818s quadcopter
HI FOLKS, I HAVE THREE UDI U818S, MY NEIGHBOUR TOO...GREAT FUN BUT THE MOTORS ARE PRETTY RUBBISH...A COUPLE OF HOURS AND THEY ARE TOAST. THERES HUNDREDS OF THESE ABOUT.....HAS ANYONE CONVERTED ONE TO BRUSHLESS ?....PHYSICALLY LOOKS POSSIBLE, I'M A LAYMAN THOUGH SO FIND IT DIFFICULT TO UNDERSTAND THE TECH JARGON 1000mAh 3.7v x2.....THESE MOTORS ARE GEARED DOWN. I FOUND A THREAD SAYING THE LOAD SPEED IS 5200RPM AND 652 GRAM THRUST PER MOTOR, NOT SURE IF THATS CORRECT THOUGH.
MAYBE I SHOULD TRASH THE LOT AND START AGAIN...YOUR COMMENTS APPRECIATED.
sammywhiskas is offline Find More Posts by sammywhiskas
Old Sep 22, 2016, 04:02 PM
Josegonzalez1985 is offline
Find More Posts by Josegonzalez1985
United States, PA, Apollo
Joined Sep 2016
Is there a way to do this conversion on say an inductrix that uses just +- connection for the motors
Josegonzalez1985 is offline Find More Posts by Josegonzalez1985
Discussion circuit to go from brush to brushless motor electrontube Multirotor Talk 2 Jan 25, 2013 05:43 PM
Discussion Is this the only ESC compatible with Brushless and brushed motors? Bigbond Electric Power Cars 7 Jan 23, 2013 01:54 PM
New Product Unique Walkera V400D02 / V370D05 and RX2614V Brushed to Brushless Motor Converter BlueHorizons Product Announcements 1 Nov 18, 2012 11:02 AM
Help! Converting from Brushed to Brushless Motor shah Electric Plane Talk 19 May 04, 2009 11:50 PM
can astro gearboxes be converted for brushless motors Joel K. Scholz Power Systems 5 Mar 19, 2005 01:51 PM
