Old Jan 25, 2013, 09:08 PM
electrontube is offline
Find More Posts by electrontube
Joined Jul 2012
can I convert a brushed motor to brushless
I made this question in a different area ., but not sure if i was understood or was asking in right area . have few questions and hope i will get the answer .
If i have a quad copter the cheep ones for $50 from china whatever brand ...etc they have small brushed motors ., however these motors go bad after a while.
can change the motor all 4 for example to different ones and the cycle continues., however, . if i want to install brush less small motors i have few small ones and i do have the control units for them .can i build a small circuit where i can go from the + and - wires for the brushed motor to the control unit for the brush less motor .
electrontube is offline Find More Posts by electrontube
Old Jan 25, 2013, 10:47 PM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
A store-bought voltage - PWM converter (goes between the brushed ESC and the brushless ESC)
http://www.miracle-mart.com/store/in...oducts_id=3949
A thread doing similar things with a micro heli:
http://www.rcgroups.com/forums/showthread.php?t=1500927
If you can find a PWM for each brushed ESC somewhere (on the controller board, or between the controller and ESC if they're off-board), you can just feed that straight into the brushless ESC.
Odysis is offline Find More Posts by Odysis
Old Jan 26, 2013, 12:38 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
One thing to watch out for is that the brushless converter needs to have fast response. I tried using the Extreme converter to drive a brushless tail motor on my GWS Mini Dragonfly helicopter, but it was much much too slow and the gyro could not the tail steady. To fix this this I wrote my own firmware and loaded it into the converter.
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Jan 26, 2013, 12:50 AM
fantasy1988 is offline
Find More Posts by fantasy1988
Joined Oct 2012
fimware use ATMEGA48 ,you can convert to ATMEGA8 ?
it is compatible with many types of 4in1?
can show me the schematic? i do not understand connect input PWM with code
; Atmega48 with 16MHz ceramic resonator.
; LED on PC2 (pin 25), connected to GND via 1k resistor.
; Motor PWM input on PD6 (pin 10), low = motor on.
; Servo pulse output on PB1/OC1A (pin 13)
thanks Bruce abbot
fantasy1988 is offline Find More Posts by fantasy1988
Old Jan 26, 2013, 12:57 PM
Joined Jul 2012
as a start this great info.and thank you all indeed for the time and response.,
., so the link to the converter you say ., however there is a note on that site This converter is NOT suitable to use on Blade MCPX., i think the mcpx is something to what i will be doing .NO
, and according to the 2nd response by bruce it will work but too slow ., need to modify ?.
the IC on the converter is an Atmega of some model..., and needs to be replaced ,and program the new atmega with the code he wrote.??
if that is the case ,and worked for (bruce ) would you please provide me all information for to complete the project ..what IC do i need to modify the board ....etc
2.odysis is saying if i can tap into the the quadcopter board somewhere and feed the brushless controler... is that what he is saying ,?
if so. so i have to just do trial and error until i reach that pin on the board .., that is if there is a place to tap.
again for real nice work people . just need more and complete info to start the project.
sincerely
Old Jan 26, 2013, 01:14 PM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
Some time ago I developed a direct motor-PWM to brushless software for a commercial ESC.
Here is the page:
http://home.versanet.de/~b-konze/blc_6a/blc_6a.htm
and this is the appropriate software:
http://home.versanet.de/~b-konze/blc...cp_pwm_r02.zip
It is important to feed in the motor signal in the right way. If you use more than one lipo, it is necessary to adapt the motor signal to input port of the atmega8.
quax
quax is offline Find More Posts by quax
Old Jan 26, 2013, 02:29 PM
Joined Jan 2001
Originally Posted by fantasy1988 View Post
fimware use ATMEGA48 ,you can convert to ATMEGA8?
Converting to ATMEGA8 should not be difficult.
Yes. It automatically adjusts to the incoming PWM frequency.
The circuit is powered from the brushless ESC's BEC (via the throttle servo plug) but the PWM + input is connected to the original brushed motor's power supply. R3 and R4 reduce this voltage down to logic level, and are the correct values for 2S Lipo. If you are running 3S Lipo then the value of R3 should be increased to 2.2k Ohms (to keep the input voltage at pin 10 below 5V).
I just realized that the code on my website is out of date.
Here is the latest version.
***EDIT***
Found bug in V0.3 code - analog comparator's inverting input was being forced to ground (worked OK on the bench, but unstable in heli!) Now updated to V0.4. Also included hex files for ATmega48, and ATmega8 (untested).
Last edited by Bruce Abbott; Jan 28, 2013 at 04:21 PM. Reason: Corrected circuit diagram, updated code to v0.4
Old Jan 26, 2013, 03:06 PM
Joined Jan 2001
Originally Posted by electrontube View Post
This converter is NOT suitable to use on Blade MCPX.... according to the 2nd response by bruce it will work but too slow
Correct. Co-axial helis have gyro control of motor speed, and the stock Extreme converter is too slow for this use (it's fine for single rotor helis where main motor speed is controlled manually by the pilot).
The MCU does not have to be replaced - the existing one just has to be re-flashed (there are pads on the pcb for connecting to the programming pins - see picture below). Alternatively you could make your own board from scratch. You just need an ATMega48 chip, a 16MHz crystal or ceramic resonator, and a few resistors and capacitors.
Flashing your brushless ESC with quax's code is an is even simpler option (you just need to make the voltage divider to cut down the input voltage) but you can't go back to the ESC's original firmware, and it only works with ESC's that have an ATMega8.
"cheap ones for $50 from china" probably do all their processing internally, and don't don't have any place to tap into.
Old Jan 26, 2013, 03:14 PM
Joined Jul 2012
this is very exciting I love this. Thank you for all these great replies suggestions...etc
Bruce just to make it clear. I still need to buy Brushed to Brushless Signal Converter from the store, the link I was provided, and then replace the atmega on board with the atmega schematic the one you have placed here
Just by looking at the schematic you have provided ,it looks as a complete circuit board for the whole project ., has input output the whole thing, i do not see the rest of the control unit in there ...
don't need to buy any converter. Your schematic is complete working circuit ?? do i understand you right .? or im not as ok with electronics as i thought.
either or so know i need to look for a programmer or find the one i have or build one ., hey maybe buy the atmega too. please bare with me here
sincerely
Old Jan 26, 2013, 03:43 PM
Joined Jan 2001
You can either buy the Extreme converter and modify it (connect pin 30 to pin 13) or get your own components and wire them according to my circuit.
The only other hardware you need is a programmer. I used a simple AVR isp parallel port programmer with PonyProg.
Old Jan 26, 2013, 04:18 PM
Joined Jul 2012
ok great as soon as I'm home in few I'm getting started and I'll keep you updated i know this will be great to see it working, i can modify my quadcopter to brushless , that is great.
I'll keep you updated sincerely
Old Jan 26, 2013, 05:22 PM
Joined Jul 2012
One more question if i may ask . i found few atmega 8and 128 in my junk collection . ...the old days when i used them., you are using atmega 48 .
the question can i use the atmega 8 or atmega 128 instead of the 48
... and of course your code was build for the 48 .ofcourse if they are the same great i dont need to wait a week to place an order .. shipping the order ..etc
if they all the same.? what do you need to change in the code so it will work with the atmega 8. or the 128 .
anyhow i want best results so if i need to buy i will buy the Atmega 48 i will buy few
sincerely
Old Jan 26, 2013, 05:47 PM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Now there all great idea's and do work.
Brushed controller > Converter >Brushless ESC > Brushless Motor
Used both options that Qaux made there great.
Tools
AVR's (mcu)
Programmer USBasp or printer port cheap (have used it without resistors but you shouldn't) Could even use Arduino as an Programmer
Other way
Brushed controller > Brushless ESC > Motor
This time using Silabs based ESC guessing you want small and cheap 2g esc
Tools
Arduino UNO or Arduino Mini Pro.
Cable
Software https://github.com/bitdump/BLHeli
Thread to help with problems http://www.helifreak.com/showthread.php?t=390517
Other thread for programmer / Setup software http://www.olliw.eu/2013/ardubox/
I'm doing a multiWii using 2g esc and 2g hexTronik
Ok the motor can be bad (buy extra) mostly because there so small and soldered cables do come apart but!! when you get that sorted using SSkaug code is a joy, Olliw inter face/ programmer makes changes super simple.
SadSack is offline Find More Posts by SadSack
Old Jan 26, 2013, 06:07 PM
quax is offline
quax's Avatar
NRW, Germany
Joined Apr 2004
SadSack, you are right, I also think that this is the best solution.
My software is somewhat "overaged"
BLHeli should be the choice.
Old Jan 26, 2013, 06:24 PM
SadSack is offline
Joined Aug 2008
don't say that I've still got 3 working Nano Fleas and 6amp modded ones takes a lot to burn them out.
You should check out v9.4. I can watch 2g motor very slowly start to spin and smooth speed change all the way to max . He's done a great job with it. I have rewinded one of my old ones for fun. None load speed 45000 rpm. I did swap out fets on esc there little bit slow but once done pretty rapid to respond
Discussion circuit to go from brush to brushless motor electrontube Multirotor Talk 2 Jan 25, 2013 05:43 PM
Discussion Is this the only ESC compatible with Brushless and brushed motors? Bigbond Electric Power Cars 7 Jan 23, 2013 01:54 PM
New Product Unique Walkera V400D02 / V370D05 and RX2614V Brushed to Brushless Motor Converter BlueHorizons Product Announcements 1 Nov 18, 2012 11:02 AM
Help! Converting from Brushed to Brushless Motor shah Electric Plane Talk 19 May 04, 2009 11:50 PM
can astro gearboxes be converted for brushless motors Joel K. Scholz Power Systems 5 Mar 19, 2005 01:51 PM
