Old Jan 25, 2013, 08:48 PM
Kaw1000 is offline
Find More Posts by Kaw1000
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
Pylon stickers on wing
I flew a Pogo in a event where they put different color stickers on the wings. Can someone tell me the best way to get those stickers off of the monocote??
Kaw1000 is offline Find More Posts by Kaw1000
Old Jan 25, 2013, 09:22 PM
fizzwater2 is online now
Find More Posts by fizzwater2
United States, KS, Overland Park
Joined Jun 2007
Lighter fluid usually works, or a little heat from a heat gun, but dont overheat the monokote. Also, remove them as soon as you can after the race. You can also use a little wax or polish on the wing before sticking them on, but that only helps next time, right?
fizzwater2 is online now Find More Posts by fizzwater2
Old Jan 26, 2013, 07:13 AM
I Marauderer is offline
Find More Posts by I Marauderer
I Marauderer's Avatar
Powder Springs, GA
Joined Oct 2008
The lighter fluid has never worked for me. I always use a heat gun and heat the sticker and slowly peal it off. And like Fizz said sooner is better than later.
I Marauderer is offline Find More Posts by I Marauderer
Old Jan 26, 2013, 08:29 AM
Kaw1000 is offline
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
Its been on a few months..so I have a job ahead of me. wish there would be a better way to mark the wings.
Thanks guys
Old Jan 26, 2013, 09:11 AM
Joined Jun 2007
If you have the same stickers that I've seen at most races, the lighter fluid helps, but I've had best luck squirting on a bunch, and letting it soak for a while. It does work it's way through the sticker to the glue. Once you get an edge loose, you have to squirt more lighter fluid under it as you SLOWLY lift the sticker.
Heat is easier, but if you're at a race and find that you've forgotten to peel off the last event's sticker, lighter fluid is more portable..
Old Jan 26, 2013, 09:19 AM
Powder Springs, GA
Joined Oct 2008
Fizz is right about if you are at a race and forgot to take the old sticker off. I have been fortunate to have a deep cycle marine battery and a 1500W inverter so I can take my heat gun with me. I also let others use it and I don't have the noise a generator produces but, I am looking at a generator as a lot of race fields don't have any power.
Old Jan 26, 2013, 12:43 PM
Joined Jun 2007
I'll bet you and your heat gun are pretty popular at races!
Old Jan 26, 2013, 01:43 PM
Powder Springs, GA
Joined Oct 2008
It is getting that way Charging batteries, etc. Heck I can remember going around and bumming off others so it all evens out.
Old Feb 22, 2013, 09:27 PM
Edalves68 is offline
Find More Posts by Edalves68
Edalves68's Avatar
United States, Mt, Billings
Joined Feb 2012
Hint, take the sticker before applying it to your wing and lightly place it on your shirt. The small amount of lint it picks up helps in removal after the race and as long as you wrap the leading edge it will still hold very well. Credit to the the Helena HellCats on this tip.
Edalves68 is offline Find More Posts by Edalves68
Old Feb 24, 2013, 07:52 PM
Kaw1000 is offline
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
I used a heat gun and it came off with no problems...thanks for tips guys.
Old Feb 27, 2013, 09:17 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
Wax your wing right before you put stickers on it....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Feb 28, 2013, 09:56 AM
Kaw1000 is offline
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
Got it!!
Old Feb 28, 2013, 09:23 PM
Dale 813 is offline
Find More Posts by Dale 813
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Hopefully. In two weeks, I'll be putting stickers on my wing for the first time !!! I was told to put Rain X on the wing before.
Dale 813 is offline Find More Posts by Dale 813
Old Mar 02, 2013, 12:36 PM
JetMech2002 is offline
Find More Posts by JetMech2002
Racing Enthusiast AMA 3557
JetMech2002's Avatar
United States, MO, Sedalia
Joined Sep 2011
Seems like an issue for alot of people. One would think that an alternative to this method would be looked at. Maybe even contacting the company that makes the stickers to see if a lower tack adhesive be used.
JetMech2002 is offline Find More Posts by JetMech2002
Old Mar 02, 2013, 12:59 PM
Powder Springs, GA
Joined Oct 2008
I started racing again in 08 and have been going to 8-12 races a year. I have heard about the lighter fluid method and about a zillion other methods to protect and remove stickers from the wing. I hadn't heard of the RainX until Dale mentioned that. I have yried a few of them but, I have found if i just wait until I get home and crank up the old heat gun and soften the sticker glue a bit they always come off with a minimum amount of hassle and no problems. I am sure that one of the sticker companies adhesive worked great with the lighter fluid method but "Mr. Murphy" be a very close acquaintance of mine the sticker adhesive that I was trying to soften never worked. I look forward to trying the RainX but I do worry about the sticker coming off before I am through racing especially if the is a flyoff and I need to change sticker colors asap. I have a race in two weeks and I will be trying something different or just take my big marine battery and 1500 watt inverter and have the heat gun in my pit area.
Discussion Rudder on a wing... Thoughts on my design? Nightstone Flying Wings 5 Feb 06, 2013 09:02 AM
Discussion KF Swifty wing - need advice on powering this flying wing bbz Foamies (Scratchbuilt) 3 Jan 20, 2013 02:16 AM
Discussion Questions on pylon gliders luvmyjello Electric Sailplanes 0 Jan 14, 2013 07:24 PM
Discussion Stickers on molded wings - does it matter? Neil Walker Modeling Science 12 Aug 14, 2007 04:33 PM
Poll: Stickers or no stickers on SS? Kramer_87 Parkflyers 6 Oct 24, 2003 05:58 AM
