Old Jan 25, 2013, 09:26 PM
shamrock1990 is offline
Find More Posts by shamrock1990
Fly A Mile High
shamrock1990's Avatar
Aurora, Co
Joined Jan 2004
Engine mounting question on Corsair 60 Arf
The manual says "Center the engine mount in relationship to the
oval holes in the firewall." What does that mean? Do I center the blind nuts in the center of the oval holes? Not quite sure how critical the location in the mounting holes is. Also, there are two pencil lines that intersect roughly in the middle of the firewall. I dont recall draing those lines(I bought this plane 5-6 years ago!) and there is not explanation of what they are for in the manual. Are the mounting bolts supposed to line up with them? Ive included a pic, hopefully you can see the pencil marks! Thanks for the help!
Brendan
shamrock1990 is offline Find More Posts by shamrock1990
Old Jan 26, 2013, 01:53 AM
Kit_Builder is offline
Find More Posts by Kit_Builder
YAY the tourists are GONE
United States, MA, Sandwich
Joined Feb 2010
At work now but those are thrust lines. Will give more info later
Kit_Builder is offline Find More Posts by Kit_Builder
Old Jan 26, 2013, 07:13 PM
Joined Feb 2010
On the edge of the firewall where the pencile lines are, is there small laser marks maybe 1/2 inch long. If yes then those lines are the Vertical and Horizontal thrust lines
If no I have no Idea what those lines are.
What brand ARF do you have?
Do you know what thrust lines are?
This forum is for the workings of engines you will get more traffic if you posted this in "fuel plane talk" forum
Old Jan 27, 2013, 03:10 PM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Hangar 9 Corsair 60
http://www.hangar-9.com/ProdInfo/Fil...575-manual.pdf
The oval holes in the firewall are to allow the engine mount to accommodate multiple engine size and case widths. Adjust the mount location so you see equal amounts of the oval holes peeking out from the mounts and tighten the mounting bolts. If you're a little off, you'll never notice it.
My assumption is the lines on the firewall are either center or thrust lines.
Hemikiller is offline Find More Posts by Hemikiller
Sold Top-Flite 60-size Corsair ARF NIB hyperknight Aircraft - Fuel - Airplanes (FS/W) 5 Feb 07, 2013 10:22 PM
Discussion Engine mount on 60 size Corsair Arf shamrock1990 Engines 2 Jan 25, 2013 02:03 AM
Discussion Hangar 9 60 corsair engine question... shamrock1990 Engines 9 Jan 16, 2013 11:45 AM
Discussion Parkzone f4u corsair firewall/motor mounting question Rc ninja Electric Warbirds 1 Jan 14, 2013 10:55 PM
Sold Top Flite 60 Corsair ARF vanvan818 Aircraft - Fuel - Airplanes (FS/W) 5 Jan 06, 2013 07:23 PM
