This thread is privately moderated by ross_badger, who may elect to delete unwanted replies.
Old Jan 25, 2013, 06:55 PM
ross_badger is offline
Find More Posts by ross_badger
Trader Rating: 70
SuperX Hex and X8 Flyer
ross_badger's Avatar
Columbus, IN
Joined Jul 2009
Trader Rating: 70
For Sale
DJI F550 Frame Polycarbonate Domes!
For sale are polycarbonate domes for DJI F550 frames. The cost is $25 plus shipping for a standard hemisphere dome or $30 plus shipping for a hemisphere dome with a removable GPS sensor protection/mounting pocket.
You can order online at www.BadgerFly.com
DJI F550 frame hemisphere dome dimensions: 152mm inside diameter, 76mm from flat flange to inside top of dome, 185mm diameter of flat flange.
Clear Polycarbonate Material
0.080" thick (2mm) clear polycarbonate dome weighs about 85 gms and is very strong to protect those expensive electronics. Polycarbonate (Lexan, Makrolon, etc) is the strongest plastic and won't shatter like acrylic, PET-G, and other clear plastics that you can buy at a cheaper price. These are the real deal if you care about your electronics!
The flange has indentations to line up with the F550 frame inner plate screws. If you would want to use the screws to mount the dome, simply use the indentations to drill appropriate size holes. The dome can be mounted using velcro as well.
This hemispherical dome can be purchased alone or with an optional GPS sensor unit pocket. The pocket fits perfectly at the top of the underside of the dome to protect the sensitive GPS unit or other electronics that need to be mounted above the flight control board. It can be attached with velcro or with nylon or aluminum screws (steel screws will affect the GPS signal). The mounting hardware is not included. Polycarbonate plastic will not affect the GPS signal.
ross_badger is offline Find More Posts by ross_badger
Old Jan 26, 2013, 08:46 AM
txflyboys2 is offline
Find More Posts by txflyboys2
Trader Rating: 59
txflyboys2's Avatar
USA, TX, Lancaster
Joined Nov 2004
Trader Rating: 59
The domes look great, Ross!
Larry
txflyboys2 is offline Find More Posts by txflyboys2
Old Jan 26, 2013, 01:59 PM
saskya is offline
Find More Posts by saskya
Trader Rating: 1
DR , EVIL
saskya's Avatar
Canada, QC, Montreal
Joined Apr 2012
Trader Rating: 1
Subcribe
saskya is offline Find More Posts by saskya
Old Jan 27, 2013, 06:29 AM
Trader Rating: 70
Columbus, IN
Joined Jul 2009
Trader Rating: 70
Larry
Your dome is on it's way, Larry!
Thanks, Ross
For Sale Polycarbonate domes for Rusty's UAP1 frames. ross_badger Aircraft - Electric - Multirotor (FS/W) 3 Jan 15, 2014 06:51 PM
For Sale Polycarbonate Domes for Rusty's UAP1 Frames ross_badger Aircraft - Electric - Multirotor (FS/W) 4 Jan 25, 2013 05:27 PM
Sold DJI F550 Flame Wheel with DJI Motors & DJi 30amp ESCs & Props peaksview Aircraft - Electric - Multirotor (FS/W) 2 Jan 22, 2013 09:53 AM
