Old Jan 25, 2013, 05:12 PM
jimmy boo is offline
Find More Posts by jimmy boo
jimmy boo's Avatar
United States, WA, Mercer Island
Joined Dec 2012
Video
New scratch build.
hey guys hopefully you can all check out my recent thread on the plane, but I need to get all the electronics for it. It weighs about 350 grams with the nose weight (95g). wingspan 30inches. which is needs to have aa good CG, of course with electronics, the weight could go down. I have a transmitter from the FMS easy trainer 800 and could sue that as the transmitter, I may be able to use the reciever if its easy to take off. idk. Anyways heres the plane. need all the electronics/battery etc. help i can get.
it is a full three channel plane with some cool features.
#1 self leveling, dihedral wings make sure that it will never fall onto it's side.
#2 with such a big rudder, it will always turn to face the wind without control
#3 hand free gliding/self correction, will not stall unless extreme loss of speed, even then it will self correct.
#3 3 channels elevator, rudder, throttle.
BTW the plane and plane are 100% self made, although a lot of help came from the forums.
P.S. the plane is intended to be a motored glider.
the video you saw was just a hand launch with no controls, I had no way to steer it and all movement was on its own,
thanks to all.
jimmy boo is offline Find More Posts by jimmy boo
Old Jan 27, 2013, 06:04 PM
jimmy boo's Avatar
Joined Dec 2012
Thread being closed, all other comments, which are welcome, please post here:
http://www.rcgroups.com/forums/showthread.php?t=1815502
Discussion Seeking suggestions for next scratch build dglo Scale Kit/Scratch Built 29 Oct 29, 2013 08:12 PM
Question First Scratch Build Questions elmtree Scratchbuilt Multirotors 9 Jan 23, 2013 10:00 PM
Discussion Ugly 1 Scratch Build asusrick Fuel Plane Talk 3 Jan 19, 2013 03:44 PM
Discussion Ugly 1 Scratch Build asusrick Balsa Builders 0 Jan 19, 2013 02:53 PM
