Old Nov 22, 2001, 03:47 PM
pierluigi demontis is offline
Find More Posts by pierluigi demontis
'Akilaweb
pierluigi demontis's Avatar
Cagliari,Italy,Europe
Joined Feb 2001
Fast E.R. 400 free plans!
Hello
maybe someone is interested to know that I've just updated my site with a downloadable plan of the FastE.R. 400: a simple but performing little plane quick and easy to build. What could you ask for more? Try it and enjoy the FastE.R. !!!
You can find it at
http://web.tiscali.it/AKILA/faster40%20engl.htm
happy flying
PG
pierluigi demontis is offline Find More Posts by pierluigi demontis
Old Nov 22, 2001, 09:33 PM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
Looks good, nice design.
Downloading them now. Thanks.
Kevin Murray is offline Find More Posts by Kevin Murray
Old Nov 23, 2001, 02:30 AM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
PG,
That looks nice and simple! Downloading.....
......or not downloading. All I'm getting is a lot of coding in in the left margin. What'd I do?
tim
tim hooper is offline Find More Posts by tim hooper
Old Nov 23, 2001, 07:17 AM
'Akilaweb
Joined Feb 2001
Tim,
strange enough... I've tried myself and the second time everything went OK. Maybe us a server problem. Anyway I can send you the plan as an e-mail if you wish. BTW it is in a Autocad 97 format, but I can send it in a different format. Let me know...
Anyone experienced problems in downloading? BTW n°2 the CG is at 28 % of the cord !
PG
Old Nov 23, 2001, 09:16 AM
VequalsIR is offline
Find More Posts by VequalsIR
Wiltshire
Joined Sep 2001
PG
I had the same problem as Tim.......
Steve
VequalsIR is offline Find More Posts by VequalsIR
Old Nov 23, 2001, 09:51 AM
Joe Yap is offline
Find More Posts by Joe Yap
Singapore
Joined Nov 2001
Looks cool! I've succesfully downloaded it. I think you guys should click on item 4 with the RIGHT button instead of left and you'll see a command block.Click on the 'save target as' command and you'll get it. BTW how does the plan view of the fuselage looks like? Your drawing doesn't seems to have the profile. Anyway, I think I can figure it out myself. Thanx for the free plan. Meanwhile, I'm searching for the spare S400 motor.
Joe Yap is offline Find More Posts by Joe Yap
Old Nov 23, 2001, 03:21 PM
'Akilaweb
Joined Feb 2001
Hi Joe
thanks for your appreciation. You're right about the fuselage plan view, it's simply obtained keeping -i.e. with a foam block- a distance of about 5 cm (or 2 inches) at the wing seat location and then cyanoing together the fuse sides at the rear. At the front you glue the sides to the s400 motor mount former. A detail is missing too: the
front wing attachment point that is a small piece of wood -not ply- with a
notch to accept the half rib with a hook that retain the wing in front.The aft attachment point is missing too, but it's a simple piece of
obechewith a threaded hole to accept a M3 nylon bolt! BTW the first flight
of the new version was a total success! If you keep the wing at 0° the model
is veeeery fast, but still very forgiving about the stall. This is due to
the excellent airfoil...
Let me know if you build it...
Old Nov 23, 2001, 04:37 PM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
No go, I'm afraid! Tried right-clicking (I'm using Netscape BTW), and no 'Save target as' option appears!
PG,
To save trouble, and to hide my total lack of programming knowledge, I'll gladly accept your offer of an email plan! I have TurboCad so the choice of format is yours!
tim
Old Nov 23, 2001, 11:20 PM
Trizza is offline
Find More Posts by Trizza
Grand Poobah of Nothing
Trizza's Avatar
Once Australia, now Finland
Joined Feb 2001
You should get "Save Link As..." in Netscape. I'm using version 6.2 and I get it.
Trizza is offline Find More Posts by Trizza
Old Nov 24, 2001, 03:41 AM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Hmm....partial success anyway.
I've downloaded the plan OK, but am unable to open in TurboCad. I get the following failure message;
"Failed....Open DWG Error.
DXF Line contains non-numbers"
Sorry to be a stupid Brit here lads, but I'd really like to have a better look at this model!
tim
Old Nov 24, 2001, 05:15 AM
Reformed Slimer is offline
Find More Posts by Reformed Slimer
Retired, but not tired
Reformed Slimer's Avatar
Live Oak, Florida
Joined Oct 2001
Fast E.R. 400
PG
Great looking little plane, good plan, no problems downloading or viewing!
Thanks!
Reformed Slimer is offline Find More Posts by Reformed Slimer
Old Nov 24, 2001, 05:59 AM
KAMarks is offline
Find More Posts by KAMarks
KAMarks's Avatar
Louisville,KY
Joined Jan 2001
What is a good target weight for the Racer?
Ken
KAMarks is offline Find More Posts by KAMarks
Old Nov 24, 2001, 04:35 PM
'Akilaweb
Joined Feb 2001
KAMarks
I've built two of them: the first elevator/aileron HS55 servos with 2mm balsa sides weighted 417 grams with the Gunther prop and about 430 with the CamSpeedProp and alu spinner; the second one with 1,5mm balsa sides and three HS55 weighted...the same! , so I suppose the thinner sides are a good choice if you want to go for the rudder chance. BTW today I've managed a little knife edge flying... great fun/small package !
Keep those sparks flying...
PG
Old Nov 24, 2001, 05:53 PM
Joe Yap is offline
Singapore
Joined Nov 2001
Thanx Pierluigi, I'll keep you posted when I got mine done. Meanwhile still struggling to finish up my S400 pattern plane.
Regards,
Joe Yap
Old Nov 25, 2001, 03:51 AM
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Got it by email from Pierluigi. No problem!
Thanks for the help though, lads.
tim
Splash-E Free plans in FLY RC jimsp Waterplanes 78 Jun 22, 2007 03:58 PM
Mini E-Xtreme Free Plans misi 3D Flying 0 Nov 30, 2004 04:19 PM
WIP :free YF-23 Speed 400 Pusher Plans ssyed Electric Ducted Fan Jet Talk 7 Jun 07, 2004 05:57 PM
Pylon Free Plans 400 size...... Sluf7 High Performance 6 May 28, 2002 04:22 PM
p-51d s-400---free plans? i-fly Scale Kit/Scratch Built 2 Nov 27, 2001 08:37 AM
