Old Jan 25, 2013, 01:08 PM
vactrol is offline
Find More Posts by vactrol
Joined Sep 2005
HobbyKing 64mm 10 Blade 3300Kv Alloy EDF Unit
I couldn't find a thread on this 10 blade 64mm EDF from HobbyKing. Does anyone have one yet? I have one on order.
vactrol is offline Find More Posts by vactrol
Old Jan 25, 2013, 01:13 PM
vactrol is offline
Joined Sep 2005
Link:
http://www.hobbyking.com/hobbyking/s...ey_3300Kv.html
Old Jan 25, 2013, 01:50 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
I see the radiused lip is removable. I wonder if they offer a strait version for ducting, or is the shroud long enough after removing the radiused item.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jan 25, 2013, 04:01 PM
vactrol is offline
Joined Sep 2005
Seems like it might barely cover. I'll post a pic when mine arrives. (Still in China, but has been "sorted" by USPS, whatever that means.)
Old Jan 25, 2013, 05:06 PM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Seems like that's gonna be some Roasty Toasty 1000 watt motor... inside that streamlined containment oven. Dubious engineer(?) in there somewhere
Bare is online now Find More Posts by Bare
Old Jan 25, 2013, 09:24 PM
vactrol is offline
Joined Sep 2005
Found a demo video. I think the 10 blade shown is this unit. Looks similar anyway.
HobbyKing Daily - Alloy Casing EDF (3 min 6 sec)
Old Jan 26, 2013, 12:07 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Fuzz
It's long enough. The lip is held screwed on by clear tape. Cutting the tape and unscrewing the lip off is all that is required.
anlucas is offline Find More Posts by anlucas
Old Feb 14, 2013, 11:11 PM
vactrol is offline
Joined Sep 2005
My EDF finally arrived (25 days to U.S.). Looks to be in good shape.
Weighs 230 grams (6 under spec).
Radiused lip is not removable, it is part of the entire shroud.
Sticker on unit says "KV:3000", specs say 3300KV. Hmm.
Will try to test this weekend. My ESC requires larger bullet connectors so I will have to change those first.
Old Feb 15, 2013, 04:31 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
I have had many examples of wrong Kv on some brands of Chi-Com motors. I have had to start at the lower cell count range, and see what readings I would get. The add cell(s). Even their amp restrictions/limits are not very accurate. So I prefer to just spend a few more bucks and get the proven brands. Assemble my own fan.
Shame the lip is not removable. Makes for a good "foamie" jet replacement fan tho.
Fuzz
Old Feb 15, 2013, 10:48 PM
vactrol is offline
Joined Sep 2005
Yeah I'm planning to put this in a T-45 foamie.
Just ran a quick test on 3S (40C) and got 670g of thrust at 40 amps. Seems a bit low, but battery has been sitting for a few weeks. Voltage was 12.3V afterwards. Should be able to try 4S tomorrow.
On the plus side the 10 blade "woosh" sound is great.
Old Feb 15, 2013, 11:52 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
Does the fan seem to be well balanced?
BadLemon is offline Find More Posts by BadLemon
Old Feb 16, 2013, 01:19 AM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
That Kv is higher than 3000, to load 40A, on 3s and only a 64mm fan. Cutting down the original CS-10 rotor should significantly lessen the higher load qualities of the design. It has always been my thoughts, that when a "un-common" designed rotor is cut down, it loses it's efficiency, over the original diameter.
In the case of this rotor, the high pitch is lessened, as diam is increased. Cutting it back, utilizes that part of the rotor that is at a higher pitch than the stock tips. I think that explains the nice wooshing sound. Efficiency will most likely go down as power is increased.
But...I like scale, over un-realistic speeds. So, quality sound has always been more important to me. I find higher pleasure in seeing and hearing a more realistic model in flight.
Fuzz
Old Feb 16, 2013, 03:07 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Has anyone confirmed the thrust numbers for this setup?
I got way less than 3lbs on 4s with slightly more KV and higher volts
regards
erh7771 is offline Find More Posts by erh7771
Old Feb 16, 2013, 01:06 PM
vactrol is offline
Joined Sep 2005
At full power, yes. However it has a slight buzzy sound at certain mid-throttle settings. Not sure if this is EDF timing, bearings, or balance issue? I'm about to post a video of a test run, you can hear it as throttle is reduced at the end of the run.
Old Feb 16, 2013, 01:08 PM
vactrol is offline
Joined Sep 2005
Agreed. I wasn't all that interested in EDFs until I heard the whooshy ones.
Discussion HobbyKing Mercury Alloy 64mm 4700KV EDF Unit lipoflyer Electric Ducted Fan Jet Talk 292 Dec 14, 2014 12:02 PM
Discussion HobbyKing vs. RC Lander - 70mm Alloy EDFs delfin2003 Electric Ducted Fan Jet Talk 1 Jan 27, 2013 03:38 AM
Wanted HobbyKing 64mm Alloy EDF 4000kv 850w 4S JGuilty13 Aircraft - Electric - Jets (FS/W) 4 Jan 23, 2013 12:54 PM
Sold Mercury Alloy 64mm and Extremem Hobbies Alloy 10 Blade 70mm Alpha10 Aircraft - Electric - Jets (FS/W) 8 Dec 08, 2012 02:12 PM
