Old Jan 25, 2013, 09:36 AM
potshot is offline
Find More Posts by potshot
Vertical approach specialist
potshot's Avatar
Northeastern Illinois
Joined Mar 2009
Help!
Motor substitution advice needed
I came across an old Cobweb airframe that was popular in the 2005-7 time frame.There are no electronics, servos or motor. The bare airframe weighs only 68 grams with control rods. I need to select a motor for it.
According to an old thread, owners used these motors: Hacker A20-50S, LensRC 22.7mm 17T and Python 30. The Hacker is 29g but I can only get sketchy info on the others. It appears that a BW 1300 KV might be a good one to try. I also have 15, 17 and 19 gram motors on hand. For power I'm thinking maybe 2S 400-500.
Anybody care to advise or comment?
potshot is offline Find More Posts by potshot
Old Jan 25, 2013, 10:30 AM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Here's a review from 2006. They suggest MPJet 22/7-60D, 7x4 APC slow flyer, 8-amp ESC and a 2S 340mAh lipo.
whitecrest is offline Find More Posts by whitecrest
Old Jan 25, 2013, 11:00 AM
flydiver is offline
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
Go REALLY light if you can. Too much weight and the wings POP on you.
It's quite fragile, almost completely an indoor sort of plane.
flydiver is offline Find More Posts by flydiver
Old Feb 02, 2013, 10:21 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Motrolfly 2203-1600 v2 (18g, ~1645Kv) would be good with a 7x4 APC SF.. just 4.50A (33W, 215g thrust @ 29mph).
http://www.subsonicplanes.com/Motrolfly_Motors.html
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 02, 2013, 07:07 PM
potshot is offline
potshot's Avatar
Joined Mar 2009
Thanks, Dr. Kiwi. That looks like a nice unit. I appreciate the suggestion.
I have already installed a 1300 KV BW and am going to maiden it tonight in a golf dome. The BW balanced it nicely; the battery is just a touch forward of the CG, so I'm hoping for an uneventful maiden.
Help! My plane went for a swim today! Need some quick advice! PiperCub49 FPV Aircraft 22 Feb 01, 2013 04:37 PM
Question Need a little more advice... av8ersteve Jet Turbines 17 Jan 28, 2013 03:44 PM
Question Need advice on setup for a new plane danov High Performance 1 Jan 23, 2013 01:27 PM
Discussion KF Swifty wing - need advice on powering this flying wing bbz Foamies (Scratchbuilt) 3 Jan 20, 2013 02:16 AM
Discussion New Build Help Advice Needed Jerkstore1 Multirotor Talk 5 Jan 17, 2013 09:26 PM
