Old Jan 25, 2013, 02:04 AM
Joined Nov 2012
light ply substitute ?
Has anyone ever used luan plywood instead of lite ply for fuselage construction ? Seems light enough, from the stuff I've used in the past for non aviation projects. Seems a cost effective substitute. Am I wrong here, or just cheap ?
medic976 is offline Find More Posts by medic976
Old Jan 25, 2013, 06:09 AM
Play loud, Fly high
Gil Gauger's Avatar
Vincennes,IN USA
Joined Apr 2007
Lite ply substitute
Yes indeed to your question. In my years of electrical contracting I have done many a dumpster dive. My stash currently includes 3 sheets of Oak veneered 1/8 inch ply. Makes really nice parts. Recently had a housebound club member cut me a short kit for an Aquila, and using this ply and carefully selecting the balsa it should build out lighter than the Airtronics kit.
Gil Gauger is offline Find More Posts by Gil Gauger
Old Jan 25, 2013, 09:02 AM
prodjx's Avatar
Joined Jan 2007
If the ply's are of equal thickness I'd use it, if not no. I once made an acceptable 15' canoe out of the non-equal Luan but I glassed it inside and out.
prodjx is offline Find More Posts by prodjx
Old Jan 25, 2013, 11:34 PM
grog85361's Avatar
United States, AZ, Wittmann
Joined Jan 2006
Ed Slobod specified this material in the RCM construction article for the Paragon. In my experience, it is made with a weather resistant glue and is very durable.
grog85361 is offline Find More Posts by grog85361
Old Jan 26, 2013, 05:30 PM
Joined Nov 2012
At the local Lowes, and Home Depot, I found (labeled) 5.2 mm luan plywood. Actual measurement was just at 3/16". Too thick and heavy ? It goes for $6.47 for a 2 x 4 foot sheet. I'll pick up a sheet tomorrow and see what shakes loose.
Old Jan 26, 2013, 05:55 PM
Joined Nov 2012
or actually, maybe I should consider continuing to look for actual 1/8 inch stuff
Old Jan 26, 2013, 05:56 PM
grog85361's Avatar
Joined Jan 2006
Home Depot or Lowes should also carry a product called "Door skin". It is slightly less than 1/8". That is the material I referred to in my previous post about the Paragon.
Old Jan 26, 2013, 09:24 PM
Joined May 2010
Lowes and home depot probably can't get it, but most real lumber yards can order 1/8 Italian bending poplar. I usually buy three sheets at a time.
Mark
Mark Anderson is offline Find More Posts by Mark Anderson
Old Jan 27, 2013, 10:36 PM
United States, MA, Waltham
Joined Dec 2001
I've seen some kind of light plywood at Home Despot that seemed like it would be nice for making planes, if slightly heavier. It was very pale. Aspen, maybe?
If you want a true structural equivalent to the usual light ply, use bubble gum with a few wood fibers as reinforcement. Or find some fruit crates.
If the luan has 3 equal plies, it will NOT be very stiff or strong across the grain of the face sheets. 4 layers is ok. The normal thin face plies and thick inner ply are more closely matched in terms of directions. Either one might be more appropriate, depending on the application.
lincoln is offline Find More Posts by lincoln
Old Jan 28, 2013, 11:00 PM
Joined Nov 2012
OK... So I didn't go for the 5.2 mm (3/16") from Lowest/Home Depot. Still trying to find local supplier of 3mm (1/8"). Also..... What ever happened to spruce sticks!?!?!? Tried a couple LHS's here in San Antonio, and was amazed to find NONE !!! Guy behind counter was useless, as well. Didn't even know what spruce was!!!!!
Old Jan 30, 2013, 03:40 PM
United States, CT, Farmington
Joined Sep 2008
I used to buy this stuff for making forms. The actually make two different versions , one for bending along the 8 ft dimension and the other for bending along the 4ft dimension. apparently it's a balsa wood core and Poplar for the two skins. Did not get along the Laser I had back then
Jim
jimbonk is offline Find More Posts by jimbonk
Discussion Peel ply substitute? GaryO Composites Fabrication 12 Jan 31, 2012 01:18 AM
Discussion Non-hobby substitutes for building materials-- ply, carbon rod, ... learn2turn Foamies (Scratchbuilt) 26 Jul 20, 2011 08:16 AM
Question Ply Wook Substitute Ganthor The Builders Workshop 8 Sep 29, 2009 08:00 AM
Best Router Bits for Cutting Light Ply/Balsa????? Tim H. The Builders Workshop 8 Dec 10, 2004 07:37 PM
Unwarping light ply? chemsurfer The Builders Workshop 1 Apr 24, 2003 05:21 AM
