Old Jan 26, 2013, 01:57 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Originally Posted by SlowBarless View Post
Didn't know you could throw that hard Sebbe
Thanks for clearing that up Alien Tech.
Interesting points about ground and air speed. Doppler can be a confusing thing sometimes. I don't blame him for getting confused though, it took me ages to understand the concept. It was only when I first heard the F3D models going around the pylons that it finally clicked.
I throw very hard
really, this gps showed right numbers quite often but sometimes it was really bad, so to me its not good enough as i dont know which numbers is right at the end..
sebbe is offline Find More Posts by sebbe
Old Jan 26, 2013, 02:23 PM
Mreyello is offline
Find More Posts by Mreyello
Mreyello's Avatar
Deutschland, RP, Niederzissen
Joined Dec 2011
The problem with these small GPS systems is mainly that they are not able to handle accereration above 4G.
According to Stefan Merz ( manufacturer of the SM-Logging system) this is the limit of the sensors which are obviously used in all small gps systems, so all of them will have the same problem.
Some F5d or F5b will have higher G-forces even at acceleration under power in straight line,in corners it may be higher than 35G!
If you log the hole flight as a speed graph it may be possible to sort out strange readings especially when you have also an altitude graph to compare.
Some guys in the german forum did some serious developement on software to eliminate the rubbish but it seem to require a lot of knowledge and the intention to get proper readings and not the highest possible speed to claim.
Systems which are only able to give the highest speednumbers or max altitude or average speed are simply useless.
Yello
Mreyello is offline Find More Posts by Mreyello
Discussion How to estimate flight times accurately, and safely. Tharr62 Multirotor Talk 16 Jan 23, 2013 01:11 PM
Question HKing mini osd w/gps or aeorc mini osd gps abletowinginc FPV Equipment 1 Jan 10, 2013 06:37 AM
Discussion How accurate is Spektrum RX data telemetry? zanek Radios 2 Dec 13, 2012 11:25 PM
Discussion Voltron MINI GPS HOW TO SET FROM MPH TO KMH ? FedericoA High Performance 4 Mar 18, 2012 07:45 AM
