Old Jan 24, 2013, 08:50 PM
Rhea is offline
Find More Posts by Rhea
Registered with FAA since 2016
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
Question
What should I use to paint monocote?
I think I have seen this question answered here in the past but since I never thought I would need to know I didnít pay attention. Well, now that I think it would be a reasonable alternative for me I ask the question; if I can what should I use to paint monocote? Note that I use the generic word monocote because itís an ARF and I donít know for sure what it is or if it even matters. Whatever it is it began as a transparent blue and has faded to nearly clear. Not a good color for a high-flying sailplane regardless of what the sky may be. It disappears in cloudy sky or blue.
I am recovering the faded blue sections of the wing and tail with red Monocote but I want to paint only the underside of the fuselage to minimize the weight gain.
Anyone with good ideas please throw them in here.
Rhea is offline Find More Posts by Rhea
Old Jan 24, 2013, 11:04 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Personally, I wouldn't paint it, I've never (apart from one time where I did some crazy stuff) had good experiences painting film.
And no, you don't want to do the 'crazy stuff' which involved covering the film with tissue.
If I were you I'd strip the wings and recover in the same red you're doing the tail with. It'll look muuuuch much much better than a wing that's faded on top and painted on the bottom.
Just my 2c.
Curare is offline Find More Posts by Curare
Old Jan 25, 2013, 08:44 AM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I have had really good luck with good old Kyrlon in the old days. I painted some dice on the wings of my Kougar way back in the early 90s with it. Plane lasted a good 10 years and the paint was just fine. Just cleaned REALLY good with acetone first.
More recently I've used Krylon Fusion. (http://www.krylon.com/products/fusion_for_plastic/)
I even had a place on an open structure where it got dinged where I had a paint stripe. It was Ultracote, so it just dinged, and didn't break. A LITTLE heat, the ding came out just fine, and you couldn't even tell on the paint stripe where the ding was.
FWIW, I paint trim work on as I always seem to have a problem with smaller shapes/paint strips, etc coming off if I use covering.
rcav8r2 is offline Find More Posts by rcav8r2
Old Feb 07, 2013, 08:03 AM
sixfins is offline
Find More Posts by sixfins
sixfins's Avatar
United States, FL, Sunrise
Joined Jul 2011
Is the krylon fuel proof, or does it need a sealer?
sixfins is offline Find More Posts by sixfins
Old Feb 07, 2013, 08:08 AM
kenh3497 is offline
Find More Posts by kenh3497
Don't fear the reaper
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
How would some of the dyes work that the automotive community uses to change interior colors or refinish interior items like your dash. Colors may be a bit limited though. They are available in rattle cans.
Ken
kenh3497 is offline Find More Posts by kenh3497
Latest blog entry: A letter from my other senator
Old Feb 07, 2013, 12:02 PM
rcav8r2 is offline
rcav8r2's Avatar
Joined Sep 2001
Not sure of the Fusion as I only have used it on Electric planes. The OLD, "normal" stuff I used on my Kougar certainly was. The exhaust pointed right on part of the painted parts. And after a good 10 years or so of a lot of flying, the paint was about the only thing intact when it crashed. (Broken elevator push rod in a dive... wasn't pretty ) Can't say if the "new and improved" stuff is.
As with any new process, best to run a small test.
Old Feb 08, 2013, 02:43 PM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I use rustoleum. But like was said, I'd strip it and recover with whatever mylar since this is a sail plane. When I soared, we did everything possible to lighten it up. Interesting to hear about krylon. Most of the guys I fly with wont use it because they say it is not fuel proof. My test showed it softened up with raw fuel. You say that was older krylon back then? Think I need to test again.
Edwin
edwin1 is offline Find More Posts by edwin1
Discussion Painting problems using Tremclad spray paint ? riggerman Scale Boats 2 Jan 27, 2013 07:42 AM
Discussion What paint should I use to paint my balsa Nobler airplane? seascape2 Painting and Finishing Tips 4 Oct 03, 2009 10:26 AM
What paint should be used on balsa sheeting JAM Electric Plane Talk 6 Aug 21, 2004 03:00 PM
what kinda spray paint should I use on foam? troymills Foamies (Kits) 4 Jul 15, 2004 06:30 PM
What paint should I use to finish field box? groundfx The Builders Workshop 4 Mar 27, 2004 03:24 PM
