Old Jan 24, 2013, 04:14 PM
alexmussol is offline
Find More Posts by alexmussol
alexmussol's Avatar
Castellon, Spain
Joined Jul 2004
New Product
New SF601 Electric Bike WCB in ArtesHobbies.com
Nuova Faor SF601 Electric Bike - World Championship San Marino
In ArtesHobbies already have available the new creation of Nuova Faor after winning the World Championship in San Marino in the Superbike class
This new Sf601 has totally changed its geometry lowering the center of gravity 25mm redesigning all components of the bike to achieve high efficiency in driving as demonstrated in this last World
The chassis is made unifying the main and rear tail in one piece Carbon 3.5mm thick giving extreme rigidity and greatly simplifying the chassis Sf601
The placement of the servos as low as possible to lower the weights favor of the bike
This bike is designed for mounting mini servos Savox SH-1250mg
New Probike front suspension with a new interior design stop making 25mm and 11mm shorter suspension travel more than enough to fulfill its function
Rear shock Down Stop system perfectly coupled at the rear of the chassis
New Aluminum rear swing 3 parts, much narrower than its predecessor and tensioner system for a chain adjustment and perfect alignment of the rear wheel
This new rear swing has been removed from the head width of the wheel axle and the fastening nut, that adding these two points to the new width of 5mm narrow tilting 9mm been achieved by making each side margin to much knock the bike without touching the rear
Has inherited from his predecessor Sf509 cooled engine support
Comes with new wheels NF Insert Integrated tires we can mount both Slick and cut PMT are currently marketed
Here we see the weight of the chassis in the absence of the other components being a more than acceptable final weight
The new kit Sf601 Electric Bike WCB contains:
-Moto Sf601
-Full body Lexan
-Lexan pilot
-Probike Hydraulic Fork
-Radial Brake System
-Hydraulic Steering damper
-New wheels Integrated Insert
-Engine pinion
-Nylon Side supports and coating
-Vinyl decorative stickers
-Support bike on front wheel
www.arteshobbies.com/OnlineShop
Best regards
Alex Guinot
alexmussol is offline Find More Posts by alexmussol
Old Jan 27, 2013, 04:35 AM
metalbike2 is offline
Find More Posts by metalbike2
Joined Mar 2012
metalbike2 is offline Find More Posts by metalbike2
Old Jan 28, 2013, 02:11 PM
superbiker is offline
Find More Posts by superbiker
SUPERBIKER
Belgium - Antwerpen -2070 zwijndrecht
Joined Mar 2005
sf 601 newbike
........superb......best bike ever seen.......best kit bike at the moment I think
But what abouth the tyres, how you can glue them on the wheels?? there are no longer grooves or spaces in the wheels??
Look forward to see how they do that and can that hold the power of this bike??
superbiker-Belgium
superbiker is offline Find More Posts by superbiker
Old Feb 14, 2013, 01:43 AM
alexmussol's Avatar
Castellon, Spain
Joined Jul 2004
The tires fit perfectly and can be mounted Pmt all slick and cuts in any hardness, these new wheels NF Insert Integrated give exceptional grip
Regards,
Alex Guinot
Old Feb 14, 2013, 04:21 PM
Ifly_65 is offline
Find More Posts by Ifly_65
Ifly_65's Avatar
United States, MO, St Louis
Joined Dec 2003
That is one sweet bike!
Ifly_65 is offline Find More Posts by Ifly_65
Old May 25, 2013, 02:05 AM
Foodie is offline
Find More Posts by Foodie
Joined Sep 2011
A couple of questions to this bike
What is the leaning angle with that front brake and front fork? It seems a bit wide there...
Can you put Xray 48P spurs on it?
On the sales pictures this part: http://www.rc-motorradshop.de/produk...tbilder/?X12/A is aluminium but on the Artes photos its plastic?
Is the mini servo for the steering good enough? Seems all other are going for the low profile one...
Foodie is offline Find More Posts by Foodie
New Product ROADIES in ArtesHobbies.com alexmussol Motorcycles 0 Sep 24, 2012 05:47 AM
New Product New Airbrush section on ArtesHobbies.com alexmussol Motorcycles 0 Sep 21, 2012 09:57 AM
Discussion Promotion Arteshobbies Wcb San Marino 2012 alexmussol Motorcycles 3 Jun 02, 2012 12:11 PM
Discussion ArtesHobbies.com WCB Sponsor San Marino 2012 alexmussol Motorcycles 4 May 05, 2012 03:44 PM
Discussion He ended the 2011 WCB Lostallo ArtesHobbies Promotion alexmussol Motorcycles 14 Aug 25, 2011 11:59 AM
